C-Class (W202) 1995-2000: C 200 CDI, C 220 CDI, C 270 CDI, C 180, C 200 K,C 230 K, C 220, C230, C 280
Where is the Idle Air control valve?
Old 02-29-2004, 09:48 PM
Almost a Member!
sunrat's Avatar
Can someone tell me where exactly this part is located? Is it after the mas, or the piece after the mas? I think i just need to clean this thing out but i need someones help so i can find it. Thanks.
Old 03-01-2004, 07:40 PM
redcoupe's Avatar
11 ML350
Why are you looking for it?
The idle air is control by the computer and like I saw in your earlyer post it sounds like you need a M16 motor(throttle body).
If you have a 104 engine(silver valve cover) then its a PITA to change.
Brian
Old 03-01-2004, 07:46 PM
DougandhisC280's Avatar
2008 SLK-280
The IAT sensor is on the intake right before it goes into the engine. It takes 30 seconds to check and change. This is on the older engine.
Old 03-01-2004, 09:33 PM
Almost a Member!
sunrat's Avatar
can i just simply clean some junk out and try to make it work better or is it pretty much fried? i have near 95000 miles on the car and the check engine light has been on about maybe 1 and a half year.
Old 03-02-2004, 03:22 AM
2008 SLK-280
I'd try cleaning it with alchohol first. This trick sometimes works on even the air mass meter.
Old 03-02-2004, 04:49 AM
mjtray's Avatar
C280
Just so I understand this correctly, if you stand in front of the engine and look at the air intake. You have the MAS on the left, the plastic trunking then snakes over the top of the engine and down into the throttle body. Just before it enters the throttle body up on the right hand bend of the plastic trunking there is a push fit sensor.........is this the IAT??????????
Old 03-02-2004, 10:33 AM
2008 SLK-280
BINGO!
Old 03-02-2004, 01:46 PM
Almost a Member!
sunrat's Avatar
what is an iat? idle air throttle? so it is the part before the silver area?? i understand the part where the black snake lookin intake goes over the engine, it is the part right after that? what is that sensor on the HUGE air intake that is over the engine? not the mas but the sensor after that?
Old 03-02-2004, 02:51 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
carb cleaner should also do the trick...
Old 03-02-2004, 04:32 PM
2008 SLK-280
Idle Air Temperature sensor. It's right before the intake goes into the engine.
Old 03-02-2004, 10:08 PM
Almost a Member!
sunrat's Avatar
ok is that sensor on the actual MAS itself? I tried cleaning the MAS and so far no CEL, but when i get this digimoto software to check my car, ill know for sure.
Almost a Member!
sunrat's Avatar
Old 03-03-2004, 02:47 AM
2008 SLK-280
No, it's not. If we were allowed to post pictures larger than one byte I could show you.
Stupid cheap forum. What happened to being able to give out useful information?
Old 03-03-2004, 06:43 PM
Almost a Member!
sunrat's Avatar
hey doug if you can please send it to me at kings49ersfan@yahoo.com i would really appreciate it.
Quick Reply: Where is the Idle Air control valve?
