P0306 After header install
Old 02-19-2012, 10:15 PM
nicco's Avatar
E55 AMG
Wondering if the forum god can help me out....
Couple of weeks back i got my kleemann headers installed and when we first started up the motor it wasn't idling properly.. Really rough!
The mechanic took it for a drive and when he brought it back we scanned the car and found the code p0306. So we swapped out the coil and wires between 5 and 6.... Still ended up with the same issue.
Hooked up star and noticed when the car is at idle the duty cycle for 6 is much larger then the rest of the cylinders. If you stand behind the car your clothing, skin etc will smell like GAS. if you park the car and walk behind the car you smell like gas.
Now where should i start my troubleshooting? Should i start by changing the plugs? or the injectors?
The guy that installed the headers said that i may have a problem with my injector and to run injector cleaner.
Old 02-19-2012, 10:23 PM
skratch77's Avatar
2005 E55
did he plug the wrong wires in the 02s?
Old 02-19-2012, 10:25 PM
nicco's Avatar
E55 AMG
Plug the wrong wires? how many wires are there?
Old 02-19-2012, 10:27 PM
skratch77's Avatar
2005 E55
he could of swapped the left and right bank or even the post cats banks.If all you did was install headers and nothing else I would look at those first before taking things apart.
Old 02-19-2012, 10:31 PM
novae500's Avatar
W211
White o2 harness plug goes front and black o2 goes rears
Or also wires were reinstalled wrong?
Old 02-19-2012, 10:32 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
He may have installed the 02 sensors in the reversed order is what he's saying. Car wouldn't run right correctly
The upper 02 sensor is where the lower sensor should be... The E55 has a left and right set. I would agree with Skratch. Make sure your o2 sensors are aligned
Old 02-19-2012, 10:33 PM
skratch77's Avatar
2005 E55
you have front and rear and left and right,if the left and right are swapped the ecu will go nuts trying to get its A/F right
If your guy just installed the headers only and nothing else was touched and didnt double check to see if he plugged the 02s in the right places I would find another mechanic asap
Old 02-19-2012, 10:38 PM
nicco's Avatar
E55 AMG
Ill have them check it out first thing in the morning and will keep you guys posted
Old 02-20-2012, 01:08 AM
nicco's Avatar
E55 AMG
Anybody have a wiring diagram of how there actually suppose to be wired up?
Old 02-20-2012, 03:06 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I'd be looking at the spark plug wires and the plugs themselves on cylinder 6. Could have cracked the porcelain on a plug while working in the area wrestling the headers in if they left em in while installing the headers or damaged a spark plug wire when installing/removing them. One of the wires not seated well possibly?
I don't see it throwing a cylinder 6 misfire if the O2's were somehow crossed. You'd get a multi cylinder misfire if anything or issue with it going lean or rich as the computer fought to control air fuel ratio in the banks and it was not seeing what it was requesting/expecting from the injectors.
If an O2 is the problem (I doubt it) it would be the front O2's as the post cat O2's do NOTHING except report on if the catalytic converter is operating properly. The front O2's is what the engine uses to adjust running parameters.
Old 02-20-2012, 04:54 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Black connectors are for the front sensors and white connectors are for the reat sensors
Old 02-20-2012, 06:47 AM
gp500e's Avatar
2006 E55
Once again someone managed to find a master tech.
Old 02-20-2012, 03:08 PM
tbal's Avatar
Haters crazy
Lol
Mikey I would have done a better job :p
Old 02-20-2012, 03:35 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
My Kleemanns went on perfect and not one issue!
Old 02-20-2012, 06:35 PM
lowprofile's Avatar
E55
Correct.
Also, is it true that Star will give you individual duty cycles like the Op stated?
Old 02-20-2012, 07:05 PM
shardul's Avatar
Lowpro i was going to ask that same question. Where in star can you find the injector duty cycle. I know you can see the flow rate via star.
Old 02-22-2012, 05:21 PM
nicco's Avatar
E55 AMG
So finally had a chance to crawl underneath the car and found the O2 wires are complete opposite from either side. The picture is from cylinder 6 side upper O2 sensor.
Maybe it was the flow rate he was showing me on star can't remember, i was raging inside cause the car wasn't running properly.
Quick Reply: P0306 After header install
