Old 06-15-2015, 02:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Diagnostics
Print Wikipost
2013 C300 Dies on Startup?
Old 06-08-2013, 07:02 PM
JaredP's Avatar
2014 E63 AMG S
Hey guys,
Recently started having this issue with my C300. I've had the engine die right off of startup twice now, it usually happens when the engine is warm. Happened today for me when I went to the store. Engine was up to temp, went inside for 30 min, came out and started it, and it died right off the bat. Started it up again, and it kind of fought to stay alive, then it was fine. Any ideas on what the issue might be? I have contacted the dealership.
Old 06-09-2013, 04:17 PM
Drazil's Avatar
Did anything crazy happen to the interior lights or the dash? I had a similar problem with my E where it suddenly went nutso, all the lights flashed and the engine would cut out, even in the middle of driving. When the tow truck showed up, the car started up again normally and everything seemed to be back to normal. I had the truck follow me to the nearest dealership, and halfway there it happened again. Turned out to be a bad engine module and whenever it got warm, it would fail, but when cooled, it would be working again. Cost me $450 to replace.
Old 06-11-2013, 12:58 AM
MikeDaBike's Avatar
2013 C300 Sport
That happened to my 2013 C300 twice. What I did notice was that both times I started the car and put it into gear RIGHT away, not even giving it a half a second. Now I just wait a second or two after i start it before it put it in gear and it hasn't happened again
Old 06-11-2013, 01:01 AM
JaredP's Avatar
2014 E63 AMG S
It's happened to me twice too, I don't think I threw the car into gear, it was almost instant. I kind of get a weird engine noise for the first few seconds after a cold start too...
Old 06-11-2013, 11:35 AM
Super Moderator
Glyn M Ruck's Avatar
Check fuel pressure at the front rail. It should be > 3.8 bar or 55 psi while cranking. Could also be the CPS (crankshaft position sensor) if it is more inclined to happen with a hot engine.
Make sure the airbox is clipped down firmly over the MAF at the rear.
Old 06-11-2013, 02:28 PM
JaredP's Avatar
2014 E63 AMG S
Thanks for the tips, I haven't had it happen in awhile.
Old 06-12-2013, 10:16 AM
JaredP's Avatar
2014 E63 AMG S
Here is a video of the engine sound on startup. I believe something stemming from this is causing the stalling.
Old 06-12-2013, 11:33 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Agree with Glen in that it may be a fueling issue.
I know you said it is usually warm so it made me think vapor lock, but that is pretty rare with today's cars.
May also have a small leak in your fuel system bleeding off pressure??
Old 06-12-2013, 11:39 AM
JaredP's Avatar
2014 E63 AMG S
Hopefully it's nothing too big. The town I currently live in does not have a merc dealership, so I'll have to drive 3 hours to get it serviced. Hopefully it only takes one trip.
Old 06-20-2013, 06:21 PM
JaredP's Avatar
2014 E63 AMG S
UPDATE: So apparently, there is a software update for the GDI 2013 engine specifically for this issue. I'm picking up my car tomorrow. Just an FYI for anyone with this MY.
Old 06-20-2013, 10:24 PM
Super Moderator
Interesting. Thanks for letting us know. I wonder what they changed????
Old 07-05-2013, 11:28 AM
ralawren's Avatar
2017 GLC300 / 2021 C300
I am experiencing it also with just 800-900 miles. Will contact the xservice rep at local dealer. Thanks
Old 07-05-2013, 11:57 AM
JaredP's Avatar
2014 E63 AMG S
Yes, I believe the 2012 C350 has the M276 as well so it could be a problem. I got the problem at around the same number of miles. I still have engine knocking on a warm startup, but this has pretty much been deemed "normal"..
Old 07-10-2013, 09:43 AM
Properstyle's Avatar
2010 C63 AMG, 2009 M3 DCT, 1994 slicktop 2jz swapped 300z
Maybe I'm a little overly logical but If i was driving a 2013 anything and a start up issue occurred I wouldn't on a forum tryning to solve the issue the car would be going back the dealer ship with me getting a loaner under their expense.
Old 07-10-2013, 10:27 AM
JaredP's Avatar
2014 E63 AMG S
The first thing I did was contact the dealership. I posted this in hopes that it would prove valuable to other members, and it is already apparent that it was. Why revive an old thread that you didn't read just to be a douche?
Old 07-10-2013, 11:04 AM
Wasn't being a douche I was just saying, as in your thread you never stated at the begin like you should have the at car was at the dealership. You posted this on the 8th and didn't even mention going to the dealership until the 12th. Then didn't reply until the 20th that is was a software issue. Had that been be I would not be making the trip, Mercedes would have been sending a flatbed to get the car... I read the thread but like many others I see the owner always tries to solve it first instead of just leaving it to the warranty to fix and solve from the jump.
Old 07-10-2013, 12:11 PM
JaredP's Avatar
2014 E63 AMG S
Do you honestly think I would detriment a $50k vehicle by driving it if I wasn't advised to do so? I was in contact with my dealership since day one, and it was simply an afterthought to post here. As far as the dates go, I can't bring my car in whenever the hell I want. It takes 6 hours for me to get to a merc dealership and back. I waited until the weekend, drove up, rental car back, and did the same thing the next weekend, driving my C back.
Old 03-02-2024, 08:04 AM
JakeMerc's Avatar
2008 C300
2008 C300 weak start or dies on startup
Originally Posted by JaredP
Hey guys,
My 2008 C300 has a weak start or dies on startup too. Happens when engine warm. When I go to start it again, it cranks for couple extra seconds then has a rougher start. Idle rpm bit lower, doesn’t respond to gas pedal and alternator isn’t engaged for 20-30 seconds. I know cause I have a device that plus into cigarette plug that read voltage. Then when the alternator kicks in is same time the engine responds to gas pedal.
Quick Reply: 2013 C300 Dies on Startup?
