E-Class (W211) 2003-2009
Help! E320 jerking during acceleration
Old 07-11-2012, 12:43 PM
Jaruzel's Avatar
2006 E-Class 320 CDI Sport
Question Help! E320 jerking during acceleration
Hi All,
I've got a problem that my local Mercedes service centre can't seem to solve.
Car:
Feb '06 E320 CDI Sport
Problem:
When accelerating fairly aggressively (i.e. from standstill, or merging into traffic) the car accelerates to about 35-40mph / 3,000rpm and then suddenly starts to shudder/jerk as if I'm stamping on the brakes. If I continue to try to accelerate it will do this jerk-jerk-jerk thing several times and then slow down. At this point I cannot accelerate beyond 30 mph, and I have no kick down at all. To fix it, I have to turn the car off, and then back on again.
I've had this happen several times on fast roads, and it's quite scary when it does. However, it doesn't happen ALL the time; it seems totally random. I can go for days without it happening, and then have it happen several times in one day.
The Mercedes service centre have had a look (allegedly) and cannot find a fault - all they could offer was a recalibration of the gear box (?) which probably wouldn't fix it (their words).
Does anyone have any ideas what this might be? I've spent the past few months drilling Google for possible solutions but have come up with nothing.
Thanks in advance.
-Jar
Old 07-23-2012, 10:06 AM
E320_Benz's Avatar
E320 CDI Avantgarde Saloon
I have exactly the same problem - only happened twice - in the space of 5 days...first time, joining the motorway from a service station, under full acceleration it started to jerk violently then easing off it was ok for a little while until I realised that I couldnt get above 60mph no matter how hard i tried...the conditions were wet at the time i joined the motorway so presumed it was wheel spinning causing some clever ECU safety stuff to stop me slipping and sliding which caused the jerking...then when i had the 60mph later (30 mins later or so) I presumed that the car had cleverly turned something off..i.e. the turbo or something to save it from any damage...switching the car off and then on at the next service station seemed to cure it...then 4 days later coming out of another service station, this time with the wife and 2 kids in the car, under full acceleration it started to violently jerk again, i recognised the condition and took my foot of the accelerator and smoothly joined the motorway and the car was fine - wondering whether it just doesnt like being booted hard or more probably something is about to go and this is the first symptom? Any views?
Old 09-15-2012, 09:07 AM
Rand's Avatar
Mercedes CLK (W209) 320CDi
I have EXACTLY the same problem as Jaruzel. Although the issue is with my CLK 320 CDi
Has anyone managed to resolve this issue and, if so, how?
Rand
Old 09-15-2012, 07:05 PM
Lefix's Avatar
2003 E500
Try checking your transmission fluid level
Old 09-15-2012, 07:48 PM
Rand's Avatar
Thanks Lefix. Have you come across this issue before?
Having read other posts on the net it seems people have resolved the issue by changing the fuel filters and pumps.
Old 09-15-2012, 08:49 PM
ozusa's Avatar
2004 E320 4matic Sedan
Check transmission fluid level
+1
It is more common to happen at parking-lot speeds, but a low transmission fluid level is a known reason for shuddering. If you have never touched the transmission in the time you've owned the car, this would be a fair bet and worth doing anyway.
There are a myriad of other possibilities, too, so try getting the codes read and see if there's anything there to indicate an engine issue.
Old 09-15-2012, 09:27 PM
Lefix's Avatar
2003 E500
What happened to me was that the car would shudder/jerk when I'm slowing to a stop, the reason for this shudder/jerk is because the transmission is trying to change from 2/3/4/5 gear down to first, but with low tranny oil level, some of the mechanisms aren't covered in oil anymore and becomes rough when shifting down.
Drained the transmission oil, took the pan off, replaced the filter, new gasket, and new oil. No more shuddering/jerking ever since, and hope it'll stay that way
Old 09-16-2012, 11:05 AM
Rand's Avatar
I totally agree that transmission oil should be changed. I'll most likely get that done at my next service. Although I don't think the problem I have is related to gear change. The jerking I get when accelerating hard from start to around 40mph. Its exactly like the issues described in the original post. I am convinced it's a fuel issue.
Im having some work done on the car this week. I'll keep you all updated.
Old 09-16-2012, 08:43 PM
ozusa's Avatar
Fuel filter
I skipped the fact that you have a diesel when I suggested the transmission fluid.
Bad fuel filter (or bad fuel) is a pretty strong likelihood. Do the CDI"s have a readily-accessible filter? (I suspect they don't)
Old 10-02-2012, 07:27 AM
Jaruzel's Avatar
Angry
Ok - Update on this, and thanks for all your replies.
