TPMS Sensor - Where to buy them for cheap?
Old 12-04-2012, 05:56 PM
Dan5.5's Avatar
2013 GLK 350 4Matic
Hello All!
I am looking to get a winter set up for the GLK. I found good tires and rims, but i am still looking for cheap TPMS sensors? What are you guys using? What about the ford sensors that i have seen mentioned on the forums? Where are you guys buying them?
Thanks!
100Pyatt (02-12-2024)
Old 12-05-2012, 12:49 AM
JohnMichael's Avatar
2012 GLK 4Matic, 1999 S600, 1994 E320 Cabriolet
TPMS
This was the cheapest I found for original equipment ones:
https://www.tpmsdirect.com/
Don't get cheap ebay ones made in China - you get what you pay for so if they don't work right you saved nothing by buying inferior knock offs.
Old 01-22-2013, 12:20 PM
packardbell's Avatar
civic corrado glk
i was thinking of getting some from fleabay
Old 03-08-2013, 10:35 AM
RavenMDX's Avatar
2009 C300 4Matic Sport + Premium 2
http://www.ebay.com/itm/121074609207
$89.95 for 4 new benz tpms sensors (includes batteries)
The guy said they need to be programmed to the car..huh? I thought since they are 433mhz that they would work automatically? some members on this board said there's nothing to do, car will detect them. I would like a confirmation on this.
Old 03-08-2013, 12:18 PM
Automatic
Car does it automatically and I think you can re set before you start driving after installing new ones
Old 03-08-2013, 12:20 PM
RavenMDX's Avatar
Indeed that's what I just heard as well, you can reset in the cluster menus and drive about 5-10 miles and it will detect them
Old 03-09-2013, 12:38 PM
JDoggery's Avatar
Designo AMG
I think those are 433.92mhz. I'm looking for the 315mhz for an 04 S.
Which would be better the BERU RDE004 or SIEMENS/VDO?
Anyone have a good place to buy these? Seems like I can find the 433.92mhz for around 100 for a set whereas the 315mhz are 100 each?
Also, anyone have OEM part numbers?
Thanks.
Old 03-09-2013, 05:41 PM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
I may be mistaken, however by noting your location I think your objective is to install TPMS sensors on a Canadian delivered (?) MB. If so, I take it you are aware of the distinction between the (Canadian) Tire Pressure Loss Warning System and the Tire Pressure Monitoring System?
Old 03-09-2013, 05:42 PM
GLKKa2H's Avatar
Originally Posted by JDoggery
- Also, anyone have OEM part numbers?
Thanks.
A0045429818.
Old 03-10-2013, 08:26 PM
georgia10's Avatar
2010 4MATIC
Just found these, hope this helps someone in the future, I'm ordering a complete set for a winter set of wheels...
http://www.titantpms.com/tpms/merced...lass-2010-2011
Old 10-31-2015, 11:48 AM
mogulman's Avatar
2013 GLK350
Sorry to revive this old thread, but trying to find TPMS for some winter wheels for a 2013 GLK350 4Matic.
Anyone know the OEM part#?
Are there different parts depending on when the car was made? Seems like some sites have the TPMS a 433Mhz, and some as 315Mhz....
Old 11-05-2015, 03:13 PM
mogulman's Avatar
2013 GLK350
FYI.. for my 2013 GLK 4Matic, the ID for the TPMS was A0035400217.
Looks like Schrader makes an replacement sensor also. Ordered...so we'll see how it works.
Old 11-05-2015, 03:46 PM
GLK350AMG's Avatar
2013 GLK350 4-Matic & 2003 E320
I read somewhere that Costco sells them for cheap too. Don't know if it is OEM or not.
Old 11-13-2015, 09:33 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Tire Rack sells the TPMS made by the same company as the OEM- Schrader I believe.
Old 11-15-2015, 12:59 AM
rocketd55's Avatar
GLK
Originally Posted by Dan5.5
Hello All!
Thanks!
Do not buy the ones from Titan TPMS. I bought 4 of them last year for a winter set of rims and tires. The Titans were substantially lower priced than the OEM Schraders. PepBoys installed them for me.
The Titan TPMS ones do not relay the actual tire pressures back to the computer system on the GLK. Therefore, it only tells you if they are inflated or not. It'll just read "TPMS active". I had this tested.
With that said, I had to return the Titan TPMS ones. The company Titan TPMS were fantastic about the whole thing and did refund my money, in addition to pay for new OEM sensors and the replacement labor. But it did cost me hassle and two trips to PepBoys.
Old 12-10-2015, 07:12 PM
mogulman's Avatar
2013 GLK350
I ended up getting OEM Schraders from ebay. They were $80 for 4. Unfortunately the stems were a little too short for the wheels that I had.
http://www.ebay.com/itm/171386087367
I ended up having to get a Schrader rebuild kit 20020ak (20020 20013) and using some of the parts to make them work. $20.
Works now. The Schrader valves transmit individual pressure to each sensor.
Old 07-28-2023, 09:38 PM
CERNICALO1's Avatar
2015 GLK350
Exclamation GLK350 Inexpensive TPMS Sensors - No Programming Required
I have just installed the SEINECA brand TPMS sensors (SKU: BBC009-4-SA-OLT) on my 2015 GLK, and I can confirm the vehicle recognized and learned the 4 new sensors within a few miles of driving, without any input from me whatsoever.
Amazon link below - $45 for set of 4
Amazon Amazon
The following 2 users liked this post by CERNICALO1:
andreigbs (07-31-2023), Roadrashed (07-29-2023)
Old 07-29-2023, 09:40 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Interesting. Their fitment information is very confusing! As far as I can tell, the only GLK250 it fits is the 2013 model year... (I think)
Old 07-29-2023, 10:17 AM
CERNICALO1's Avatar
2015 GLK350
Correct! In fact, I noticed it says it will NOT "fit" in a GLK350, but it did, and it worked as I mentioned before....hence my posting here so others can benefit
John CC (07-29-2023)
Old 07-29-2023, 12:23 PM
habbyguy's Avatar
2011 GLK 350 4Matic
FWIW,
these are the ones I bought these are the ones I bought
($80 for four from Amazon). The description (for when the link expires): "MORESENSOR Compact PRO Series 433MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 850+ European/American Brand Models | Replacement for 56029398AA | Clamp-in | KX-S033-4"
I did a fair amount of research, and wanted some that were likely to last more than 5 years before requiring replacement, and that would auto-install. Add $60 at Discount Tire to install them and rebalance the tires (due to possible difference in the weight of the old and new sensors). They auto-configured, and have been working like a champ.
The following 2 users liked this post by habbyguy:
andreigbs (07-31-2023), Roadrashed (07-30-2023)
Quick Reply: TPMS Sensor - Where to buy them for cheap?
