20x10.5 rear?
Old 02-20-2012, 09:58 AM
bigigg's Avatar
14' CLS550
20x10.5 rear?
Is anyone sitting on a 20x10.5 rear wheel? I know vossen likes to do a staggered setup 9F and 10.5R.. Curious if it will fit.
Old 02-20-2012, 10:30 AM
Shawnw's Avatar
2011 E350 Cab, 2010 B200
This may help
https://mbworld.org/forums/e-class-c...fset-20-a.html
Old 02-20-2012, 01:33 PM
bigigg's Avatar
14' CLS550
No doesn't help, thanx tho.. I'm lookoing for someone who has fitted 10.5" rear wheel on there w212
Old 02-21-2012, 11:10 AM
ondehoi's Avatar
w212
i have, hope this might help
Btw
here is my spec
Rennen R10 x-treme concave(due to offset-not so concave)
9" front on 245/35/20
10.5" rearon 285/30/20
Kirril from showroom motorsport helps me
nice customer supports too
Attached Thumbnails 20x10.5 rear?-img-20111223-00160.jpg   20x10.5 rear?-img-20111223-00158.jpg   20x10.5 rear?-img-20111212-00124.jpg
Old 02-21-2012, 11:29 AM
threeMBs's Avatar
Only MBs - the best or nothing
Shocking you were able to fit 245/35-20 & 285/30-20 on W212. I mean its 26.8" diameter tires. That would be about the max one can run on C219 CLS and R230 SL (both of which have a lot more room than W212).
What offsets? Any fender modifications? I see you're using non-stock body kit, hence the question.
Old 02-21-2012, 11:51 AM
ondehoi's Avatar
w212
no fender mod, just brabus body-kit and wheels
little modification on the front bowl (bowl-like metal supporting the shock absorber) for the tyre not to rub
the rear clears up barely as the body is straight in-line with the outer surface of the wheel, i haven't even had the time to drop the height. let you know later, but the workshop said it would clear up just fine.
if you are buying forged, just console with the engineering/shop.
regarding the offset, please just contact showroom-motorsport. it's not that i am promoting, it is just that they take care of mine just fine...
10.5 i would say is the max. i've seen a friend of mine go with 11", and it is petroding out of the body.
i'm in south east asia.
Old 02-21-2012, 12:01 PM
threeMBs's Avatar
Thanks for confirming and clarifying it - as I expected, shock's perch had to be modified to fit 245/35-20.
Old 02-21-2012, 12:12 PM
ondehoi's Avatar
w212
if you dont want to mod the perch, just use profile 30 on the front
Old 02-21-2012, 12:33 PM
threeMBs's Avatar
That's why I'm using 235/35-20.
Old 09-09-2020, 07:56 AM
takay the loko's Avatar
2008 mercedes c300 , 2017 mercedes e300 , 2015 gmc sierra , 2010 camaro ss ...
W213 e300 on 20x10.5 +35 all around
The following 2 users liked this post by takay the loko:
hyperion667 (09-09-2020), pierrejoliat (09-09-2020)
Old 09-09-2020, 08:02 AM
hyperion667's Avatar
Received 3,353 Likes on 2,807 Posts
2012 CLS63
What up Bigigg, not seen you in a bit! Keep it clean!
Quick Reply: 20x10.5 rear?
