2002 - 2007 Mercedes-Benz C240 (203) Information
Old 04-12-2013, 08:27 PM
PeterFerreira's Avatar
2002 MB C240 (203)
Arrow 2002 - 2007 Mercedes-Benz C240 (203) Information
Hi everyone,
I had so many questions about my 2002 MB C240 when I got it that I decided to start a post with answers to questions I was having trouble finding online even here in the forum! So I'll be posting information as I can and hope it helps other new C class owners like me!
Above is an image for the engine compartment layout of a MB C Class V6 Model
1- Coolant expansion tank and pressure cap
2- Interior ventilation filter and battery access cover
3- Brake fluid reservoir access cover
4- Engine oil filler cap
5- Windshield washer fluid reservoir
6- Power steering fluid reservoir
7- Oil filter housing
8- Serpentine drive belt
RED ARROW This is where the engine oil dipstick / dipstick tube cap location on V6 engines only.
CYLINDER LOCATION ON THE V6 is:
3---6
2---5
1---4
FRONT OF VEHICLE
Photo above is also of the V6 (2002 MB C240)
A- MAF sensor
B- Electric Air Pump
C- PCV Hoses
D- Cylinder 4,5,6 Coils
E- Cylinder 1,2,3 Coils
F- Brake oil reservoir
G- ABS/ESP actuator assembly
Above is an image for the engine compartment layout of a MB C Class four-cylinder Model
2- Automatic transmission fluid filler tube
3- Engine oil dipstick tube
4- Air filter housing
5- Power steering fluid reservoir
6- Windshield washer fluid reservoir
7- Engine oil filler cap
8- Oil filter housing
CYLINDER LOCATION ON THE four-cylinder is:
4
3
2
1
FRONT OF VEHICLE
Please note that this cars DID NOT come equipped with a dipstick but you can actually buy one from the dealer
(part number 120 589 07 21 00) or aftermarket from the web. Unlike most vehicles, a dipstick is not present in the oil filler tube. My preference is the dealers dipstick even though it costs more money but it works the best in my opinion. Otherwise you can check the oil level using the multi-function display method on the instrument cluster (refer to owners manual).
CAUTION - The dipstick used for checking the oil on 2005 and earlier models is only a tool and it should never be left in the dipstick tube when the vehicle is operated. On 2006 and later the oil level is checked with a dipstick which is located on the side of the engine.
The oil level should only be checked before the car has been driven, or about 5 minutes after the engine has been shut off. If the oil is checked immediately after driving the car, some of the oil will remain in the upper part of the engine, resulting in an inaccurate reading on the dipstick and/or on the multy-function display.
BASIC TORQUE SPECIFICATIONS:
CAPACITIES & IGNITION SYSTEM
Recommended Lubricants and Fluids
Engine Oil
Type ----------API grade "certified for gasoline engines" fully synthetic.
Oil Viscosity (choice of viscosity may be determined by brand of oil.)
SAE 0W-30, 0W-40, 5W-30, 5W40, 5W-50
NOTE: Mercedes-Benz recommends Mobil-1 Synthetic.
Automatic Transmission: MB Automatic transmission fluid or equivalent.
Manual Transmission: MB Manual transmission fluid or equivalent.
Coolant: 50/50 mixture of MB 325.0 Anti corrosion/antifreeze (or equivalent) and water
Differential lubricant type:
Front differential(AWD models)
---- SAE 85W-90 hypoid gear oil
Rear differential ---- SAE 85W-90 hypoid gear oil
Brake fluid: -- DOT 4 Brake fluid
Power Steering: --- MB power steering fluid (Pentosin CHF 11S) or equivalent.
Yes... the MB C240 has 12 spark-plugs and if they look like the ones I took out of my car IT IS time to change them!
You will need:
Four cylinder engine:
2002 models.........................NGK IFR6D10 or equivalent - GAP 0.039 inch (1mm)
2003 and later models............Bosh M6MPP332 or equivalent - GAP 0.031 inch (0.8mm)
V6 Engine:
2002 and earlier models...............Bosh F8DPER or equivalent - GAP 0.039 inch (1mm)
2003 through 2005 models...........Bosh F8DPP332 or equivalent -GAP 0.039 inch (1mm)
2006 and later models.................Bosh Platinum Y7MPP33 - GAP 0.031 inch (0.8mm)
FIRING ORDER:
4 cylinder engines - 1,3,4,2
V6 Engines - 1,4,3,6,2,5
NOTE: I will be updating this post as I can and will also be adding photos as I do this things on my car. Stay posted!
DISCLAIMER: I am not a mechanic, I am a professional violinist! But I am what you would consider a D0-It-Yourself believer. All the information contained here is provided from research I have done in order to work on my own car and save the money so I can spend it on violin strings instead! USE IT AT YOUR OWN RISK
Who knows maybe they will make this a permanent link/sticky?
Old 04-13-2013, 01:34 AM
phister's Avatar
06 C230 SS 6spd
you can ask glyn and the other moderators to attach it to the wiki at the very top.
Old 04-13-2013, 01:36 AM
phister's Avatar
06 C230 SS 6spd
most of the content and actual procedures on how to do the work is here in the wiki plus the approved mb oils and fluids to use. also they have pdf formats of the owners and service manuals.
Many "newbies" dont know that there is a WIKI link at the very top of the site that has a lot of technical and informative pages. Plus it has a lot of the shop manuals on removing and installing the basic things straight from the MB service cd.
https://mbworld.org/wiki/index.php/W203
Old 01-12-2014, 12:41 PM
centuryplace's Avatar
e320, c240,c230
nice ride
Old 01-19-2014, 05:48 PM
yuloa1's Avatar
C240 wagon
Does this windshield water system has a fuse? I thought the pump is broken so I got one and installed. It is not working, not to say any noise. So I think it might be something else?
Could any one help? Thanks.
Old 01-19-2014, 08:34 PM
Super Moderator
samaritrey's Avatar
THE C350
Check your fuse map I think it is listed. I believe it is controlled by the front sam
Old 01-20-2014, 11:18 AM
corkshoppe's Avatar
13's550/2000's430/13'gl63/'13's550/10's63
all this information is on here already, but thanks for the pictures.
Old 01-21-2014, 03:07 PM
yuloa1's Avatar
C240 wagon
do not buy water pump yet
I search around the previous message left in this website and found that I am also a victim of common knowledge. The windshield water spray of a Mercedes C240 is different from the U.S. made. When you press the stalk slightly, the wiper moves only. You have to press the stalk harder to 2nd stage, the the spray is activated.
My pump did not broken, so now I have a spare pump.
Thanks to everyone here.
Old 01-21-2014, 05:16 PM
VVF
VVF's Avatar
2005 C230K(sold), Mk7 Jetta
yuloa, it works the same way in the US models.
Rate This Thread
Rate This Thread:
Quick Reply: 2002 - 2007 Mercedes-Benz C240 (203) Information
