OIL LEAKS
Old 02-22-2012, 03:44 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
OIL LEAKS
Guys: I am noticing (small amounts) of oil on my garage floor. Are these engines prone to leaks because of the stress there put under? Anybody have experience with there rear seals and manifolds leaking oil, the cost to repair, etc?? Thanks
Old 02-22-2012, 04:07 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Whats with all your BOLD typing these days?
Old 02-22-2012, 04:10 PM
grantwoodtx's Avatar
GLE 63S
These are not SR71's that leak when on the ground. Any leak should be looked at and fixed.
Old 02-22-2012, 04:24 PM
jcjmw's Avatar
2005 E55 Wagon
You can quickly check the valve covers and see if that is the source of the leak (maybe the bolts to the valve covers are lose). If that is the case, then its something easy that you can do yourself.
As for rear seals, do a search and you should find other members who had rear seal leaks, but I do not believe its common. Good luck.
Old 02-22-2012, 04:32 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Sorry its just my MO on internet forums.
Old 02-22-2012, 04:33 PM
GregMB's Avatar
Valve cover leaks will generally give you a telltale burning oil smell since they drip directly on the exhaust manifolds.
I had leaks even with only 29,000 miles on the odometer. It's common.
-G
Quadcammer's Avatar
96 and 08 911 turbos
if anything is dripping you have a big issue. These cars are all covered up with plastic panels underneath, so if its dripping through the trays, its a significant leak.
Old 02-22-2012, 04:34 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Thanks for the input! I will look into the valve cover issue immediately and also the check the rear seal posts here.
Old 02-22-2012, 04:37 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
I think its the rear seal to be honest, and my mechanic wants $900 to fix.
Old 02-22-2012, 04:43 PM
GLE 63S
Also check the valve cover gaskets as they are fairly cheap and easy to replace. There's a DIY out there for you to look at for those.
Rear seal is a major job as you have to drop the transmission.
Old 02-22-2012, 04:55 PM
novae500's Avatar
W211
If its leaking on the floor prob read main seal leak. Mine is seeping right now on the lower rim. But I know it will need to be looked at when it gets worse.
Old 02-22-2012, 04:58 PM
jcjmw's Avatar
2005 E55 Wagon
Good luck and keep us posted. Info like this is helpful to members and in case of future searches by others on the same topic.
Old 02-22-2012, 05:18 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
$900 sounds right price. Also might be the oil pan.....
Old 02-22-2012, 08:54 PM
jmb614's Avatar
E55 AMG
$900 sounds high, find a good indy. Should only take about 6 hours.
Old 02-23-2012, 11:41 AM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
Be nice bud!! ...LOL!! emoving is on the ramp page today!!
Old 02-23-2012, 11:43 AM
JoelE55's Avatar
Best way to check is putting the car on a lift to see where the leak comes from? Could be your rear seal is worn out.
Old 02-23-2012, 01:48 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
I had two leaks so far. One from the cam cover's internal breather setup where the sections on each side are bonded into place. The one with the larger section weeped on mine. Easy but time consuming DIY repair. This leak makes the covers look terrible and yes drips down onto the headers.
The socket plug into the rear / side of the tranny was the next one and this has been repaired for $75 privately by a MB tech. This is more problematic as the oil can find its way up the harness into the tranny electronics and that then gets nasty. The new plug is a new style plug apparently and the issue should not recur.
Old 02-23-2012, 05:11 PM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
LOL!!!
Quick Reply: OIL LEAKS
