e430 cat problem
Old 07-14-2012, 11:34 PM
julian14's Avatar
E 63 amg
e430 cat problem
Hi guys having problem with my old baby 2000 e430 sport(120K)/that i keep in the garage must of the time/i have notice that the car has lost power little by little to the point that you press the pedal to the metal and it lags to reach 5-6k RPM
slow as turtle than again my daily driver i cannot compare apple to oranges. but i remenber this car had more power and lately all the sudden it start misfiring/and occassion it shuts off/the CEL came on and the code was P0100 mass or volume air flow A circuit/ I went a bought a new Maf sensor at the stealership and the same BS. So got tire and took in to the local Merc Dealer
and they said that the problem is all four Catalytics are plug up/inside and it will take $1600 to replace all four of then and of course i told them NO WAY.
Not until i check with my extended family in MB world. Sorry for the long tread guys. The car runs ok one day the bad the next. What do you guys think? thank you in advance! Ohlord fill free to chime in
Old 07-15-2012, 08:35 AM
Figuero's Avatar
2002 E430 4MATIC
I can't imagine that your local Mercedes dealer would replace all 4 cats for $1,600. Nope - Not even if he used after market parts from BFT.
Old 07-15-2012, 08:48 AM
MBfinatic's Avatar
e36 318i, 2004 sti
I can sell you some mercedes cats for a lot cheaper! Message me!
Old 07-15-2012, 11:09 AM
julian14's Avatar
E 63 amg
sorry guys i just look at the estimate/is the front left and right cats
my mistake. is it true that magnaflow make replacements for the front cat or is it universal fit cut and weld? would that be the cheapest way out? And is it true that plug cat can cause the misfire on occ that my car has.
Old 07-15-2012, 11:26 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I would have a look at Magnaflow. Several people have had good success with their products.
Old 07-15-2012, 01:18 PM
MBfinatic's Avatar
e36 318i, 2004 sti
That could work. Ill sell my secondary cats from my C55 AMG if you want?
Old 07-15-2012, 01:35 PM
julian14's Avatar
E 63 amg
Ill let you know if i go with the Magnaflow cause my both front ARE PLUG UP/HOW MUCH YOU WANT FOR THE REAR
Old 07-16-2012, 12:12 PM
Figuero's Avatar
2002 E430 4MATIC
I'm a bit confused - If all 4 cats are bad, why did the dealer only quote replacing the front 2? Did that price include new O2 sensors?
Old 07-16-2012, 06:41 PM
julian14's Avatar
E 63 amg
no the dealer said that the front right and left were plug up and that was causing the car to misfire/rough idle. I thought the dealer had said all 4 but actually said is the 2 front one. I just got off the phone with one of the tech for Magnaflow and said that they only had replacement for the 4matic model e430
NOT the base model? has anybody replace the front one with magnaflow and if you had which model?
Quick Reply: e430 cat problem
