SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Brake Pedal Spongey
Old 05-14-2012, 12:27 PM
jnappi's Avatar
Brake Pedal Spongey
I have a 1985 380SL: Can anyone tell me why is it when I first push the brake pedal down, it almost goes to the floor, then when I let it up and press again, it acts normal.
Is it air in the lines? I haven't touched the brakes to create this situation. Also, the ABS light comes on once in a while but now it is off.
Thanks for your insights!
Old 10-20-2012, 12:19 AM
roadster Kev's Avatar
1985 380 sl
Have you checked the brake fluid resevoir?
You may have developed a leak in the system if it is low ... it will need the brake lines bled out and a repair of the leak .
Fill up the res and take it ( very carefully )to your mechanic my friend.
Old 10-26-2012, 02:17 PM
SPONSOR
PelicanParts.com's Avatar
^^+1 - a spongy brake pedal may be due to a low fluid level or air in the lines.
Quick Reply: SL/R107: Brake Pedal Spongey
