ABC pulsation damper and Filter DIY repair
Old 01-01-2012, 07:38 PM
carbizindio's Avatar
2003 C32, 2002 S55, 1999 SL500, 2004 S430
The suspension pulsation damper will cause a humming / buzzing noise when not working correctly.
See TSB Topic number LI32.50-P-048280 for more detailed information.
Not every thing I do is according to the strict guidelines of WIS, so use my directions at your own risk.
Jack up front end. Find the 2 bleed screws on the LF and RF next to the torque strut bushing and bleed the system. Make sure you have the car secure because you will lose all suspension pressure after this is done.
Remove the pulsation damper. You will need a 24MM wrench for this, because of how the threads are welded to the unit you can't fit the wrench in every position. Maybe you can take this off with a oil filter remover?
This is a good time to change your filter for the suspension.
The top is held on by a hook, remove by pressing down on the spring.
My fluid was black so I pumped out what was in the res. try to be as clean as you can be.
Fill up res to the engine off min/max, install filter.
I started the car and set it to normal height, check fluid level at engine on min/max. Raise up then normal 15 times if any major components were replaced while checking fluid level only when set in the normal ride height level. If you hear a hissing noise in the area where you installed the pulsation damper or in the rear of your car then shut it off and bleed at the same bleed screws.
I had the hissing noise so I had to bleed the system 5 times. I had no luck getting rid of the noise. I ran the rodeo and dynamic test along with testing the pump and other components and had no codes after I was finished.
Old 05-28-2015, 02:06 PM
Fried Chicken's Avatar
2005 S500 Designo
Two questions.
1. I can't find a pulsation damper for less than $350, and various older threads mention paying ~$150. Is this a supply and demand issue, where everyone is getting these replaced since the TSB, or is something else funny going on in the global ABC pulsation damper market?
2. Where are the pictures?! Pleeeaassseeeeeee I want to DIY this, and having these pictures will probably be very useful!
Old 05-28-2015, 05:27 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Carbizindio seems like the pictures are no longer available. Would be nice if they were still available.
Fried chicken did you check http://www.autohausaz.com or http://www.ecstuning.com seems to me they were in the $150 to $170 range. There are actually (4) accumulators on the Mercedes S-Class with ABC suspension. On my car 2003 S500 the part numbers are 220 327 01 15 (2), 220 327 02 15 (1) and 220 320 04 15 (1). I believe the last one is the pulsation damper. It list on ecstuning for $164. and on autohausaz for $190. When you do your part number searches I have found that you get better results when there are no spacees left between the numbers.
Old 05-29-2015, 09:57 AM
jnash's Avatar
2017 S63
The ones that typically fail are the two large ones
Old 05-29-2015, 12:30 PM
ibeforreal's Avatar
I agree with you Jnash. Those two are generally the culprits.
Old 05-29-2015, 01:31 PM
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
ibeforreal,
Thank you for mentioning us!
If there is anything I can do to assist anyone please let me know.
David
Old 05-29-2015, 07:08 PM
2005 S500 Designo
I'm not sure if any of those parts are the one's I'm looking for.
I'm looking for the pulsation damper mentioned in TSB LI32.50-P0048280
Here's a link to it although I'm not 100% sure it will work:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=180082
It's a part that bolts pretty much directly onto the tandem pump.
Old 05-30-2015, 05:33 AM
MCMLXIX's Avatar
2006 S65 AMG V12BT
Can anybody fix the missing pictures?
Is there a difference between an S500 V8 and S600 V12?
Old 05-30-2015, 11:11 PM
2005 S500 Designo
It is my understanding that yes, the S600 V12 requires a very expensive repair because the pulsation damper is integrated or otherwise. I am not sure exactly why.
Old 05-31-2015, 02:44 AM
jnash's Avatar
2017 S63
They are identical.
Old 05-31-2015, 10:32 AM
ibeforreal's Avatar
The S600, S55, CL, and S500 are identical.
Old 05-31-2015, 02:13 PM
2005 S500 Designo
Just kidding, they are identical xD
Rate This Thread
Rate This Thread:
Quick Reply: ABC pulsation damper and Filter DIY repair
