E-Class (W211) 2003-2009
JERKING!!!!! very annoying.
Old 07-24-2004, 12:06 AM
yxc145's Avatar
2004 E320, 2006 Audi A6, 2008 C350 W204, 2010 BMW F10, 2012 Porsche Carrera S 991, 2014 E350 W212
The Jerking continues..... whenever I slow down to about 5 mph in a sitting traffic. And I don't want to risk the chance of the dealer messing w/ the ECU, flashing the program that I installed in it. They did that one time. They didn't flashing out the software, but they change something else that totally slow the car down, BUT!!! the problem came back after a couple of days!! Does anyone know exactly why it's doing this? and if MB has a solution for it already?
Old 07-24-2004, 08:26 AM
fazooley's Avatar
2013 w204 C350
Make sure your car is in S "Standard" mode and Not C mode. I was given the car on C mode and drove it for 2 weeks. After complaining of the jerking and hard shifts I bring the car to the dealer and the guy pretty much chuckled. Seems if the car is in C it will actually skip 1st gear all together which gives the jerky feeling. I could be totally off since you have software modded, but maybe Im not. Good luck
fazooley
Old 07-24-2004, 10:11 AM
Barry45RPM's Avatar
2015 ML 350
...and here I thought it was:
S= Sport Mode
C= Comfort Mode
Old 07-24-2004, 12:31 PM
yxc145's Avatar
wait... where are you guys??
My car says. S and W
S=Standard
W=Winter or Wet
Yes, I have it on S mode... and it does the same thing.... I feel like I am trying a manual transmission car w/ bad clutch!!!
Old 07-24-2004, 12:34 PM
lig
lig's Avatar
was '03 E320 - now - '04 S4
Looks like we have the same problem (and both of us have '03 E320s)
I seem to recall that a fair number of other owners had the same thing and one or two of them had the torque converter replaced and it fixed the problem.
Old 07-24-2004, 02:21 PM
Barry45RPM's Avatar
2015 ML 350
S=Standard
W=Winter or Wet
My dad's '02 E3 has "S & W", my '04 E5 has "C & S"
Old 07-24-2004, 04:41 PM
matt5555's Avatar
'03 E320 here. Same jerking.
Have not contacted dealership when I go in for next service (soon) I'll have them check it out.
Old 07-24-2004, 11:30 PM
stevenW211's Avatar
2010 BMW F10 535i
03 E240 here in HK, same jerking.
RJC
RJC's Avatar
Exclamation
There is the same complaint in the W209 section. The cure for one was the t/converter and for another it did no good, the car eventually had the transmission contol unit repalced which was apparently redesigned. Hope this helps.
Old 07-25-2004, 12:53 AM
mbfan67's Avatar
pinto
hey guys, i have an 04' and i have the same problem when i'm traffic going about 5 to 10 mph. should i bring it in to the dealer? the car is only 3 weeks old.
Old 07-25-2004, 03:04 AM
topspin4hand's Avatar
2004 E320, 2004 Lexus GX470
I sometimes feel this jerking when I'm coasting around 5 mph but I never considered it a problem. I have an '04.
Old 08-06-2004, 12:03 AM
yxc145's Avatar
Jerking, again!!
Ok. I am taking my car to the dealer to fix the Jerking AGAIN!! I asked the service advisor if he has encounter customer w/ the same problem. He said no. I told him it's a pretty common problem among the 03 E320.. He said he heard nothing about it and had never had customer come in for that problem.. Well, I think he lied.. But, anyways.. I want to know if anyone had the same problem and was fixed. Can you tell me what exactly is causing the jerking at low speed and how to fix it. What solution did MB actually come up to fix it? So, I can tell the dealer service advisor and shopforman, since they couldn''t fix it the 1st time.
Old 08-06-2004, 11:22 AM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
I have encountered a little bit of jerking at slow speed too. It seems to occur just after starting the car and driving slowly out of the driveway. I haven't noticed it reoccuring after the car is warmed up though. I haven't taken the car in for this problem since it is so intermittent. I too will be interested in any fixes.
