E-Class (W211) 2003-2009
Old 06-04-2015, 08:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
Service E-Class (211) USA
Rating: Thread Rating: 5 votes, 5.00 average.
Old 06-22-2006, 09:35 AM
vettdvr's Avatar
03 E500 and Corvette
How do I reset the FSS after I do a service. The nearest service is 100 miles away and for the "normal" stuff I can do local I would like to reset the FSS.
Also when I go from Service D to the sub menu by holding the reset button I get another menu. Service data, Items, Service work, and Confirmation. I can scroll up and down with the + / - buttons but can't select and read what each of the items have in their sub data. Any help Thanks Jim
Old 06-22-2006, 10:10 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Jim,
Go to the link I gave you in the Tech Talk section in response to your post and download the pdf -- it will have instructions.
Regards,
Paul...
Old 09-07-2006, 03:15 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Calling up the service data information
• Switch ignition on.
• Outside temperature display.
• Press button up or down on the steering wheel until the FSS PLUS indicator appears in the display.
• Press the trip odometer reset knob for about five seconds. The Service Menu appears in the display.
• Select the items menu with the + or – button.
• Press the menu systems button (left side, below up and down buttons).
• The service indicator now displays the items menu (1 – 14 described below).
• Press the menu systems button until the outside temperature display appears.
Beginning 2006 MBUSA removed the ability to pull up detailed service data information in the MFD by using the reset button.
Furthermore, the manual states if maintenance is not carried out by an authorized MB center an instructional to reset the indicator is available from either your dealer or directly from MB.
Old 11-26-2006, 06:03 PM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
For some reason I can't pull up the FSS Plus on my Display using the below procedures in the first posting on this thread.......any suggestions for getting access to the FSS Plus?
Old 12-09-2006, 07:00 PM
  #30
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Update for MY07
Played with it and found a procedure that works.
1) Get to temp screen and tap the reset button 3 times quickly in succession. (should show voltage display)
2) Now you can go through the steering wheel control buttons as listed above to get to the service menu for viewing and resetting.
HTH
P.S.
Someone with a -> MY05 and a MY06 -> one might want to compare.
Old 12-12-2006, 11:45 AM
  #31
'71 Pinto
Originally Posted by amdeutsch
Played with it and found a procedure that works. Someone with a -> MY05 and a MY06 -> one might want to compare.
Doesn't work.
Old 12-12-2006, 12:19 PM
  #32
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Doesn't work.
Please explain. I was able to see the the individual items to be performed for the respective service as well as the reset functionality, the miles/days remaining, etc.
Old 12-12-2006, 12:33 PM
  #33
'71 Pinto
Relative to my vehicle, nothing happens in pressing the reset in the temp screen – any combination of taps. And when held in constant, of course, the trip odometer resets. Let us not forget the 07 IC, other than appearance, is a brand new. Side note; remember the preset fiasco that could not be adapted to the 03 – 06 IC.
Old 12-24-2006, 02:43 PM
  #34
'71 Pinto
OK, here’s the deal on calling up the service data information:
2003-2005
- Switch ignition on (position one);
- Outside temperature display;
- Press button up or down on the steering wheel until the FSS PLUS indicator appears in the display;
- Press the trip odometer reset knob for about five seconds (Service Menu appears in the display);
- Select the items menu with the + or – button;
- Press the menu systems button;
- The service indicator now displays the items (1 – 14);
- Press the menu systems button until the outside temperature display appears.
2006
- MPH display;
- Press the trip odometer reset knob three times consecutively (Voltage display appears);
- Select the Service menu with the + or – button;
- Service indicator displays items (1 – 14);
- Press the menu systems button until the MPH display appears.
