What do you know, C55 weighs less than CLK55 & C32
Old 07-19-2004, 12:38 PM
MiamiAMG's Avatar
C63
C55 - 3,540 lbs/1,605 kg
CLK55 - 3,635 lbs/1,657 kg
C32 - 3,605 lbs/1,635 kg
I thought that the C55 would weigh more. guess i was wrong
Old 07-19-2004, 12:48 PM
Former Vendor of MBWorld
BlackC230Coupe's Avatar
Fast Cars!
That is weird.
Old 07-19-2004, 12:54 PM
e-fivehundred's Avatar
werd!?
Old 07-19-2004, 02:12 PM
brianhn1's Avatar
into things
Lighter = faster, better handling, more chicks can fit in the car
Old 07-19-2004, 02:57 PM
rrf
rrf's Avatar
say what?
Hey Chris,
Where did you get the data? I personally don't believe it. There are lots of variables in weight measurements for cars. Let's get this sorted out. Some of the variables that come to mind are: full tank/empty tank, spare/no-spare, with driver etc.
Supertest quoted C55 at 1680kg = 3703 lbs, but you can be sure that wasn't empty. It would be what they consider to be a true "test weight". I know Norm weighed his C32 at an actual 3600 with 1/2 tank ready to go (no driver).
The C55 has bigger wheels, longer nose, bigger motor, (less supercharger weight), bigger exhaust, rear deck spoiler. I don't see anywhere they actually saved weight. I guess the C32 is the lighter one by about a little, maybe 40-50lbs.
You can drive your C55 to a scale, only costs about $3 max.
Old 07-19-2004, 03:10 PM
©32's Avatar
C55 AMG
This is from AMG...
Attached Thumbnails What do you know, C55 weighs less than CLK55 & C32-stats.jpg
Old 07-19-2004, 03:17 PM
Fast Cars!
According to MBUSA the C55 weighs 3,540lbs and the C32 according to the brochure weighs 3,540lbs. I find it hard to believe there the exact same weight.
Old 07-19-2004, 03:28 PM
Almost a Member!
cbrcab's Avatar
2002 M3 Cab, 2005 C55 AMG, 2007 B7 RS4
Hi Chris
According to the data I have you are right,
C32 3605 lb ( AMG Catalog 2003 )
C55 3540 lb ( MBUSA website )
but again....it doesn't make sence, except they use different material on the chassis.
Old 07-19-2004, 03:46 PM
Fast Cars!
Originally Posted by cbrcab
Hi Chris
Where did u get that? I did not see 3605 in the catalog and i can take a pic.
Old 07-19-2004, 04:01 PM
Almost a Member!
cbrcab's Avatar
I call my dealer, and that's what they give me. I'll try the get that catalog tonight. It's hard for me to believe too.
But is that matter? I mean it's only about 50 lb of different ( if it's true )
I think you and I may already have the different on the bodyweight.
Old 07-19-2004, 04:33 PM
AaronC's Avatar
C32
I also remember reading an article in a mag saying that the C55 is lighter then teh C32 by 75lbs.
Old 07-19-2004, 05:40 PM
vimzin's Avatar
06 E55 current, M5 Sold, C32 Sold, 330xi Sold
what C32 weight are you talking about 2002 or 2003-4, since the C32 in 2002 didnt come with the spare wheel.
Old 07-19-2004, 06:26 PM
Thai's Avatar
2004 Mercedes G500 Black
Damn, that supercharger in the C32 weighs a lot!!
Old 07-19-2004, 08:37 PM
s4iscool's Avatar
those numbers are inaccurate. You cant tell if the number is wet or dry...pointless.
Old 07-20-2004, 12:29 AM
smgC32's Avatar
Take the spare out of the C32 to be fair as I am sure both cars are weighed with their spare installed. That will be good for about 50lbs minus the number for the space saver spare.
More importantly, look at the increase in front and rear track which should help in the handling department. There is an increase of 13mm in the front, and 10mm in the rear, which is just about what my aftermarket wheels and tires have equaled. I will have to think it through, but it seems that the wider track should cause additional wheel/tire clearance issues with both the front and rear fenders upon a wheel/tire upgrade for the C55. Does this increase in track set the hub mounting surface out towards the fender more causing the stock 7.5/8.5 wheels with 225/245 tires to sit in the same orientation as upgraded 8.5/9.5 wheels with 235/265 tires? Remember one inch is 25.4mm, so the increase in track is about .5", or half the wheel width increase of the upgraded wheels, which represents the same increase out towards the fender if you split the 1.0" total wheel width increase between the inside and the outside. Food for thought...
Old 07-20-2004, 05:16 AM
AMG FANATIC's Avatar
Nothing
I've read 2 road tests here and both said the C55 is lighter, but not by much. Both magazines tested the C55 faster than the C32. The one did a comparo between C55, S4 and M3 on a track. Guess what - they chose the C55 overall!
Old 07-20-2004, 09:13 AM
AaronC's Avatar
C32
Link?
Old 07-20-2004, 09:21 AM
BenzoAMGpower's Avatar
Cars and boats!
actually, im not surprised that the C55 is lighter... The motor is definately lighter!!! The Kompressor weights a lot on the C32... the C55 motor weights just as much as a C43 motor.. its the same block with different bore and stroke!!!
Old 07-20-2004, 10:40 AM
slytoksy's Avatar
E500
The C55 AMG and C32 AMG have exactly the same weight:
C55 AMG: 1635kg (3605lbs) http://www.carfolio.com/specificatio.../id/?id=119174
C32 AMG: 1635kg (3605lbs) http://www.carfolio.com/specificatio...s/id/?id=78331
Old 07-21-2004, 02:09 PM
MiamiAMG's Avatar
C63
Hmmm, interesting. I get different numbers for the C55 in MBUSA
Old 07-21-2004, 04:02 PM
hantzis's Avatar
2004 C32 AMG
From multiple sources on the net, I've seen the curb weight at 3,540lbs not 3,605lbs. From specs, you would think the C55 would weigh more, but you never know. I'd like to check the official manual statement on this...
Quick Reply: What do you know, C55 weighs less than CLK55 & C32
