Brake Booster Seal part# help?
Old 09-17-2013, 11:00 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
I just ran both numbers through EPC and they state "nothing found". That means that it might be a valid number, but since it is a European part number it is not available in the U.S. market.
Old 09-17-2013, 11:48 AM
nickvardy's Avatar
2002 ML270 CDI
Thanks for looking in to it.
This is the sticker on the booster I have got that's from the ML320 in case I've been supplying the incorrect information from it. Is it of any further use?
Cheers.
Old 09-17-2013, 12:25 PM
Here is the listing for the booster for your year and model.
They must have changed the numbers and you cannot refer to the old number.
As long as the booster you bought came from a 2000+ ML there shouldn't be a problem.
Of course disconnect the Master Cylinder from the booster, but do not disconnect the brake lines from the Master Cylinder. The booster can be removed with a little finesse and it will save you from bleeding the brakes.
Old 09-17-2013, 03:36 PM
nickvardy's Avatar
2002 ML270 CDI
Thanks very much for taking the time out to help here. I think I'm going to source a replacement direct from a diesel ML just to be absolutely certain its like for like. I made a call to an MB parts specialist in the UK and they seemed to have the same result of not being able to cross reference older parts details.
Old 09-20-2013, 02:19 AM
  #30
greg.gnr's Avatar
ML63 and ML270
Try P/N A0014313160 for the seal.
Old 09-20-2013, 06:56 AM
  #31
The seal you recommended goes between the master cylinder and the booster.
The seal that is causing the problem is at the rear of the booster, which is not replaceable.
Old 10-14-2013, 07:38 AM
  #32
StevenHaywood's Avatar
1999 ML320, 2009 Cayenne GTS
Hey allApologies for resurrecting this, but I have the same hiss in my 99 ML320.
How serious is this? I mean, do I need to fix it now, or could I wait a while? Idle doesn't seem to be affected...
Old 10-14-2013, 07:55 AM
  #33
The choice is up to you, but I would consider it serious. You will not receive the full braking force if the brakes are applied in a emergency stop.
Any loss of vacuum will affect your fuel trim.
Old 10-14-2013, 08:11 AM
  #34
I'm able to lock the wheels as things stand (well, to get ABS to kick in). The hiss is quite soft, seems like quite a small leak but I assume it will get worse with time.
The price of a new booster is insane (20% of what I paid for the vehicle!) but we have companies here that will rebuild it with a 1 year warranty for 1/4 the price of a new one ...
Old 10-14-2013, 06:24 PM
  #35
greg.gnr's Avatar
ML63 and ML270
I repaired this seal in my ML 270 and the leak has stopped. The performance improved dramatically as the turbo was effected from the lower vacuum that was available prior to the repair. I trust the repair will work for a while.
Old 10-15-2013, 01:06 AM
  #36
Ok I'm going to try the patch repair. If/when it gets worse, I'll look at rebuilding the booster. Thanks
Old 10-15-2013, 01:23 AM
  #37
greg.gnr's Avatar
ML63 and ML270
I tried to work through the manufacturers of the boosters in USA. My vehicle is a US build.
To this time I can drill down far enough within the company but I came to a brick wall for simple part. Use a fair proportion of rubber grease on assembly and it may help on the installation as well as help seal- just take your time! Greg
Old 10-15-2013, 04:33 AM
  #38
Mine was also built in the US (I think they all were, weren't they?)I have a place here that's prepared to remanufacture the booster, with a 1 year warranty, for about 220USD. Going to keep that option in reserve, but will try the patches first
Old 10-15-2013, 04:55 AM
  #39
greg.gnr's Avatar
ML63 and ML270
I spent some time in SA so as can Oz happy to assist! You are right all RHD was produced in USA.
Good luck.
Old 10-17-2013, 04:18 PM
  #40
st0rm's Avatar
03 ML350
Hey, I been watching this thread and finally decided to register and ask. Some here here stayed that any 2000+ ML breakbooster would work.
I have found one from 2006 would that work since the part number i got A163 430 06 30
And the one i found is a A164 430 14 30
Edit.
Never mind the booster itself is different.
Old 10-29-2013, 07:38 AM
  #41
Just an update, I pulled the booster out on wednesday evening and dropped it at a brake and clutch centre on Thursday. Picked it up again yesterday afternoon and reinstalled it - leak gone. Cost me about USD330 to do, with a 1 year warranty. I think that's a pretty good compromise, considering a new unit here is USD880 ...
Was able to remove it without disconnecting the master cylinder
Old 08-02-2015, 03:13 PM
  #42
momin786's Avatar
ml 270 cdi 2003
I know this is thread hasn't had much action in an age but I've found a replacement brake servo gasket, the one from a Volvo S60 is identical, so the question I have is how do you fit it?
Manufacturer is TEDGUM if anyone is interested
Old 08-18-2015, 03:19 AM
  #43
janoe55's Avatar
2014 E350 Sport,1999 ML430,X cars 2008 Z06,2006 E55,2002 Z06,95 M3
Originally Posted by momin786
Attachment 313906
Attachment 313907
Do you have a part number for this seal?
Old 08-18-2015, 06:26 AM
  #44
momin786's Avatar
ml 270 cdi 2003
http://tedgum.pl/catalog/getdetails/21729/00748698.html
part number is 00748698 if link doesn't work go to tedgum parts catalogue, Volvo, s60, other
Old 08-18-2015, 02:34 PM
  #45
janoe55's Avatar
Thanks..when I get this part and I will try to replace it and post the replacement procedure
Old 04-25-2016, 05:26 AM
  #46
kuleke's Avatar
2007 S550 (Prev) 2001 ML320
Sorry to resurrect this again but I've been reading the posts and I'm still not entirely sure what to try first. Is it really viable to try a temporary solution until I can afford a new brake booster? If so, does someone have a video guide or something like that somewhere?
Old 04-26-2016, 06:58 PM
  #47
drefanzor's Avatar
2002 ML500
I just threw up in my mouth looking at this thread.
Old 04-28-2016, 04:23 AM
  #48
Brake booster.
Old 04-27-2017, 03:38 PM
  #49
TheShooter's Avatar
ML 500
Thumbs down
Ya, you know, every time I have ever thrown up it was in my mouth and then out my mouth
I have no idea why people say things like this - and, you didn't add any value to the thread either.
Old 04-27-2017, 03:40 PM
  #50
TheShooter's Avatar
ML 500
Question
Sooooooo? Did you get the part? Did you do it? Did you post it in a new thread?
Quick Reply: Brake Booster Seal part# help?