Put the car into the Mercedes Service Centre (again) and explained to them in detail (complete with physical demonstrations) what the issue is.
They had it for three days, on and off the computer, and then drove it around and tried to replicate it and couldn't.
So I'm still stuck with the problem. The only upside is that they didn't charge me a penny for those three days...
Regarding previous posts saying transmission fluid - does this still apply with diesel engines? (excuse my total ignorance here!) and surely they would have checked that ?
Thanks,
-Jar
Old 10-02-2012, 08:14 AM
Rand's Avatar
Since my last post my car went into "limp mode" which means there was a loss of power. Car was moving but the turbo wasn't kicking in and when I would slow down the gear would jerk. I took it to a automatic gearbox specialist who said it was the gearbox valve body. However, after reading the fault codes it seems that there is an issue with the inlet manifold flaps / motor. It is being repaired at the moment. I should have it back tomorrow. I'm hoping this might resolve the jerking issue I was experiencing to begin with.
Having read other posts on the net, it seems that the fuel filter / pump could also be to blame for the jerking at 30-40mph.
Old 10-31-2012, 06:32 AM
allbenz's Avatar
e280 w211
same problem
hi guys iv the same problem on my e280 cdi sport ,iv posted here befoore about tit but nothing realy came out of it ,,
can u please tell me how u got on so i can fix my car thanks
Old 10-31-2012, 08:06 AM
Plutoe's Avatar
1999 E300TD
If I were you I would start another post-----all the above is excess band width usage.
Additionally if you have an issue(complaint) that has not produced a fault-------then be very specific and detailed about the complaint as MANY cars are diagnosed with a clear definition of the complaint. Good Luck
Old 10-31-2012, 12:56 PM
Rand's Avatar
Hi guys
I have now had the in-let shut off motor replaced (controls the flaps) due to the car going into limp mode and error codes appearing. The car is running perfectly.
It has been around 3 weeks and I haven't experienced any jerking issues either, despite having put the car through its paces. The issue seems to have been resolved :-)
Old 11-05-2012, 05:18 PM
Danceking's Avatar
Mercedes 320 cdi
I know what the problem is
Hi all I'm new and believe I know what the problem is.
It's a common and through Mercedes an EXPENSIVE fault.
It's the turbo .. On the turbo is an ECU and that's the problem .. It needs replacing however Mercedes don't allow you to buy the unit separately so you need a new turbo with it all built in that's over £2k in parts alone and then it's a recon unit and your unit is a trade in ..
I can give you a copy of my bill.
However there is a fix
You can get the ecu repaired here
http://www.ecutesting.com/mercedes_e..._e320_tur.html
and then get a local mechanic to fit it .
I've been quoted £395 inc vat to get replacement and fitting ..
I've had 2 diagnostic tests one by specialist one by Mercedes . They updated software or something but both told me this was the fault and new turbo .
Specialist said they could fit this part at the above price.
Old 11-10-2012, 01:26 AM
ajohnfar's Avatar
2003 Mercedes E500 W211
Change your transmission fluid out, pour out the old and in with the new. Works like a charm!
Old 06-20-2013, 08:07 PM
ivan.gregg's Avatar
e320 sport
I would just like to thank Danceking for his advice on the turbo actuator. I've had this problem for the last 33000 miles despite being with the main MB dealer several times - they couldn't get to the bottom of it. Sent ECU actuator for testing last week, a fault was detected and repaired at a cost of £244. I re-installed the part 3 days ago and the problem has been completely resolved. So after trawling various forums for the last year and a half, Danceking has been the only one who has identified the problem and spoken any sense.
Old 06-20-2013, 08:53 PM
Plutoe's Avatar
1999 E300TD
The poster is correct the "turbo vane accuator motor" is not an ecu, however is also not available as a purchased part. The English repair shop sounds like an excellent alternative to a very expensive part!!
Old 09-23-2013, 04:25 PM
thewiz49's Avatar
2006 E320 CDI
I had simular problem with my 2006 E320 CDI.
During acceleration tubo would kick off, engine check light would come on.
Poor performance.
Turning car off and back on would "clear" the problem.
Changed fuel filter, problem gone.
Old 09-28-2013, 03:29 PM
Shopkeeper's Avatar
Cls 320cdi
Cls 320cdi
Hi guys, this is first post by me
I would also agree with DanceKing.
I have 2007 cls 320cdi and this very same problem has just started. I have had it with Mercedes for full check and they say it's turbo for sure and as such I'm booked in for new one 3000 euro
I think the wishfull thinking fuel filter posts are just that.
God dam turbo.