2007 (compliments of amdeutsch & csumt76)
Old 12-28-2006, 04:20 PM
  #35
'71 Pinto
Recommended A and B Service:
Old 01-20-2007, 08:29 PM
  #36
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Second OIL report
I know that is has been a long time, but here is the second oil report analysis. It is obvious to me that I did the correct thing to paying for an oil change at 5,000 miles. Then MB paid for the oil change at about 11k miles but I did not test that oil. At 16K miles I paid for an oil change because I was going on a long trip over the desert and wanted clean oil. I tested this sample and it was a waste of good oil (having it changed). Now my car just had another free oil change that I also know was probably wasted at 23k miles, but free is free. I now plan to change it within the 2,000 mile allowance of what the FSS says. After I run the oil for what that computer says I can I will test it again and repost.
On a side note, my MFD service display usually started at 13,000 miles until next service. Now it started at 10,000 miles! I wonder if MB changed their software. I have not had time to personally speak with the mechanic, but I think that this was the case. This means that 03 and 04 model owners who are still under free service will have more frequent changes, If the interval was 13K the dealer would change the oil after about 11k. Now that it says 10K to start with, they will change it when it after 8k miles driven or 2,000 miles remaining on the service. I find this interesting and I wonder if it has anything to do with that fact the MB no longer offers free service and they want to make more money by getting their customers in sooner.
Enjoy the report,
Steve
Attached Thumbnails Service E-Class (211) USA-scanned-oil-report.jpg   Service E-Class (211) USA-scanned-oil-report-1.jpg   Service E-Class (211) USA-scanned-oil-report-2.jpg
Old 01-28-2007, 12:21 PM
  #37
BudC's Avatar
2011 E550, 2013 GLK
Steve
This is an e-mail I got from my SA.
Sorry its taken so long to get back with you they will let us service the
car if its been 1 year since the last 1 was done or since the purchase date
of the car if its the first service. or 10,000 miles which ever comes first
It says that MBUSA will pay for service at one year or 10,000 miles (which ever comes first). I've been getting yearly free service with an average mileage of 7,500 miles.
I've seen where BMW have also changed to permit service at the one year mark.
Old 02-10-2007, 03:48 PM
  #38
'71 Pinto
Service recommendations
2003 & 2004 free maintenance as per FSS recommendations (initial post) however, oil changes will be allowed @ 1-year or 13,000 (10,000 AMG) mile intervals.
2005 to date free maintenance eliminated and fixed service intervals as follows:
Old 02-13-2007, 01:39 PM
  #39
06E350Sport's Avatar
2006 E350 Sport
Question Service A
We just got Service A done at about 12,000 Mi. It was about $275.00. The invoice shows that we were charged for 9 quarts of synthetic oil at 9.95 a quart. Does an E350 really hold 9 quarts? that seems like a lot of oil for a 3.5L gas powered V-6.
Old 02-13-2007, 01:53 PM
  #40
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
It really takes 8 liters.
Old 02-13-2007, 02:04 PM
  #41
2006 E350 Sport
Thumbs up Thanks!
Wow, well that explains it! It would take 9 quarts to make 8 liters. I guess that high volume of oil helps give the long service intervals. Thank you for your prompt response JP!
Old 02-25-2007, 07:59 PM
  #42
Frank Wiesmann's Avatar
Enjoy the report,
Steve
On a related note, I just had my oil and filter changed in between the service after around 6,000 miles without resetting the FSS computer. I stood next the the car so I know it was changed. Still, the computer continues to count down miles and has not added any with the fresh oil and filter. Some people said the got extra miles between services after refilling a quart, so I thought mine would really go up after changing the whole thing. Any thoughts?
Old 02-26-2007, 11:33 AM
  #43
SAguirre's Avatar
The first time I had the oil changed without resetting the computer it took about 20 miles of driving and the FSS gained about 800 miles. The second time it did not gain that much, maybe 200 miles at most. I think that it depends on how bad the oil was that you took out. The first time I did it the test came back stating that the oil was full of metal and junk (higher conductivity readings), when the new oil went in, the computer noticed. The second time I did it, when there was a minor gain in miles left, the oil came back as still being in good shape so I wasted the oil. On a side note, sometimes it takes a bit of driving for the computer to notice that the oil is better, but I bet that in your case the oil that they removed was still very good.
