CPS - "Crankshaft Position Sensor" Discussion Thread
Rating: Thread Rating: 6 votes, 4.33 average.
Old 01-22-2006, 08:43 PM
mleskovar's Avatar
'17 Jaguar XF
Courtesy of KarlBenz: "Replacement of L5 (crankshaft position sensor) is relatively easy with proper tools 1/4' 12 inch extension with flex socket on end connected to another 3" short extension and the proper socket,simply remove air cleaner assembly and with enough light to follow/see wire behind left cylinder head remove/loosen bolt holding L5 in place reinstalling by placing grease/white lube on bolt installing in sensor and then tightening down Note that on removal a long magnet might aid in retrieving of small bolt that could fall into abyss on engine Its a simple 15 minute change"
https://mbworld.org/forums/mercedes-tech-talk/132060-problem-starting-2000-s500-need-expertise-mb-tech.html
Old 01-22-2006, 09:31 PM
LowCaliTi's Avatar
Audi 225 TT.w203 sedan.Bmw 318tiCali.Ed.VW Jetta vr6
thanks !!
Old 01-23-2006, 10:38 AM
LowCaliTi's Avatar
Question CPS replacement
Just got quoted $300 for CPS installed, and a hook up to the diagnostic to check everything else. good price??? dealer cost for CPS was $110.25
Old 01-23-2006, 07:28 PM
white_w203's Avatar
is SOLD
what's a CPS???
Old 01-23-2006, 10:40 PM
  #30
LowCaliTi's Avatar
Crankshaft/camshaft Position Sensor
Old 01-23-2006, 11:26 PM
  #31
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
Not covered under warranty? Most cars that is on the transmission. If you think that is a bit much go to a good private shop. But assuming ~$90/hr labor rate, 2 hours could sound about right depending on where it is mounted. Some cars it is mounted on top of the tranny and either requires a special to to get it out or dropping the tranny to get to it (My Jeep was like that) or a person with 2 elbows. Some other cars it is mounted on the side and can be easily reached, in which case 2 hours is a bit much. If you can find out where the CPS is.
Old 02-14-2006, 11:07 PM
  #32
krew944's Avatar
somethings really wrong....please help...
i drive a 2001 c240.
i was driving one day and the car just shut off... for some odd reason. i looked at the car and it seem to be ok. i tryed starting it and it started... the check engine light was on....
in a while the engine light went off
a week later this happened again...
but this time i had trouble starting the car again...i had to move the car out of the way and than 5 minutes later i was able to start the car again. and the check engine light was on once again.... and it went away again in a while..
i drove the car to my dads auto shop. and parked it there because he wanted to take a look at it. he looked at it and it seem fine.
so now i left my car with my father for two more days.
as he was driving around it shut off again....once again the same thing happen?
i was wondering if anyone know what this is?
i really confuse and have no idea what it might be
is it because i drive it on W instead of S because thats the only thing i remmeberr changing on my car.
please help me ...
thank you
Old 02-14-2006, 11:23 PM
  #33
e1000's Avatar
a quarter mile at a time
call roadside assistance
Old 02-15-2006, 12:06 AM
  #34
krew944's Avatar
what is roadside assistance and how do i located them?
Old 02-15-2006, 12:09 AM
  #35
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Pull down your visor and see what you find.
  #36
MBworld Guru
FrankW's Avatar
white and whiter
sounds like the same thing that happened to my sister's 00 CLK320. I might need to dig up the service record tho. I can't remember what the dealer have changed from fixing the problem.
Old 02-15-2006, 01:16 AM
  #37
Moviela's Avatar
Exclamation Roadside Assistance Spiel
Roadside Assistance
1-800-FOR-MERCEDES (1-800-367-6372)
Throughout the life of your Mercedes-Benz, a Roadside Assistance expert is just a toll-free call away. Call 1-800-FOR-MERCEDES (1-800-367-6372) for assistance any time you're on the road, day or night, if you have a problem related to your Mercedes-Benz.
