parts fit w209/w203
2004 clk500 coupe
parts fit w209/w203
just a td-bit of info, today while doing some suspension work on my 209 CLK500 noticed that all suspension parts were labelled with a 203 series part number sway bars, knuckles, arms, so i went into parts dept at dealership where this was being done and looked at parts EPC and found all major components the same except variations in springs(options etc.) so let there be no doubt about interchangability, my reason for paying attention to this was to verify my clk500 brakes will bolt directly to a 203 chassis, i have seen questions as to interchangeability on this board so i thought i would contribute this info
Almost a Member!
CLK500
hi clkguy
just want to make it clear. so can w209 use wheels that is taken off from w203 without any problem? and can also coil over that is designed for w203 used in w209
04' CLK 500 Black/charcoal
2004 clk500 coupe
reply
Originally posted by xquisit
hi clkguy
hi clkguy
w203 and w209. my pss9 coilover kit is labelled for 203 and 209 bodies so you can safely interchange parts, brembo big brake kit same thing, labelled and designated w203 and w209, when purchasing aftermarket upgrades most stuff falls in same designations
Almost a Member!
CLK500
hi clkguy
well here's the question that I wanted to make sure. My friend offered me a used brabus mono VI 19x8.5 FA and 19.9.5 both with et35 taken from W203. I just want to know do I need to add spacer for the wheels or I can just put it and have no problem?
and by the way do you know whether I am able to use H&R coil over designed for w203 ?
anyway thanks for all the help
hi clkguy
hi clkguy
Yes, H&R CO for W203 can be fitted on a W209.
