key won't turn in ignition???
Old 07-21-2003, 03:19 PM
Almost a Member!
joboo's Avatar
The other night my key would not turn in the ignition. I had to get the baby towed to the dealer. How embaressing!! Anyways, is this common problem? I was told it was the ignition lock tumbler. Does this sound right and is this expensive?
Old 07-21-2003, 04:17 PM
Eurosport's Avatar
monowiper
are you sure you didn't lock your steering wheel?
Old 07-23-2003, 04:58 AM
DMXtremeZ's Avatar
2013 Audi S4
or how about checking if you were completely in the park gear...
chances are you probably tried everything as well as the tow truck driver
Old 07-23-2003, 05:11 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
i seem to remember the key won't start the engine again if it's left in place after turning it off...u'd have to remove it and reinsert it to restart engine...but that's probably not ur case...
Old 07-23-2003, 07:57 PM
DMXtremeZ's Avatar
2013 Audi S4
yeah that too...
i had a similar problem a couple weekends ago... i checked the terminals and just put a little gas before turning the ignition and it started after like 20 tries...it was pretty random
Old 07-28-2003, 02:06 AM
BrabusCClass's Avatar
GL450, Sienna SE
Hmm. I have never had that problem. Knock on wood.
Old 07-28-2003, 02:18 AM
tpliquid's Avatar
C63, GT3RS, 430 Scud, E63, CGT
try a diff car...
Old 07-23-2008, 04:18 PM
PAK9's Avatar
C43 AMG and 911 Type 993
I'm experiencing this problem right now.
It's not the steering wheel, park, or brake pedal.
It seems that if the remote doesn't transmit via LED/infrared, the electric ignition lock mechanism doesn't disengage.
I also changed the remote's batteries and cleaned the internal contacts.
Has anyone seen this, too?
Old 07-23-2008, 05:11 PM
amgv8's Avatar
2003 CL55AMG, 2020 GLB250W4, 2020 SLC300
Had this over the weekend when I realized I left the C43 key in my bathing suit and went in the pool. ! It fell to the bottom of the pool...
The key would unlock all the doors, but would not turn in the ignition.
Removed the mechanical key, then removed the the top of the key, that has the little battery tray, and used an electric hair dryer to blow out the water and really dry it out good.
Worked fine after that.
Old 07-23-2008, 06:04 PM
PAK9's Avatar
Yeah - I took mine completely apart (even the battery tray) except for the circuitboard inside.
I might get some tweezers and pull it out for a good cleaning.
Seems intermittant right now. Inop more often than operational.
Old 09-15-2008, 09:26 PM
w202305's Avatar
c230 kompressor 1999
i had the same problem got home one night and the next day the car didn't want to star i try everything i was trying things for 2 days after that i just when to the dealer and got a new key
Old 09-15-2008, 10:34 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
happened a few months ago to a kids camry. was stuck in my driveway for 2 days. got towed and had to get a new ignition. it was only like 250 but thats a camry
Old 09-16-2008, 02:51 AM
bagelsjustbagel's Avatar
In search of W222
my infared doesnt work
i replaced the fuse.
nothign hapened
i tried to re-sync it.
nothing
Old 09-16-2008, 11:24 AM
Z06EATER's Avatar
1997 C36AMG
i gota take alook at ur car dude...it should work, mine works...is the sensor on your drivers door broken? like the plastic covering broke off?
Old 09-16-2008, 01:55 PM
In search of W222
yeah its broken
Quick Reply: key won't turn in ignition???