Old 09-28-2013, 06:19 PM
thewiz49's Avatar
2006 E320 CDI
Maybe in some cases Fuel Filter is wishfull thinking.
But in my case that was the problem.
It's been 18 months since change and no problems with acceleration or Turbo.
Old 11-05-2013, 04:08 AM
cafe1's Avatar
ml320cdi
God dam turbo.
Will this work also for ML320CDI? The same problem, i drive, then stop for about 10 minutes for a coffee, then drive again, and it jerks. However after the jerking and couple of minutes of drive and probably heating engine up till normal, jerking disappears and i can accelerate hard again, like nothing happened.
Old 04-06-2014, 07:49 PM
daytona77's Avatar
CLK 320Cdi (C209)
CLK 320 CDi (Euro 4 V6 C209) Engine - jerking
Hi All
My first Post from London UK.
My CLK320 CDi has done 95% motorway miles ('56 plate or 2006) and my odometer shows 256,000 miles (travelled in the UK and Europe)
1. Problems with Link Arms because of terrible London roads and potholes.
2. AIR MASS SENSOR
3. JERKING or JUDDER on "flooring the car" on a slip road onto a motorway. The car feels constipated !
The Independent Merc guys had suggested:
a) ECU or actuator "re-programme"
b) Change transmission fluid
c) Replace the AIR MASS sensor
d) Replace the turbo unit
I chose the cheapest option...
Independent Merc Garage sent the turbo brain viz; the ECU or actuator to be reprogrammed and the fix was a success. The car drove like new with huge power and fast accelleration .....amazing ....but for about 6 weeks until the same problem returned.
NEXT.....
I had also complained just after this work done of a whining noise in the engine and it revealed itself when I broke down (an embarrassment) outside Reims in France on the E17 Motorway.....freaking expensive breakdown. It turned out to be a fuel pump issue because the fuel filter was clogged and dirty.
Returning to the "constipation" issue because the car seems to jerk or shudder....I decided to carry out an oil change and fuel filter change and the car has been driving much better.
Next I will look at changing the transmission fluid and check if there are any metal pieces inside the old fluid. A specialist transmission company mechanic took my car for a spin and thought the car gearbox was sound.
Checked for fault codes with a computer and found "numerous" but the old chestnut issue of AIR MASS sensor raised its head again.
Informed that Bosch make the AIR MASS sensors for MB and probably a cheaper option and will therefore fit myself.
Finally, whilst my service intervals are every 17,000 miles or 25,000km this is only "truly possible" using the best synthetic oil such as Mobil 1 however I suggest MB drivers change the oil every 10,000 miles plus the fuel filter to optimise performance.
Also consider an oil change using MB specification (but cheaper) oil followed in 4 weeks by another oil change with Mobil1 to having flushed out all the old oil. Regular oil filter replacement and oil change is a big deal for diesel Mercs.
The MB V6 Euro 4 Diesel Engine is a beauty and I hope to exceed 300,000 miles in the next 18 months with the only limiting factor being the third party components which may fail !
I have started to learn much about my Merc but it's a joy to read everyone else's experiences here which inspired me to share mine.
Old 07-31-2014, 03:44 PM
Hedgerow's Avatar
E280 CDi Sport Tiptronic
Hedgerow
Hi, using this thread as it appears close to my problem
Car is 2007 E280 CDi Sport (7 speed auto) and it has no turbo
Only very occassionaly if I accelerate fairly hard it will suddenly start juddering and if I don't lift the accelerater quick enough the engine goes into a "limp mode" and will not go beyond 1500 revs although it will slowly accelerate through the gears. If i select a lower gear then the engine will rev up to match the speed/gear but will then drop down to 1500 revs with the car slowing.
The garage has not found any error code and have no suggestions other than to start replacing parts until it is fixed.
More recently the juddering has started to happen when the car is crawling in traffic and the engine is at around 1200-1400 revs
Any ideas?
darecarlsson (03-23-2018)
Old 07-31-2014, 04:28 PM
daytona77's Avatar
CLK 320Cdi (C209)
Hi
E280 CDi and it has no turbo? Has the turbo blown? I thought all the CDi's had turbos!
You may have a MAF or Mass Air Filter problem where the filter is dirty so the sensor misjudges the airflow and hance the "hesitation" issue. Bosch make the best MAF's but they have discontinued MAF's for my 2006 CLK 320 Cdi so you will need an OEM or an "aftermarket" manufacturer. Some MAF's are low quality and price sometimes reflects quality. You can clean the MAF but need to be careful and use carburetor cleaner and a clean cloth. Watch the Youtube videos. Unfortunately diesel Mercs suffer from this problem.
Good luck
Quick Reply: Help! E320 jerking during acceleration
