Finally got rid of the exhaust drone...
Old 05-15-2012, 01:06 AM
nias9527's Avatar
C300 2008
Talking Finally got rid of the exhaust drone...
After many tries to get rid of that sound, I finally found a solution, and I want to share it with you guys.
Here is the pictures..(see attachments)
I was having very bad drone around 2100~2500 RPM on the freeway
and lower when driving local..
I did some search online and found this side branch resonator that works to cancel the resonance (drone)..
It uses the properties of sound waves to cancel out the drone..I found the ideal length of the resonator for my RPM range will be around 28 inches
but my muffler guy told me 28 won't do because of the space so the most I can get is 27 inches...I did it and it works great! although not all the drone at lower than 2000 RPM is cancelled, the drone is alot more acceptable and wont hurt my ears anymore!
so the solution to the exhaust drone is to have 27 inches of side branch resonator and let the sound waves bounced back inside the resonator cancel out the resonance!!!
Cost around $70 to install!! not so expensive
Attached Thumbnails Finally got rid of the exhaust drone...-img_20120508_164941-copy.jpg   Finally got rid of the exhaust drone...-img_20120508_164945.jpg   Finally got rid of the exhaust drone...-img_20120508_164950.jpg
Old 05-15-2012, 01:36 AM
Mixedfruits's Avatar
E63 Black on Black
so its just a pipe sticking out? I have the same setup - the magna flows and sticking out thing
Old 05-15-2012, 01:53 AM
Doanster's Avatar
C300 Sport 6MT
From what I see in the pics, you: a) took out the stock resonator, b) installed an x-pipe, c) used ONE Magnaflow muffler with dual-ins/outs very close to the x-pipe, and d) two glasspacks? Are there any mufflers after the glasspacks? Now you've had to punch a hole in each side's piping in order to weld on extensions that dead-end after a couple feet in order to get rid of the drone?
Too many hoops to jump through IMO, but if the drone is gone, .
You're probably halfway home (or more) to a Meisterschaft system by now, though.
Old 05-15-2012, 03:07 AM
nias9527's Avatar
C300 2008
do you have exhaust drone problem with your setup??
yea there is just straight pipes after the glasspacks!!
The exhaust tone is a lot deeper than OEM exhaust!! I LOVE IT
Old 05-15-2012, 03:20 AM
killerg's Avatar
99' Toyota Corolla
definitely DONT post any sound clips
Old 05-15-2012, 03:49 AM
nias9527's Avatar
C300 2008
LOL yea??
why not..???
Old 05-15-2012, 08:25 AM
Stevedotmil's Avatar
W204 2010 C300 Sport/6M
Sarcasim at its finest.
Quick Reply: Finally got rid of the exhaust drone...
