06 C55 Amg Reliability w/ 60k Miles?
Old 01-09-2013, 04:53 PM
kylegangsta's Avatar
2009 C300
Im sure there's hundreds of posts on this but I'm thinking of purchasing a 06 c55 but i was curious about the reliability of these cars? From what i hear they generally dont have very many problems and keeping up with maintenance should be a breeze.
Old 01-09-2013, 05:39 PM
crazeazn's Avatar
C55
pretty problem free.. i had maf go out and thats pretty much it.
Old 01-09-2013, 06:34 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
I bought my 06 back in june with 58k and its got almost 67k on it now and no problems...the oil use is a bit annoying but whatever
Old 01-09-2013, 06:42 PM
crazeazn's Avatar
C55
oh and seat heater..but thats a w203 problem.
Old 01-10-2013, 03:55 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
the PO mentioned the seat heater. said he went through two and just gave up. my car has under 50k and the seat bottom wont heat. And the rear window shade is stuck up. and i still havent gotten around to fixing the SOS Teleaid warning light...
little things
Old 01-10-2013, 04:16 PM
Capn's Avatar
03' CL600
Secondary Air Pump can be an issue.
Old 01-11-2013, 01:08 AM
arekux's Avatar
2006 C55 AMG
C55 pretty reliable, around 60k you should check valve cover for oil leaks, check all the fluids brakes, coolant, tranny oil, only thing expensive on my c55 is tires and oil....
Old 01-11-2013, 02:02 AM
ruben65's Avatar
Motor mounts, and transmission mounts tend to go out every 30k-40k miles approx... I been through 2 sets on my car. Other then that easy maintence. Just keep the fluids current and your good.
Old 01-11-2013, 05:13 AM
aussie e55's Avatar
2009 C 63
bought at 40 Km, selling at 80 Km. replaced 2 engine mounts/ 1 idler pulley/ 1 stepper motor/1 susp. bush /
Old 01-11-2013, 10:12 AM
speed7's Avatar
07 E63 Estate | 09 & 10 Rx8 R3
C55's are tanks. Don't hesitate, buy the car. I bought mine at 52k miles... we're up to 98k now. Issues minor and just regular maintenance. If I had the extra cash I'd have two of these guys.
Old 01-11-2013, 12:15 PM
biturbowagon's Avatar
06 C55 AMG
Bought at 90, have 99k. No issues at all. car rides fine! Just regular maint is best. I check oil weekly and coolant weekly.
Although, mine was maintained very well at dealership.
Old 01-11-2013, 12:33 PM
MBNiko's Avatar
2006 C55 AMG
I put on 20k miles in 7 months and it handled it like a champ. They are tanks, indeed. Just make sure to do a tranny flush if it has not been done, check your valve cover gaskets for leaks and motor mounts.
Old 01-11-2013, 02:28 PM
ghiaguy's Avatar
+1 on valve covers leaking and motor mounts. I think mine was driven pretty hard though by the original owner. Still a reliable car, as these things are not going to put you on the side of the road unless you let them get out of hand.
Old 01-13-2013, 02:06 AM
speed7's Avatar
yeah second on the valve cover gaskets.. but really that's a small issue.
So where are the pics of this new C55 you bought? =)
Old 01-14-2013, 02:49 PM
ghiaguy's Avatar
C55s are also reliable at embarrassing M3s and S4s
Old 01-14-2013, 02:54 PM
arekux's Avatar
2006 C55 AMG
2nd that, m3s are scared now my car sounds little angry now.. Not really a sleeper anymore...
Old 01-15-2013, 03:21 PM
AMG3.2's Avatar
C63 AMG, P30
60k miles? I'd start parting out the car to get my money back. These things blow at like 40k.
In all seriousness, you'll have no problems at 60k. (hopefully)
Old 01-15-2013, 03:39 PM
ghiaguy's Avatar
Keep us posted on whether you have taken the AMG plunge!
Old 01-16-2013, 11:31 PM
mikekuriger's Avatar
2010 C63
still running strong at 180,000 miles
Old 01-17-2013, 12:22 AM
pointman's Avatar
a car that can't do the throttle reset.
Man, that makes me feel good about the future with my 32.
Old 01-17-2013, 06:57 AM
F1Bobby's Avatar
Location: People's Republic of California (Southern Region)
C55 AMG, CLK550
I've had mine a few years now and so far its been bulletproof!
Old 01-17-2013, 05:14 PM
Tump43's Avatar
2014 E350 4Matic
I'm a fanatic and drive my car very hard and all is good at 120k miles. Regular maintence like everyone said. I too have given up on my driver's side seat heater after two replacements. Also replaced the plastic donut on the steering wheel height adjustment motor twice (common) and do not now adjust my steering wheel more than once a year. Motor mounts every 40 to 50k., tranny fluid & filter change every 40-50k, change your differential oil every 50k. I had to have my secondary air pump rebuilt ($125 & 3 days with a guy from ebay). Plugs and wires should be changed every 50k. Check valve cover gaskets. Mine went at 60k but have been good since. Tranny mounts, and the seal between the tranny electrical connector and the shifter box are suspect and should be changed. I had my rear seal (t'wn engine and tranny) done at 75k. The alternator regulator (brushes) should be changed at about 60-75k. The crank position sensor and maf as needed (about every 75k). I do the oil and filter every 5k miles with Mobile 1 0W40 or 5W40 M formula. Some do their oil every 7.5k miles or 10k miles without trouble. Oh and I had to replace my radiator at 100k since the plastic to metal connection separated and I had to replace two stepper motors (auto climate control motor that control the internal flaps) -- the last two repairs, however, are not usual.
Old 01-19-2013, 01:18 AM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
It’s very encouraging to hear how robust these cars are proving to be. They seem to be able to handle a lot of punishement too – from road course and autocross action to the dragstip. Personally, the only real problems I’ve encountered are with the valve cover gaskets leaking (replaced twice) – not a huge deal. As a preventative measure, I’ll probably look at replacing the crank position sensor and voltage regulator in the future.
Quick Reply: 06 C55 Amg Reliability w/ 60k Miles?