Jim
Old 08-06-2004, 12:23 PM
Barry45RPM's Avatar
2015 ML 350
My opinion is that in the 7 speed, 1st gear is so low and the car tends to stay in 1st a little too long when you drive slowly & the car is "cold". I believe there will be a programming change made to the transmission in due time, as MB gets feedback from owners.
Old 08-06-2004, 01:51 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
E320s don't have the 7 speed tranny you are talking about.
Old 08-06-2004, 02:03 PM
DWP
DWP's Avatar
'08 AM Vantage V8 - '03 E500
When you get the "jerking", have you tried "manually" shifting the transmission down to the lowest gear it will allow? You shouldn't have to do that to avoid "jerking", but it would have diagnostic value. Analogies to manual transmissions may not be valid, but the kind of "jerking" you describe would, in a stick, usually mean that the gear in use is too high (numerically, not ratio) for the road speed. If manually downshifting fixes the jerking, the question for the dealer then becomes one of why the car isn't downshifting automatically like it should
Old 08-06-2004, 02:21 PM
JimPurdy's Avatar
My slight jerking happens at about 2 mph. The car seems to start in 1st gear and hasn't shifted at this speed.
Jim
Old 08-06-2004, 03:15 PM
drboxster's Avatar
2004 E class, 87 porsche 911
jerking is gone
I just had the transmission control module replaced and upated software flash. Jerking is gone. Now if they could only get my phone to work. Do not feel bad my dealer tell me I am the only one with such problems. We know better. Good Luck
Old 08-06-2004, 09:28 PM
RJC
RJC's Avatar
Exclamation
The condition you describe is normal with all late model MB's as its to help the cats get hotter quicker and that's why it only occurs when cold.
Old 11-18-2004, 10:27 PM
mahwahdave's Avatar
Has anyone made progress on the jerking problem? I was unsuccessful in reproducing the problem for the shopforeman.
Old 11-18-2004, 10:40 PM
RJC
RJC's Avatar
Talk with the shop foreman and enlighten him that MB should be aware of this problem, copy one of the previous posts that discusses the software flash and module replacement and show it to him. Also, ask drboxster for the name of his dealer and service writter so the writter and your shop foreman can communicate if the shop foreman still questions the fix.
Old 11-18-2004, 10:41 PM
lig
lig's Avatar
Jim
Mine is exactly the same. Hot or cold - it doesn't matter. When I asked the tech about it - his reply was that if everything else was working fine then he didn't want to mess with it for fear of making it possibly worse.
i just deal with it. So ghetto on a 50K car
Old 11-18-2004, 11:33 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Model 211, Model Year 2003
P-B-07.00/28f FEB04 – Lack of Power/Hesitation
Engine Control Unit Software Update
My guess is that this will probably work for early build 04s also.
Old 11-19-2004, 06:23 AM
Frank Wiesmann's Avatar
Jerking
Hello,
the jerking could also be the torque convertor. A member of a German forum had to have the engine of his E500 replaced at 40,000 miles because it was exhibiting strong vibrations and jerking when moving off from a standstill. When he took it in to the shop, they discovered a faulty torque convertor and damage the the engine valves as well as a lack of pressure in the seventh cylinder. They decided to replace the engine as a symbol of good faith (no 4 year warranty in Germany!).
Old 11-19-2004, 10:22 AM
Almost a Member!
SDChargers's Avatar
MB E320, BMW 323i
yxc145,
I have the same issue with my '03 E320. I get that "jerking" acceleration especially when I head into a turn from a standstill (e.g. making a left or right turn at an intersection) and then try to accelerate out of it. I also get it sometimes during stop-and-go traffic. It's almost as though the car doesn't know whether you want to accelerate hard or slow from a standstill.
This is the one thing where my old 528i beats the E320 hands down. My 528i was very smooth during accelerations.
I keep meaning to bring this up to my service advisor but keep forgetting. Based upon the advice of the other members, I'll ask them to take a look at it the next time I'm in.
Quick Reply: JERKING!!!!! very annoying.
