2009 ML320 Bluetec dead this morning
Old 04-13-2013, 10:08 AM
seaeric's Avatar
2003 E 320, 2005 ML 350, 2009 ML 320 bluetec 2008 E350 Wagon
I have owned this vehicle for 2 months. No problems until today. I went to start the engine and when I turned the key to on, the instrument cluster started flashing and nothing else would happen. Engine will not crank. When I turn it back off and take the key out, there is a "flashing" noise and the 4 way flasher red triangle pulses. Door will not lock, tail gate will not open.
I had to go to work this morning so I got in another car and left it. It was still making the noise when I left, although it was not as loud.
When I pulled in my garage shut the car off last evening I noticed a similar pulsing sound that the car was making after I shut it off. I also noticed a "hot" smell in the garage.
Any ideas on what's up?
Old 04-13-2013, 11:07 AM
vegeta's Avatar
06 SLK55, 22 EQS450
Not sure what the problem could be, but I would at least disconnect the battery because at least that should help stop whatever is running. Then, after a few minutes, reconnect the battery. I'm not saying this will fix the problem, but hopefully it'll prevent possibly something else from going wrong.
Old 04-13-2013, 05:22 PM
seaeric's Avatar
I'd like to push the car out of my garage. With electronic shift, how the heck do I get it into neutral to make it roll? I guess I need to read the manual....
Old 04-14-2013, 09:44 AM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
Simple start the engine and select N.
PS: There's a hole in the bucket....
Old 04-14-2013, 03:02 PM
medic's Avatar
2009 ML550
didn't he say the engine does not start? the point of the entire post...
Old 04-15-2013, 08:43 AM
seaeric's Avatar
I called MB Roadside Assistance. They have had the car towed to the dealer where I assume it will get sorted out. FYI they had to hook a hot box to the battery to get it to go into neutral.
Old 04-15-2013, 12:59 PM
meaculpa's Avatar
2007 ML350 (hers) 2001 JAGUAR VDP (his)
How old is the battery? Does it hold the charge?
Old 04-15-2013, 08:14 PM
HiTach's Avatar
E400S4 '17
This should explain...
Old 04-15-2013, 09:30 PM
seaeric's Avatar
I have owned this particular vehicle for only 2 months. Until Saturday AM, there has been absolutely no issues with starting or battery. I do not know the battery age. It may perhaps be the original. I'm awaiting the diagnosis from the dealer's shop.
I'm really disappointed by the childish behavior on this thread. I had mistakenly assumed that this was a serious forum, with mature constructive participation. Sad to see the infiltration of internet ******* that have nothing better to do, and nothing substantive to contribute. Perhaps the selection of available animations and smiley faces should have been a clue as to the culture.
Old 04-16-2013, 09:57 AM
meaculpa's Avatar
Keep us posted and do not be disappointed. Most of the people on this site are good apples
Old 04-16-2013, 11:41 AM
iankayem's Avatar
I am sorry that I popped in a joke to you seaeric, I should have noted you are a new poster. We do try and give a serious answer when we can.
As it so happens, this same question about selecting neutral has been posed before with the only recommendation that I have seen previouslyis to remove the tailshafts. And I understand that is not an easy thing to do.
But I am glad to see there is another method as used by the tow truck.
Old 04-20-2013, 10:44 AM
seaeric's Avatar
The problem was caused by a shorted out battery. New battery installed and good to go. Car is still under the original warranty so there was no cost to me.
Old 04-20-2013, 11:16 AM
meaculpa's Avatar
All's well that ends well !!!
Old 10-27-2013, 05:03 AM
SHOMP_DOMP's Avatar
ML320
2009 ML320 Battery Locations
Is there more than one battery in a 2009 ML320 BlueTec. I know one is under the passenger seat. Where would the other one be
Old 10-28-2013, 09:43 AM
iankayem's Avatar
There is a little auxillary, located next to the main battery, under the seat.
Old 07-05-2015, 09:15 PM
seaeric's Avatar
So here I am again - 26 months later. Same problem. Upon attempted start, dash flashes and then all dead. I popped the hood and attached a charger to the jump start terminals. After a few hours charging at 10 amps it started normally. So now what? Why would a 2 yr old battery fail suddenly? There was no clue that this was coming at all. Car is still under a CPO so I guess I call the dealer in the morning, or call Mercedes Roadside and have them check/replace the 2 yr old battery under warranty?
Old 07-06-2015, 10:27 PM
20swrt's Avatar
ML 320 CDI
searic - tell us if you replaced the smaller auxilliary battery.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: 2009 ML320 Bluetec dead this morning
