C-Class (W202) 1995-2000: C 200 CDI, C 220 CDI, C 270 CDI, C 180, C 200 K,C 230 K, C 220, C230, C 280
Engine rattle - Supercharger Pulley?
Old 06-09-2012, 11:44 AM
MB260E's Avatar
'87 260E, '00 C230, 01 S500
Hi,
My 00 w202 has an engine rattle similar to this one:
I've tried replacing the supercharger with a rebuilt one which helped - but the noise came back in full force shortly after. I've heard it could also be the supercharger pulley, but I haven't been able to find one aside from ebay - any suggestions on where to look?
Thanks,
Old 06-09-2012, 05:25 PM
ptcruiser's Avatar
C230
Sounds like a bearing to me
I heard it when the clutch engages, and sounds like a bearing to me.
Old 06-09-2012, 06:40 PM
MB260E's Avatar
That's what I thought - it usually only happens when engaged in lower RPM's ~1500-2500, however I replaced the entire s/c with a rebuilt one with no avail.
Is the bearing a standalone replacement part?
Old 06-10-2012, 06:58 PM
ptcruiser's Avatar
C230
The noise
I have no idea if the bearing is a stand alone item. Generally, you need to spend $500.00 to get a $2.00 part, which makes sense to the manufacturer, but not to the consumer.
Also, as I am sure you know, the clutch drive is an electromagnet, and it could be the clutch plate rattling when it's engaged. Strange it disappears at higher RPM. There is a space tolerance on the plate when it's disengaged, and a feeler gauge can tell if it's the right space, but I don't know what that would be. I imagine it's a searchable question on the net.
Being the same principle as an air conditioner clutch, an air conditioner repair shop could probably check it out a lot cheaper that a dealer, if you have the space tolerance.
Anyway, good luck, and let us know the end result.
Regards
Brian Wilson
Old 06-14-2012, 08:52 PM
u001elg's Avatar
2006 ml350
That noise is the supercharger coupler. It is a non-metallic composite that connects the clutch driven pulley to the internal drive of the supercharger.
It sounds like the rebuilder either did not use the correct coupler and it prematurely wore out or it was not replaced during the rebuild and is failing. Either way you will have to remove the supercharger, remove the pulley and disassemble the front case to access the coupler and replace it. The actual job takes about 20 minutes (remember to install the correct amount synthetic oil after installing the front case). The supercharger remove/install takes a couple of hours.
The Eaton M-45 series is a relatively common supercharger and you can google the replacement coupler "kit" easily for prices and availability. The intake, discharge and pulley are M-B specific pieces, but the supercharger itself is an Eaton M-45 series... the same as used on GM supercharged engines (think 3.8L Buick V-6's).
These are all aftermarket parts since M-B does not consider the supercharger as a serviceable part.
Old 06-15-2012, 10:55 AM
ptcruiser's Avatar
C230
Answer
Good, concise and to the point answer........
That is what I like to see when asking a question.
Old 06-15-2012, 10:04 PM
PTVC230K's Avatar
2016 SLK 300
I missed what model you are referring to. If it is the '00 C230, I always believed the Supercharger is the Eaton M62.
Old 06-16-2012, 02:45 PM
MB260E's Avatar
Thank you for the responses! It looks like the s/c coupler is a cheap fix so I will start there and see if that takes care of the problem. BTW, for anyone looking i've found a couple of places for the m62 coupler:
http://www.couplerfix.com/Products.html (I'm guessing I get the one for the Buick or does it matter?)
http://www.rollingperformance.com/scoil.htm
Old 06-16-2012, 03:49 PM
ptcruiser's Avatar
C230
Option 2 looks a lot more reasonable to me...
Good luck with the fix.
Keep us updated
Old 06-22-2012, 10:41 AM
xvvvz's Avatar
C230K
My car has been making this same sound at startup for a couple of years. It happens almost every time I start the car in the morning for the first time but thankfully (knock on wood for luck) only once at startup. When it is cold outside, it often does not make the sound.
Please let us know how your project goes and please post videos if you tear your unit down.
Quick Reply: Engine rattle - Supercharger Pulley?
