knocking noise when i turn the steering wheel
Rating: Thread Rating: 4 votes, 5.00 average.
Old 12-27-2004, 04:41 PM
elchinocache's Avatar
c240
everytime i turn the steering wheel i hear a knock and i can feel a small vibration in my feet coming through the floor.anyone know what it could be. i had the same problem in my old celica but in my celica it was the cb joint that went dry. but my car doesnt have axles in the front. i searched the forums and didnt find anything.
THanks
BEnnie
Old 12-27-2004, 05:14 PM
Zonoz's Avatar
2002 Black C230K
Check for ******
Old 12-27-2004, 07:28 PM
c240
Old 12-27-2004, 09:35 PM
W0n6_3d4n's Avatar
C200K (w204)
Check the cover just above your feet, u might hit it and make the cover touch the sterring ball or sth. It happen to me once, just a simple remove and reinstall.
Old 12-27-2004, 10:40 PM
05Css's Avatar
HI elchinocache, if its what I think it is then you might have had the same problem I had. I use to have a C240 and when I would make a turn to park the car or come out of a parking place and turn the steering wheel I would feel and hear a knocking sound. I took it to the dealer and it ended up being what they called " the control arms". The C240 between 2001 - 2003 is know to have control arm and suspension issues. Let us know what happens. Good luck
Old 12-29-2004, 06:57 PM
BruNo's Avatar
07' ML350
i had a knockin sound before when turning the wheel full lock, we thought it was the control arms, but it ended up that the 2 rubber bushings holding the steering rack needed retightening, and some metal trimming as the metal inserts were rubbing with each other.
Old 08-18-2007, 08:45 PM
pookie's Avatar
2013 c300 4matic, 2002 c240
Anyone know how to retightening bushings? My dealer is >1 hr drive and don't want to deal with them if I can DIY.
Old 08-23-2007, 09:28 AM
EDC320's Avatar
2015 ML350 4Matic
I have the same problem.
First thought it was low on power steering fluid.
Topped off the fluid level but noise is still there.
Knocking noise when the wheel is turned to the right.
Going in to shop tomorrow.
Old 01-31-2010, 07:58 AM
Pancham's Avatar
ML 320 MY2000, C320WZ MY2004.5
Did anyone figure out what the cause of the noise and what is the solution ??
Thanks.
Old 01-31-2010, 09:52 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Thanks for searching. Meanwhile, I'm still at the 2nd post from a wee over 5 years ago.. "check for ******"..
Old 01-31-2010, 04:36 PM
Super Moderator
samaritrey's Avatar
THE C350
wow and the guy lived in McLean VA like me lol.
Old 02-01-2010, 01:44 AM
Paculdo's Avatar
06 CTT-S
i have the same issue when i turn the steering full (to park or pulling out of the garage).. as much as i wanted to go to the dealership and have this looked at.. i think it comes from the right-front wheel (only). a month ago, i slightly rear ended another car, the front right side was pushed a bit (barely noticible). would the dealership point this out as a cause of this problem? or they will still fix it under warranty? i don't want to go there only to be charged for any other "necessary" fixes that they may charge.
Old 02-01-2010, 03:17 PM
Super Moderator
Glyn M Ruck's Avatar
Check Castor arm bushes, camber bushes, Sway bushes & links, rack bolts, rack end bushes.
Old 02-05-2010, 03:03 AM
kimman's Avatar
C230K coupe
i have this problem before and finally found that the steering rack bushing worn.
Old 02-05-2010, 07:05 AM
Super Moderator
Nice pics for those that might not have seen rack bushes.
Old 02-05-2010, 11:18 AM
Super Moderator
samaritrey's Avatar
THE C350
wow i wonder what mine look like at 142k do you have a pn on those and how long do they take to replace?
Old 02-05-2010, 11:33 PM
LILBENZ230's Avatar
Yes yes.. I have this noise, too. How much and how easy to replace?
Old 02-06-2010, 07:13 PM
WaveyKat's Avatar
Something Slow
hmm maybe this is why i get that knocking. part numbers and a DIY will be great if its an easy job :-)
Old 02-06-2010, 09:56 PM
d1no's Avatar
05 c230k 6spd
idk if thats the problem i have but when i start my car in the morning its really cold like 20-30 degrees but when i go in reverse and turn the wheel to the right i get some strange noise kinda like the knocking you guys describe.. but yes deff part numbers and maybe a diy from someone who has done it
Old 02-18-2010, 11:25 AM
WaveyKat's Avatar
Something Slow
so does anyone have the Parts numbers? i try looking on EPC but it doesnt show those Rubber Bushing..
Old 03-03-2010, 02:21 PM
Super Moderator
samaritrey's Avatar
THE C350
bump anyone know anything about the bushings.
Old 03-03-2010, 02:31 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
or ******??
LOL....such a random post by that guy!
Old 03-05-2010, 02:50 PM
SteveAustin's Avatar
2005 C230 Kompressor Sport Sedan
I read a TSB about this for which no remedy exists yet.
Cause:
Torsion of the hydro-mount in the strut rod.
When maneuvering, the hydro bushing end stop plug can collide with the inside of the outer sleeve.
In isolated cases, this surface can exhibit pinpoint wear depending on the operating conditions of the vehicle. This wear is caused by the end stop plug resting against the outer sleeve during braking maneuvers.
As the end stop plug slides over the damaged area, fluctuations in friction pairing occur which cause the knocking/creaking noises.
Note:
The noise can generally be reproduced by driving a figure-8 in reverse. If the noises occur during this maneuver, the steering gear is not the cause of the problem and must not be replaced.
Remedy:
No remedy exists at present time
Old 04-02-2010, 08:19 AM
WaveyKat's Avatar
Something Slow
i think its part #60 am going to the dealer and get a set of four! cost about $13 Bucks each!
File Type: pdf
Old 04-08-2010, 07:02 AM
WaveyKat's Avatar
Something Slow
Part Number 203-333-05-14 you need Four!
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: knocking noise when i turn the steering wheel
