C1170 Steering angle sensor N49 zero point variation?
Old 01-21-2012, 05:04 PM
153D's Avatar
2002 C230, Sikorsky UH-60
I searched, couldn't find anything...
I have an ESP not available message on my 2002 C230 after the alternator went bad and battery died, tried clearing it several times to no avail.
When alternator died I got an undervoltage message and then the car shutoff. I'm guessing the N49 shorted out when the alternator failed?
What are my options here? Has anyone experienced this before?
Old 01-21-2012, 05:17 PM
Super Moderator
Glyn M Ruck's Avatar
Forlorn hope. Turn your steering from lock to lock 5 times to reset the SAS. If this does not work it's likely a new sensor
Old 01-21-2012, 05:19 PM
153D's Avatar
Glyn you're the man, I appreciate the quick response. I'll give it a shot shortly, key position off, accessory, or on?
Old 01-21-2012, 05:31 PM
Super Moderator
Car running!
Old 01-21-2012, 05:48 PM
153D's Avatar
Will do!
Old 01-23-2012, 01:54 PM
153D's Avatar
I went lock to lock first about 3 or 4 times then shut the car off after sitting a little while and still had the message so then I tried again about 6 or 7 times and was still getting the notification. Bad sensor?
Old 01-23-2012, 03:13 PM
Super Moderator
Bad sensor likely. Are you storing any other codes?
Old 01-23-2012, 03:25 PM
153D's Avatar
No codes, just the bad coolant sensor messages for check coolant level and check wiper fluid level.
An undervoltage could cause the sensor to go bad?
Old 01-23-2012, 04:31 PM
Super Moderator
It's possible - I would suggest unstable voltage.
Quick Reply: C1170 Steering angle sensor N49 zero point variation?
