chirping noise coming frm the engine bay
Old 08-29-2012, 01:31 AM
pogijeffrey's Avatar
05 c230 kompressor
hey guys today was a totally hot day i may. well that being said i have my ac on full blast. as i was pulling out of the parking lot, i hear this really loud chirping rattling noise coming from the engine bay. only problem is you only hear it when i put the car in gear. forward or back... but when i drive off, you dont hear it. only when ur at a stop and about to take off that noise happens. my ac blows fine, no engine light. the car drives fine, the car shifts fine. no signs of failure in any type of performance. just only at the initial take when pressing the gas, you here this loud rattling shirping noise. when i put the car in gear with the brakes on, the car makes that loud noise. i'll try to record it and have it posted soon. just hoping if anybody had this problem im describing. im afraid it may get worse. so i plan to take it to the shop this weekend.
Old 08-29-2012, 10:36 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Could be the compressor making noise, could be the pulley, both are not all that uncommon.
Old 08-29-2012, 11:50 AM
05 c230 kompressor
Thanks lil Benz. I hear it more when I turn my ac on and put the car in gear. U think that's related?
Old 08-29-2012, 01:11 PM
LILBENZ230's Avatar
Likely A/C related, yes
Old 08-29-2012, 02:21 PM
mleskovar's Avatar
'17 Jaguar XF
Common noise a slipping belt makes.
Old 08-29-2012, 06:26 PM
05 c230 kompressor
Slipping belt.? Is a belt replacement that I need or more than just that? I'm being told that it could be an ac mount that needs replacing...
Old 08-29-2012, 08:10 PM
ncmudbug's Avatar
2005 C230K, 2016 Honda CR-V, '74 Lotus Europa
The spag bearing going out makes a similar noise (ask me how I know). I would make sure of what it is soon. If it is the spag bearing, it could be expensive.
Old 08-29-2012, 08:30 PM
04mbc230's Avatar
2006 C230 Sedan
How you know?
Old 08-29-2012, 10:25 PM
05 c230 kompressor
A spag bearing? What the f!!!! Is it the labor that's costly?
Old 08-29-2012, 11:05 PM
ncmudbug's Avatar
I had my A/C compressor go out on me (less than a year after it was replaced). Before I took it to the stealer, I took it to Best Buy where they had just installed my head unit. I figured they had screwed up. When they couldn't find the problem and were driving it out of the bay, it chirp like a loose belt or tires rubbing against on a rubber floor. Then I took it to the stealer because I wasn't convinced Best Buy didn't screw up but then I thought it could also be the compressor which was still under warranty. It turned out that the sprag bearing took out the A/C compressor.
I don't know if the chirping is the death knell or if it still can be saved, but I have a new respect for that sound!
(how was the popcorn?)
Old 08-29-2012, 11:07 PM
ncmudbug's Avatar
It's the A/C compressor that's costly.
I don't want anybody to misunderstand and think that hearing that chirping sound absolutely means you are at risk of losing you A/C compressor, but it's not a sound to take lightly. I suspect that a slipping belt is probably fairly rare since there is a belt tensioner.
Old 08-29-2012, 11:14 PM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
Sub'd.... I had the same noise just show up 3 days ago in my W211 E55. I am going to make a thread on it as well in the 211 AMG section. Please keep this post updated with any new findings.
Old 08-29-2012, 11:43 PM
05 c230 kompressor
will do.
just waiting for this weekend to take it in. its driveable but could be annoying at times when at a stop during idle and reversing. i really hope its not the compressor. my ac blows fine though. i hear a slight a rattle noise when i start the car and also when i step on the gas when i gear w/ the ac on. the chirping noise comes and goes, but louder during the day when its hot.
its funny how alot of us are having this chirping noise come up.
Old 08-30-2012, 11:09 AM
LILBENZ230's Avatar
The sprag bearing is why when you buy an A/C compressor it says "Please make sure the alternator pulley spins freely" etc.
Old 08-30-2012, 10:10 PM
Chase230's Avatar
2005 C230 Kompressor
Sound clip ASAP! I've got what sounds the same as your problem. And when you find out what the problem is post a quote so I know how much the repair usually runs please.
Old 08-30-2012, 10:41 PM
05 c230 kompressor
I don't know how to post a sound clip. Someone show me please. I have an iPhone I could use
Old 08-30-2012, 11:11 PM
05 c230 kompressor
here you go.
its louder during hot days...
https://www.youtube.com/watch?v=SRsn...&feature=g-upl
Old 08-31-2012, 01:11 AM
nizzle's Avatar
Oh wow. My sound is totally different and not near as loud. Interesting
Old 08-31-2012, 01:18 AM
05 c230 kompressor
anybody know what it is?
Old 08-31-2012, 03:57 AM
cextolauren's Avatar
bmw
Old 08-31-2012, 12:03 PM
LILBENZ230's Avatar
That clip sounds like the same failing compressor noise that plagued 04mbc230. IIRC, he replaced his water pump trying to remedy it and even thought it was the S/C.
Old 08-31-2012, 12:32 PM
ncmudbug's Avatar
I had a brief experience with the noise (I only realized what it was in retrospect), but the chirp sounded similar. I can't say that it came on gradually (fewer chirps, then more) or all at once, or really under what conditions it was more prevalent. I don't know if something rather benign could also cause (possibly the belt tensioner is going out), but I did get a deep respect for that sound. I would find out whatever it is immediately.
As I told somebody on another thread, this is not something to play around with. I would take the car to someone who knows about the potential now and happily pay if it is nothing. If it is something that's dangerous, I'd get it fixed soon - unless you don't care about your A/C compressor.
Old 09-01-2012, 04:40 PM
ChrisBrown's Avatar
2005 C240 4MATIC, 2010 ML350
I had a similar chirp. It was the pulley bearing that went on me. Common problem. Check that just so you can rule it out.
Old 09-02-2012, 01:19 AM
05 c230 kompressor
Did that cost u a lot to repair? I have to wait till Tuesday to get it checked.
Old 09-13-2012, 02:29 AM
05 c230 kompressor
So the car is finally in the shop. Just two days ago my a/c had this weird sucking noise and the blower wasnt blowing strong. just to get any air, i would have the knob set to #5. weird. So the mechanic says that i had a leak from the expansion tank hose and that may have caused the car to make that screaching noise. some plastic piece broke off from the heat is what they said. He then said i need a new water pump. Therefore i decided to just replace my belt and belt tensioner and idler at the same time. Lets just hope this fixes the problem. i'll keep you updated.
Quick Reply: chirping noise coming frm the engine bay