If you ever need assistance while traveling in your Mercedes-Benz, just call 1-800-FOR-MERCEDES (1-800-367-6372) for our 24-Hour Roadside Assistance. Our Roadside Assistance Experts know Mercedes-Benz automobiles, and they're well prepared to handle unforeseen roadside complications. And here's a reassuring fact: Every Mercedes-Benz in the U.S. - no matter how old, how many miles it's logged or how many owners it's had - qualifies for Roadside Assistance, 24 hours a day, 365 days a year.
Roadside Assistance repairs could involve charges for services and parts. Depending on the circumstances, an outside service may provide Roadside Assistance repairs at the discretion of Mercedes-Benz USA LLC.
Old 02-16-2006, 01:35 AM
  #38
krew944's Avatar
what do you guys think i should do now...
im still driving it whenever i have to and it didnt shut off again yet...
should i just take it to the dealer or call roadside assistance/?
i dont even know what to do..
im afraid to drive my car
Old 02-16-2006, 01:40 AM
  #39
MBworld Guru
FrankW's Avatar
white and whiter
take it to the dealership...it was just some sensors.
Old 02-16-2006, 03:51 AM
  #40
krew944's Avatar
do you know which sensor it was...i just want to make sure the dealership dont try to rip me off. i want tell them straight up so i can see if thats the problem.
thanks
Old 02-16-2006, 04:01 AM
  #41
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Originally Posted by Moviela
Roadside Assistance
Yeah, just be careful, I found out the hard way that the towing isn't free after the warranty period expires. Even though I have the 100,000 warranty, the extended one doesn't even cover towing anymore. I should have called AAA since I pay anyway but in the end the tow cost me $250.
Erik
Old 02-16-2006, 04:04 AM
  #42
krew944's Avatar
i dont have warranty on my car anymore... so how much would this sensor cost to fix?
Old 02-16-2006, 06:42 AM
  #43
BruNo's Avatar
07' ML350
hmmm my guess would be a MAF=MASS AIRFLOW SENSOR?????
Old 02-16-2006, 11:29 AM
  #44
Justinius7's Avatar
my guess is the fuel pump... had the exact same issue with myML320... it made 3 trips to the dealer before they figured it out, becuase it was very sparatic. it would usually always start by the time the tow truck would arrive. BUT one day... never started.
Old 02-16-2006, 01:44 PM
  #45
krew944's Avatar
should i just ask them to check those things out first before anything or just let them figure it out?
Old 02-16-2006, 01:50 PM
  #46
Justinius7's Avatar
1/2 the problem will be... if they can not "re-create" the problem, they will just charge you labor and say nothing is wrong with it. THE MAF sensor... a computer will tell them that it had a failure... the fuel pump... well the first 2 times the ML went in... they kept telling me that i was not putting the FUEL CAP on tightly... as that was the error the computer fed.
Old 02-16-2006, 01:52 PM
  #47
krew944's Avatar
alright thanks..ima see if its that problem...hopefully it is ...if not than i dont even know what to do...
Old 02-16-2006, 05:11 PM
  #48
zishan03's Avatar
My dad had a similar problem on his 00' CLK320 and it was the crankshaft position sensor heating up and causing the engine to not turn over, but if you waited for a while till it cooled down it would start again!!
Old 02-17-2006, 07:33 PM
  #49
krew944's Avatar
thanks everyone for there help. i brought it to a mercedes repair shop and they fixed it. it was the crank sensor which was broken. replaced it and now my car is perfect once again. with my new rims.
Old 03-15-2006, 12:02 AM
  #50
rhokat's Avatar
Help Needed Asap
Hello Everyone out there!!!! Please help me!!! I have a piece of crap 01 C320. Last week I could not get the darn thing to start. It just would not crank over. One day I did get it to start, but after driving it for about 100 yards it died on me. I got the check engine light and after reading the error code, I purchased a crankshaft position sensor (error code read P0335). Can someone tell me where it is located. My cars been in the shop so many times, Im tired of paying any extra labor costs. HELP ME OUT PLEASE!!!!
You have already rated this thread Rating: Thread Rating: 6 votes, 4.33 average.
Quick Reply: CPS - "Crankshaft Position Sensor" Discussion Thread
