ML430 Horn
ML430 Horn
I have a '99 ML430 and the horn has stopped working. When you press the horn nothing happens. I checked the fuse, 44 I think it was and that was not the problem. Has anyone had this problem before? Or can anyone suggest what the problem may be? Thanks.
Originally posted by ML God
Check relay K1in your fuse box. there is also a fuse next to it. It is not fuse 44
Thanks, I'll check that relay. I did check the proper fuse (37 if memory serves) and the fuse was not blown. Thanks for your help. Let's see if the relay does the trick
1 Post
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Originally posted by Stiggs
The horn in my Ml is embarassing. I'm afraid to honk it! It sounds like someone is strangling a goose!!
Anyone replace it with anything better??
1 Post
Since the ML55 costs about $20,000.00 more than the other models they must have decided to put a louder horn in it.
You might want to read this link http://forums.mbnz.org/forums/forums...=49864&posts=9 You can also search the www.benzworld.org forums and find more info on these horns. Take my word on it............. they sound a hell of a lot better than the stock ML horns.
Received 1,168 Likes
Horn replacement
I installed the Hella horns from Griot's Garage. They're better than stock, but still not as good as I'd like.
They also offer these "Super Loud Italian air horns":
Italian air horns from Griot's
I really like the idea of having air horns...I see Drew from Benzworld has them in his truck. Have to check out the video he posted there with the sound of them!
Anyone here put those air horns in an ML? They look big....do they fit??
I want to order them from Griot's garage but I'm afraid to do the install myself.
Do you think the dealership would install those for me??
I figure not....they would probably charge an arm and a leg for it too!
Air horns
99 ML430
DID YOU EVER FIND OUT WHY IT STOP WORKING? IM HAVING THE SAME PROBLEM. AND I CHECKED THE FUSE AND RELAY AND IT NOT THAT. AND I DON'T WONT TO PAY $90 JUST TO HAVE THEM LOOK AT IT.