Just my thought,
Steve
Old 02-26-2007, 02:09 PM
  #44
Just my thought,
Steve
Steve,
that would make sense. I have driven about 100 miles since the change and the computer keeps counting downward. Based on your sample analysis, I guess I did the right thing: After I got my car in 2003, I had the dealer change the oil and filter at about 600 miles and again at 4500 miles. Then I stuck to the FSS and had the dealer change it at 11000, 25000, 37000 and 49000 miles. Now I had it changed at 56000 at an independent dealership. The filter and oil looked dirty, but I guess according to the computer it was still good after all.
Old 07-02-2007, 03:52 PM
  #45
'71 Pinto
2007 e350/550
MBUSA service items (compliments of Forumid):
1 N/A
2 every 52,000 miles or 4 years
Replace engine air cleaner insert
3 every 25,000 / 2
Replace combination filter (passenger compartment)
4 N/A
5 every 143,000 / 15
Replace fuel filter
6 N/A
7 every 91,000 / 5
Replace spark plugs
8 every 143,000 / 15
Replace coolant
9 every 2 years
Check body for paint damage
Replace brake fluid
Check for damage/corrosion - chassis and load-bearing body components
10 every 5 years
Tilt/sliding roof – clean slide rails & shoes
11 every 3 years
Panorama sliding roof – clean & lubricate guide mechanism
12 every 13,000 / 1
Engine oil & filter change
13 first 13,000 / 1
Check catch/safety catch & hinges on engine hood
Check brake system
Check Power steering
Check windshield washer system (rear window & headlamp if applicable), wiper blades
Reset IC service indicator function test
Check warning, illumination, interior, trunk lighting
Check audible warning system
Check wheels/tires, spare
Check battery
14 every 26,000 / 2
Check for leakage – major components
Check poly-V-belt
Check brake system
Check seat belts/buckles
Check parking brake function
Check front axle, ball joints, boots
Check battery
15–19 N/A
20 39,000
Automatic transmission oil & filter change
Transfer case oil change (4matic)
20 over 143,000
Check fluid levels / changes are updated:
Transmission
Rear axle
Front axle (if applicable)
Transfer case (if applicable)
Check air, fuel, ventilations filters are updated:
Engine air filter
Fuel filter
Combination filter
Check integrity of engine, mechanical components:
Perform compression test (hot & cold)
Perform leak down test (hot & cold)
Check spark plugs
Exhaust system hangers/leaks
Check damaged/worn drivetrain parts:
Front/rear wheel bearing play
Axle joint play
Driveshaft flexible discs
Tie rod & drag link joints
Old 07-19-2007, 03:14 AM
  #46
SLAM's Avatar
C32/ A4 3.0/ E320 W211
does anyone know what is service E stand for? my car have 54k miles.
Old 07-19-2007, 12:31 PM
  #47
'71 Pinto
The estimated completion time for service E is 5 hours. Follow the procedure in post 34 then compare item numbers in the MFD to those listed in post 1. I assume they should hold true for MY05, other than item 12 because oil changes were updated to a fixed interval 13000 miles or 1 year.
Note: A=1 hour, B=2, C=3, D=4, E=5, F=6, G=7, and H=8.
Old 09-13-2007, 01:09 PM
  #48
jwc
jwc's Avatar
Broke Acura
I have a service G coming up..that's going to be a costly one isn't it? E320 2003
Old 10-11-2007, 11:14 PM
  #49
rostov's Avatar
2016 GLE 450 Coupe
I tried this procedure from post 43, and I got those numbers displayed, but some of them were missing, the last one was 13. What does it mean? What is "Addit. Work" means?
Thanks!
Old 10-11-2007, 11:32 PM
  #50
rostov's Avatar
2016 GLE 450 Coupe
Thanks!
Ok. Those are the tasks from the post 1 that have to be done? Sorry for my stupidity - never had a chance to deal with this thing.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: Service E-Class (211) USA
