Wiring diagram for lights?
Old 09-06-2012, 09:29 AM
TechSuperstar's Avatar
15' CLS400
Recent problem: The passenger front side marker light went out. Tried new bulbs but doesn't seem to have any power. Anyone have a diagram or know where the wires go from there? I'm going to check the wires themselves first in case the light socket is bad but I doubt that.
Old 09-06-2012, 09:50 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Actually, it's very common for the socket to go bad - the bulb gets hot and melts it. It can even melt the plastic lens housing.
Old 09-07-2012, 03:21 AM
Super Moderator
Glyn M Ruck's Avatar
+1^
They all power from the front SAM. Some with electronic protection/control & some fused ~ low beam only I think fused. All the rest electronic.
See your fuse diagram
Old 09-07-2012, 11:15 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
It's also very easy to manually trace the wire. Half the wiring for the front lights looks like it was added aftermarket, so much of it is exposed.
Old 09-08-2012, 03:10 AM
Super Moderator
+1^ again! The standard Schematic on that harness is of no help. I does not show routing.
Old 09-09-2012, 07:42 PM
15' CLS400
Thanks! It was the socket. Didn't see anything melted but the metal clips that clamp onto the wire which the bulb plugs into was all corroded. That was probably the problem. Anyway, $10 later I have a new socket and a working light.
A $10 problem beats a bigger problem anyday!
Old 09-10-2012, 09:27 AM
Super Moderator
Huh! Good news!
Quick Reply: Wiring diagram for lights?
