E-Class (W211) 2003-2009
MB E - Class 220 CDI (211) HELP!
Old 06-13-2012, 02:33 PM
Mrboozoo's Avatar
MB W211
Hi I own a MB 2009 (W211) E-CLASS 220 CDI
I had car trouble after MB changed dampers front on my car 2 years ago
Problem I had was that my tires are worn on the inside very quickly (front)
(have changed the front wheel bearing twice. right and left side)
I have had the car on the wheel alignment of the MB and others
But they cannot manage the problem with the front wheels
Camber bolt on the left side is changed, but not on the right
Hope someone can help me out!
Regards // Mrboozoo
Old 06-13-2012, 02:37 PM
jnash's Avatar
2017 S63
so you are saying you didn't have a problem with tire wear until AFTER front struts were changed out, or excess inside tire wear was occurring before they were?
Old 06-13-2012, 02:45 PM
Mrboozoo's Avatar
MB W211
yes that's right
after they changed it , then the problem came with the tires (front tires) only Inside
Old 06-13-2012, 02:54 PM
Mrboozoo's Avatar
MB W211
I attach a pdf file with pictures, the latest wheel alignment
it is in Swedish
Translate on the lines -
(Rear) (first measurement) (setpoints) (endpoint)
(Fron Axle) * * (first measurement) * * * * * (setpoints) * * * * * * (endpoint)*
File Type: pdf
Old 06-13-2012, 03:34 PM
jnash's Avatar
2017 S63
Looks like you have too much negative camber.
These are special camber adjustment bolts that can be ordered from your MB dealer.
Any good alignment shop should know this, they are the experts and should be able to figure this problem out.
Double check the parts numbers installed against what http://epc.startekinfo.com/epc/ states for your vin number.
You also need to check the ball joints and inner and outer tie-rods for wear. AND your lower control arm bushings. Again a good alignment diagnostic shop should be able to identify worn parts.
http://www.continentalimports.com/ser_ic4232.html
Quick Reply: MB E - Class 220 CDI (211) HELP!
