Rear Main Seal of transmission
Old 03-24-2012, 03:36 PM
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
Had my car in for service and the tech mentioned there is a slight oil seepage at the rear main seal. Is this a common problem with the 1999 E320? I am at around 90K miles on the car right now.
Old 03-25-2012, 08:32 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
The rear main seal is at the back of the engine. In many (most) cases, oil leaks elsewhere make their way back there, so before worrying about that, look for and fix leaks at the valve covers and front of the engine.
Old 03-25-2012, 10:10 AM
vinceC's Avatar
2014 ML350 4Matic
Rear main seal (RMS) leaks are fairly common in the M112/113 engines as they age. I just did one in my 2000 C280 (190K miles) and have to do one in my 1999 E430 (63K miles) and my son's C43 (85K miles). The Service Manager at the local dealership tells me it has become a regular item. The seal is rather different from what most of us are used to seeing. It is a weird material, has no garter spring and some grooves that may act as a labyrinth seal. It also requires a special installation tool (it must be set 1mm below flush with the end cover) and the end cover must be removed to get the seal out. I questioned that but after looking at the end cover I see why the procedure calls for removal.
The dealer quoted $1,300.
The tool costs the dealer about $450. It is in three parts and also works on the older M104 engine.
I also renewed the transmission front pump seal while I had the transmission out.
Old 03-25-2012, 10:41 AM
MASTERBENZ's Avatar
Mercedes-Benzes: 2005 ML500, 2002 E320 4-Matic, 1993 300E, 1994 E320, AND 1999 C230 KOMPRESSOR
112 and 113 Engines Rear Main Seal!
These engines are common of oil leaks after you hit over 80K miles on your car. Seep isn't as bad as a leak...so, it depends on how bad it really is. Usually, I note it down and not worry too much if it's just a seepage, but if it's puking out and leaking badly, then I recommend it. Valve covers are also common on this cars after 80K.
Old 03-25-2012, 04:30 PM
Coincident or not ?
Seems like after the tech mentioned about the seepage...I have noticed on two different occasions now that the car kinda kick into a neutral mode when I am doing around 10 to 15 mph as I am slowing down and off the gas pulling into a parking space.
There are no noise of any kind when this happens...just a quick feel like it is not in gear. No messages on dash and when I drive away and punch it..it still shifts like normal and still hauls ***.
I have had the transmission oil and filter replaced at around 70K and the car has around 90K now.
Any ideas of what is happening?
thanks.
Old 03-29-2012, 02:08 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
It wouldn't hurt to check for codes. The ones for the transmission are in the low P0700 range. If you see any then you'd better get the car on a Xentry or other more sophisticated scanner.
Quick Reply: Rear Main Seal of transmission
