E-Class (W211) 2003-2009
W211: Glove box light is out. Any ideas?
Old 08-31-2012, 08:32 PM
JayDee4711's Avatar
2003 CLK430 Cabrio, 2009 BMW 535 iX Wagon
Question W211: Glove box light is out. Any ideas?
I tried putting an LED bulb in the glove box and must have caused a short. Now the light won't come on anymore, neither with the LED, nor the original bulb. The bulb is OK, and so is the fuse. We are talking darkness and ignition on.
I found a couple threads that said the glove box light is under the control of one of the many black boxes. Makes sense if it senses daylight or darkness. Does anyone have an idea what can be done here? Any more details?
Thanks in advance!
Old 09-24-2012, 05:01 PM
JayDee4711's Avatar
Any ideas?
Old 09-27-2012, 12:35 PM
Long Islander's Avatar
2018 E400 4matic Wagon
Thanks in advance!
I would put a volt meter across the contacts for the glove box light and see what it reads. If you're getting proper voltage, check the contacts to make sure they're actually making contact with the bulb. I removed and reinstalled a bulb in my hatchback and noticed that there was something wrong with the contacts when the bulb would no longer light up. So I had to bend the contacts back to make sure they touched. Also, I noticed that some interior lights don't light up when the car is parked outside in daylight (light sensor somewhere). Are you checking in a dark garage?
Old 09-27-2012, 02:09 PM
starbrite's Avatar
2004 E320
+1, what oggie said
Old 09-29-2012, 04:45 PM
BTW, my glove compartment lamp only lights when the ignition is turned to the "On" position (not just the "Accessory" position).
Old 03-08-2014, 07:00 PM
sthoms's Avatar
2004 AMG E55, 2011 Ram 2500 6.7L
Also note, if the bulb isn't present when the car it turn "On", the system will disconnect it. At least that is what I have observed trying to do the same to the license plate lights.
Old 03-08-2014, 09:40 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
The glove box light seems to simply follow the ignition without other intervention.
The switch a funky mechanical piece and could have been broken playing with the bulbs.
Quick Reply: W211: Glove box light is out. Any ideas?
