Need Help ASAP - Key Will Not Turn In Ignition
Old 03-26-2012, 07:26 PM
n2it's Avatar
Mercedes-Benz E-Class
OK, so I come out of the post office and my key will not turn in the ignition. The key will engage everything else and in fact when you put the key into the ignition the stereo will play etc... I called my dealer who is an hour away and they said to have the battery jumped. I had the battery jumped and it did not work. So, we replaced the battery with a brand new one and the key still will not budge in the ignition. Does anyone have a clue as to what I can do? I really don't want to have to tow it to the nearest dealership which is 85-miles a way. Thanks in advance!
Old 03-26-2012, 07:34 PM
RobertG's Avatar
things with and without wheels
Try to clean the area where the lens is on the key and the ignition switch.
How fresh is the battery in the key?
Old 03-26-2012, 08:36 PM
n2it's Avatar
Re: Not it
Thats not it...
Old 03-26-2012, 08:40 PM
RobertG's Avatar
try to put the key in and out couple of times, you should feel a click then it will let you turn the key to start position.
Old 03-26-2012, 08:42 PM
n2it's Avatar
Re:
Trust me I've tried this several times it doesn't budge...
Old 03-26-2012, 09:04 PM
RobertG's Avatar
When you put the key in does it click?
Old 03-26-2012, 10:08 PM
n2it's Avatar
Re:
It feels the same as it always has except that it won't turn the ignition. It's too late for me now though...had to have the car towed 85-miles away. I didn't have anymore time to screw with it. The dealership said that the next step was to try the backup key but I have never had a backup key (bought the car used and the previous owner misplaced it). So, I guess I wait on their call tomorrow and then their bill!
Old 03-26-2012, 11:10 PM
n2it's Avatar
Re: Battery
The battery in the fob has nothing to do with the key turning the ignition. The battery is for the IR for the doors and windows...
Old 03-28-2012, 02:12 PM
nsolot's Avatar
1999 E320 1971 280SL
I had exactly same problem with one FOB. New batteries did not help.
I bought the car new, so backup key works. Thinking about getting a new FOB. How much does the stealer want for a new FOB?
Old 03-28-2012, 04:52 PM
n2it's Avatar
Re: FOB
It was in fact the key FOB. The new one came in today and the car started right up. Cost through my dealer was $231 tax total. No diagnostic fee etc...
Old 03-28-2012, 04:55 PM
RobertG's Avatar
Any idea what caused the fob to go out on you?
Old 03-28-2012, 05:05 PM
n2it's Avatar
Re: FOB
This could be coincidental but I had it in my pocket the last time I went jogging. I usually take my work car to the trail where I jog but had to drive the Benz this time. I know the history behind these FOB's so I wrapped it in a hankerchief as best I could to protect it, put it in my pocket, and took my normal run. It was the very next day that it failed. So, it could have been coincidental or could be that it bounced around enough during my run that something came loose inside. I will get the old key back and take a look at it. The bright spot is that now I can use the old FOB to unlock my door after my runs and lock the good one in the car while I am running. Expensive bright spot though...
Old 03-28-2012, 07:49 PM
RobertG's Avatar
Glass half full
Old 03-28-2012, 08:14 PM
nsolot's Avatar
In my case, I parked at CVS, went inside for 10 minutes, and when I got back in car, the key would not turn at all.
Just checked MBUSA website and there are 4 stealers within 5 mile (15 minute drive time) of me, so I'll call all 4 and get price quotes. I'll post what I find out.
Old 03-29-2012, 01:53 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
These keys just die sometimes and usually without warning. Glad to hear you fixed the problem.
Old 03-29-2012, 02:08 PM
tbone006's Avatar
E320
I too have this happen , but at random times. key slides into the the ignition, but i got to wiggle it around to get the ignition to 'turn over". It usually just takes me moving/wiggling it around in the ignition to get it to "release" and turn over? I hink i has something more to do witht eh ignition itself and how the tumblers inside are recv the key...?
Old 03-30-2012, 03:08 PM
nsolot's Avatar
Quote for new smartkey
4 dealers:
$260
$199
$220
$258
All told me same story that key cannot be programmed at dealership, but has to be ordered from MBUSA where is it programmed before being shipped. Takes 2-3 biz days for new key to arrive.
All 4 also said I would need to show driver's license and DMV registration and the name and address need to match up. Also they prefer if I show up with the W210, which is supposed to prove ownership when combined with the documents.
Old 03-30-2012, 09:12 PM
n2it's Avatar
Re: News Procedures
That is absolutely correct. The car must be there, you must show picture ID and the cars registration, and sign release paperwork to get the key.
This procedure was just recently initiated by MB.
My key was actually $170. But you have to pay $28 to get the key programmed, and I paid an additional $10 to have it over-nighted. So, the 2-3 day jargon is a load of crap...mine was there the next day.
I picked my new key up today...its the new chrome style. The construction of this key is not even close to the original Mercedes key. Much better construction, durability, and design. So even though the old one will not start my car it is a great backup to take with me on my jogs etc...
4 dealers:
$260
$199
$220
$258
Old 06-19-2012, 05:04 AM
renault12ts's Avatar
W215 CL500 2005
The battery in the key is not required for starting the car...try it, remove the battery from your key...now start the car. It uses an induction coil in the key.
The usual cause for key failure is that the coil breaks off the PCB. They can be repaired.
davmil2002 (09-15-2023)
Old 06-19-2012, 09:51 AM
RobertG's Avatar
Good info! that makes sense since the valet key has no battery.
Old 06-19-2012, 10:29 AM
W215 CL500 2005
We have a member on a UK forum who repairs the keys for us. If he can't it costs £240...which is about $380 at todays exchange rates.
Old 09-25-2014, 05:08 PM
Pmann67's Avatar
1997 C230 4cyl
Ingnition switch won't turn
My car switch has no problem since I own it 1 year ago. I parked it last night and ignition won't turn this morning after 6 times. I saw a discussion here that cleaning the key and the ignition hole might work. I just cleaned the key and the outside part of the ignition hole with alcohol, inserted the key and tried turning it two times and the ignition turned and my car started. Another thing, I cleaned the 2 key batteries.
Old 09-26-2014, 08:07 AM
W215 CL500 2005
I'm glad it worked for you...but the batteries do not have anything to do with starting the car.
Old 09-07-2018, 02:28 PM
Muhannad hadid's Avatar
W210 elegance 1998
I have a problem please any body can help
Before i go vacation I disconnect the battery,
and when i come back after one month I reconnect the battery again and the remote is working but when i put the key its not moving inside the switch and the gear stuck in parking and i didnt hear the click .....
please i need some help
Old 01-18-2019, 06:16 PM
Wake Law's Avatar
E430
Solved my non working key Fob dilemma
So my key fob would unlock doors, open trunk etc, but nothing happened when I inserted it in the car. I cleaned the lens and tried the “synching” process. Finally I took the darn thing apart and using a jeweler’s loupe I saw that a solder joint on the or circuit coil looked cracked. Using a fine tip soldering iron I carefully resolver the connection and now everything is perfect!
I thought I would share this with the groups so that others with similar issues might benefit.
Quick Reply: Need Help ASAP - Key Will Not Turn In Ignition
