Is this correct ATF oil for 722.631 transmission?
Old 04-17-2013, 02:14 PM
KJI3jflarryfe93's Avatar
MB 236.14 ATF
How many 1-liter bottles are needed to change the transmission oil?
Old 04-17-2013, 02:31 PM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Yes Sure,,
i'm always using this ATF fluid, its based for 722.9, 7-G-tronic #: "001 989 68 03/10 or /13" .....
ZAYED,,
Old 04-17-2013, 02:37 PM
cm60k's Avatar
"6-7" liters with converter, "3-4" liters with-out converter.....
ZAYED,,
Old 04-17-2013, 02:51 PM
cm60k's Avatar
G-AMG, done good job for oil changing,
His posted may help:-
http://www.peachparts.com/shopforum/...-pictures.html
ZAYED,,
Old 04-17-2013, 03:13 PM
Saaboteur's Avatar
eclectic assortment of cars
My recollection is that Mercedes specifies a specific standard for their ATF, and the ones spec'd for the newer transmissions typically covers the older ones too. That said, the ones in the official Mercedes bottles is the same as Shell ATF. In fact, the last time I bought some from the dealer, they gave me Shell branded stuff.
Old 04-17-2013, 03:35 PM
cm60k's Avatar
I didn't know that...!!
Good Input...
ZAYED,,
Old 04-17-2013, 04:02 PM
Originally Posted by cm60k
Yes Sure,,
Attachment 257481
ZAYED,,
thanx for your help.
found this on german ebay, seems like MB put new labels on their bottles?
http://www.ebay.de/itm/7-Liter-Origi...item3a7fa75618
I assume it's enuff with 7 liters to change the oil in trans and torque converter?
btw?
the same oil seen in your attached picture can it be used for power steering aswell?
Old 04-17-2013, 04:22 PM
cm60k's Avatar
Good find, i didn't see that label either...!!,
Yes, this oil can be used in P/S as well...
ZAYED,,
Old 04-17-2013, 06:48 PM
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I use Fuchs Titan ATF 3353 Dexron III buying the stuff in 20lt drums like for Mobil1 for the M113 engine
About Fuchs TITAN ATF 3353 Automatic Transmission Fluid
Multifunctional DEXRON III Generation ATF for automatic transmissions as well as any other ATF-applications. Developed for the latest generation of Mercedes-Benz 7-speed automatic transmissions (NAG 2), applicable as well for the preceding 5-speed automatic transmissions (NAG 1). Offers fuel-efficiency potential.
TITAN ATF 3353 has been developed to satisfy highest demands to shifting comfort in modern automatic transmissions by Mercedes-Benz. TITAN ATF 3353 is formulated with selected high quality base oils in combination with a specially developed, unique additive technology. Demanding quality control ensures constant product performance.
TITAN ATF 3353 is specially recommended for the latest generation of Mercedes Benz 7-speed automatic gearboxes (NAG 2), as well as for all former 5-speed transmissions (NAG 1). TITAN ATF 3353 can also be used in many applications where DEXRON III-type fluids are recommended.
Found this interesting article and How to in another forum: http://www.pelicanparts.com/techarti...uid_Change.htm
Also found the official MB operating fluids table: http://bevo.mercedes-benz.com/bevoli...ets-sort1.html
Rate This Thread
Rate This Thread:
Quick Reply: Is this correct ATF oil for 722.631 transmission?
