resetting park brake
Old 07-29-2012, 07:57 AM
BabyBluAMG's Avatar
240 CLK
Hi
I wanna see if anyone has experienced this?? I am getting a gringing sound from my left rear wheel, took it to a garage, who said the small springs inside the wheelhub was broken & fitted new ones. But as I went to back the car out of the garage, i noticed that the red park brake light stayed on, plus the park brake pedal now had a lot more movement than before? also the grinding noise was still there (admittedly not as loud as before). Well the mechanic spent the next few hrs fiddling & has asked to return next week??
Q: after fitting these small springs, is there some kind of tensioning to be done?
thanks in advance
Old 07-29-2012, 12:14 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, the mechanic should have adjusted the parking brake. This is a two-step process. First, it uses a standard drum brake that uses a star wheel adjuster to set the shoes against the drum liner. That needs to be adjusted to where the shoes barely drag against the drum. Next, there is an adjustment on the actuator cable located under the rear seat. That needs to be adjusted to remove slack and also should be lubricated.
Old 07-29-2012, 03:17 PM
BabyBluAMG's Avatar
240 CLK
Many thanks at Rudeney, i'm meeting the mechanic tomorrow so will pass this info on & i can get my ride back to her brillliant best!!
Old 07-31-2012, 10:13 AM
BabyBluAMG's Avatar
240 CLK
Rudeney ............. You are the effin man!!!!!!! Thanks for that.
Old 07-31-2012, 10:16 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
You are welcome. I'm glad I could help. Oh, and I'm "the effin old man with no life except talking cars"
Quick Reply: resetting park brake
