Left low beam headlight out
Old 08-04-2013, 07:11 AM
Bhayes547's Avatar
2009 C300 4matic
My front left low beam headlight is out. I have put 2 new bulbs in it, and neither worked. My next step is to replace the fuse. Hopefully that will work, but incase it doesn't, does anyone have any other suggestions? The connectors look like new and I traced the wire as far I could see and found no signs of a cut. Thanks!
EDIT: Just read there are no fuses for the headlights. Guess I'm back to square one. Any suggestions would be greatly appreciated.
EDIT v2: Now my right low beam just went out. I'll try putting a new bulb in it, but I'm thinking it won't work like the left one didn't.
Old 08-04-2013, 01:17 PM
dolvio's Avatar
2010 C250 4Matic
Hmm interesting. Turn off the car. Put both bulbs in and then restart the car. That work?
If not, turn car off, try turning the connector that attaches to the bulb. It should only go on one way but try and reverse it if it can. Restart the car.
Old 12-05-2013, 10:58 AM
kjb55's Avatar
2016 E350 4Matic; 2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
Did you ever resolved the headlight problem?
Quick Reply: Left low beam headlight out
