2005 M.B. C240 AWD... Springy weird bong sound from rear when hitting bumps....
Old 07-05-2013, 07:29 PM
awbooth's Avatar
2013 Mercedes benz ML350 4Matic
I'm getting a springy bong strut shock weird noise coming from the rear only when we hit a good size bump. Does the awd systems take a different type of suspension tune up? Do you think the noise I'm hearing is an awd issue or suspension/shock/strut problem? C240 has 95,000 miles. Thanks
Old 07-05-2013, 08:41 PM
LLUSKYY's Avatar
2005 C230 Sport Sedan
A bong sound you say?
Old 07-06-2013, 08:29 AM
awbooth's Avatar
nice....
not sure if just replacing the shocks would help. there must be more to the rear suspension than just shocks and or springs.....
Old 07-06-2013, 11:43 AM
Resilient's Avatar
2004 C230 Kompressor Sedan
I had similar sound, ended up it was a broken spring (rear passenger side). Last ring was broken and the sound was when the spring would expand, slipping past the broken ring.
Old 07-06-2013, 12:36 PM
awbooth's Avatar
That's the exact location of where our noise is coming from. are you required to change both Springs or can you just change the rearrangement right spring?
Quick Reply: 2005 M.B. C240 AWD... Springy weird bong sound from rear when hitting bumps....
