CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL 55 ideal wheel offset
Old 01-12-2012, 02:11 PM
KennyH's Avatar
2004 Cl55 AMG
Just bought an Obsidian Black, 2004, CL55. My first set of repro AMG wheels had a 35 offset, which extended beyond the fender line. Unfortunately I learned too late that the rear axel width is wider for the Cl55 than the 500 or 600. For a staggered set, what is the best offset?
Old 01-12-2012, 02:20 PM
slonar21's Avatar
CL600 2003
I own a 600, but I would say that 35 is not the right offset, the stock offset for 8.5" front wheel is 44 and the 9.5" rear is 46.
My Brabus setup is 40 front and 45 rear.
Look here for fitting chart
http://www.alloywheelsdirect.net/inf.../mercedes-benz
I am pretty certain the rear axle is the same for these cars, 35ET is just not the right offset
Old 01-12-2012, 04:01 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Your factory rear wheel is not a 9.5". The factory wheel is only 9" wide.
A good offset of 8.5" fronts and 9.5" rears appears to be +35.
R.K.
Old 01-12-2012, 06:11 PM
slonar21's Avatar
CL600 2003
Ooops,
Ok, well my Brabus are 9.5 at the rear with a 45 offset
From the chart
19x8.5 40 245/40R19 19x9.5 45 275/35R19 Brabus
Old 01-12-2012, 07:00 PM
1995E320Cab's Avatar
2003 CL600 2005 745Li
Are you sure about that, all I have ever seen is that the CL65 is different.
R.K.
That's what I am running on my CL600 and it near perfect
Old 01-12-2012, 07:32 PM
KennyH's Avatar
2004 Cl55 AMG
cl55 offset
I am assuming your Brabus wheels fit great, inside the fender line? My trial with 35 offsets failed. Your car was the reason I bought Obsidian and bought the identical wheels that you used. Another thread on the forum gives the actual measurement of the CL600 versus Cl55 axle width.
Old 01-12-2012, 07:40 PM
I am assuming your Brabus wheels fit great, inside the fender line? My trial with 35 offsets failed. Thanks for the help.
Got any photos you can post ? How wide are your wheels ??
Old 01-12-2012, 08:55 PM
radride's Avatar
Where is this?? Link please.
R.K.
radride's Avatar
On a side note; I just ordered my wheels for my CL65. About 3 months out.
R.K.
Old 01-12-2012, 08:56 PM
radride's Avatar
In your opinion, do you think the fronts could come out a couple of mm?
R.K.
Old 01-12-2012, 09:45 PM
R.K.
Yes I do, I got some 5mm spacers for the front to try but have not put them on yet. Love to know what you ordered, PM me if you like.
Old 01-12-2012, 09:51 PM
radride's Avatar
That's good to here. I will pm you.
R.K.
Old 01-12-2012, 09:58 PM
KennyH's Avatar
2004 Cl55 AMG
R.K.
20x8.5 and 20x9.5 from a southern CA online store that just does OEM copies. Regarding the thread for axle measurement, I will have to hunt for it. Most sites with fitment guides differentiate AMG versus non AMG CL's.
Old 01-12-2012, 09:59 PM
KennyH's Avatar
2004 Cl55 AMG
Rears are 20x9.5, 35 offset. Did not take any pics, the disappointment from seeing it was enough.
Old 01-12-2012, 10:53 PM
Such a bummer the fit my car well. What will you do next ?
Old 01-12-2012, 10:59 PM
KennyH's Avatar
2004 Cl55 AMG
Keep hunting for a fit. Might need LASIK to continue the online hunt
Old 01-15-2012, 08:55 PM
grane's Avatar
G350 Bluetec
Cl55 only:
If you use the same size 18" AMG wheel you need an Et44.I use this for my winter tires.
If you use staggered width 18" or 19"genuine AMG wheels you need Et44 front and Et46 rear. I use these wheels for my summer tires.
This info is in your OM and the MB wheel Accessory Catalog . Cl500, Cl600 and Cl65 have their own specs and unique wheels, as a rule.
Please use genuine AMg wheels on your AMG if you are actually going to drive it.
Old 01-31-2012, 12:29 PM
Hakop's Avatar
2005 CL55
Offset
I have a 2005 CL55
19x8.5/Front, 19x9.5/Rear
Offset: 44/Front, 46/Rear
I want to put 20" wheels will the same offset be fine N does the width of the wheel matter?
Old 01-31-2012, 02:59 PM
radride's Avatar
Originally Posted by Hakop
I have a 2005 CL55
Ofcourse it does. Changing the width of the wheel and leaving the offset the same makes the wheel sit differently. Same holds true if you leave your widths the same but change the offsets. They go hand in hand.
R.K.
Old 01-31-2012, 04:15 PM
Hakop's Avatar
2005 CL55
I
R.K.
I want to put 20x10 or 20x10.5 what offset should I look fo?
Old 01-31-2012, 04:44 PM
radride's Avatar
I
I'm assuming you are talking about the rears. If you are, I have no idea because I have a CL65 which has different sizes and offsets from the factory. Most of these guys won't even be able to tell you either as they will just call up the wheel company and they will send them wheels that fit. I use the word fit loosely. I guess it depends what look you are going for with your car.
R.K.
Old 01-31-2012, 04:47 PM
Hakop's Avatar
2005 CL55
R.K.
I like the flush look I want the maya mrs
Old 01-31-2012, 05:33 PM
radride's Avatar
Those will be cheap cast wheels expensive price tag. I'll give you all a secret about wheel companies. Quality wheels and cost don't go hand in hand. But they pull wool over your eyes. Just because all the high end cars are running them, doesn't mean the're good. I can almost bet that if you call up and as Maya what offset they offer, I bet you will have 2 or 3 choices. On being a +35, +42 and maybe one other. Also wheels faces are what clear the brakes. Most manufacter of wheels don't know your brake specs so even if you do buy those wheels, in the offsets that you need, they still might not be able to bolt on because they won't clear the brakes.
R.K.
Quick Reply: CL 55 ideal wheel offset
