How to remove Antenna & roof trim
Old 12-27-2011, 10:48 PM
Mixedfruits's Avatar
E63 Black on Black
Title says it all anyone know?
Bmw's antennas are double sided on as far as I know.
Trim is clipped in
http://www.e90post.com/forums/showthread.php?t=381362
Anyone know for our car?
Old 12-28-2011, 03:11 AM
snarlingchicken's Avatar
2009 C350
Everything can be solved with a flat head screw driver. (But maybe not fixed/repaired) :P
Old 12-28-2011, 02:21 PM
Thaa kiid Jlee's Avatar
2011 c300 4matic
lol so your saying its taped on?
Old 12-28-2011, 03:09 PM
2009 C350
I'm pretty sure the antenna is clipped. (But still don't take my word on that). Might wanna give it a wiggle and see.
Old 12-28-2011, 11:10 PM
mkng's Avatar
c300
I think it it secured by a screw or two; you'll have to unscrew it from the inside of car- rear map lights?
Old 12-29-2011, 02:07 AM
E63 Black on Black
yeah thats what i though but i dont have a star screw driver small enough to fit between the antenna and the headliner
Old 12-29-2011, 02:36 PM
Eickecc's Avatar
C350/'08 w204
Get a torx bit and angle it in the box end of a small wrench....tape with electrical tape. I've actually removed the antenna before this way. As for the roof trim. It is clipped. I pulled up from the very front (hood) and it just comes off with a little effort.
Old 12-29-2011, 04:09 PM
E63 Black on Black
can you take a pic of your tool setup? LOL.
Old 12-29-2011, 04:54 PM
Eickecc's Avatar
C350/'08 w204
Sure...I'll hook you up tonight when I get home.
Old 12-29-2011, 05:35 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
thats how I did it. Use a torx bit and a 5/16" box wrench (i think) to slide in between. I had a spotty connection on my 08 w the sirius antenna and removed the antenna to fix the connection like this. takes patience it was frustrating
Old 12-29-2011, 08:55 PM
Kaewen's Avatar
GLC250 Coupe
poo this is interesting... why would you want to remove the antenna? or roof trim?
Old 12-29-2011, 09:54 PM
E63 Black on Black
For many cosmetic reasons
Old 12-30-2011, 11:12 AM
Eickecc's Avatar
C350/'08 w204
Sorry this took so long. Been really busy....don't know that these are the right-size tools, but a use a torx bit, angled in the wrench, and tape it really tight. Manage your patience, however. lol This will pop the antenna loose and then you'll have to figure out what to do with the three cables.
Attached Thumbnails How to remove Antenna & roof trim-photo.jpg   How to remove Antenna & roof trim-photo1.jpg
Old 12-31-2011, 02:44 PM
E63 Black on Black
Ahah took it off already instead of using that wrench i just used the bit.... in that tight space took around 10 min zzzzz
Old 12-31-2011, 11:27 PM
Kaewen's Avatar
GLC250 Coupe
well.. do let us know what you are going to do with them
Old 12-31-2011, 11:32 PM
E63 Black on Black
Was going to wrap my roof, but turns out I dont want to ... LOL
Old 01-23-2013, 03:09 PM
ONE-9-T's Avatar
W204 C350
hi ive a question....i want to wrap my roof too....in following pic u see the antenna from bottom.....if i understand right i must just unscrew the screw in the middle of the part from inside light hole ????
Old 10-09-2013, 08:29 PM
dolvio's Avatar
2010 C250 4Matic
Did you ever end up taking off your antenna?
Old 10-20-2013, 06:10 PM
steckology's Avatar
c 250
Any more info on how you were able to remove it and re-install the antenna? Last night while my 2012 C was parked at the hotel I am at for business it got vandalized and someone thought it would be cool to rip mine off. The Marriott wont cover the cost and it would be cheaper for me to fix myself of course if I just just pull the rest of it up and plug in a new unit. Im taking it to the dealership tomorrow to see if the parts would be cheaper to buy than my deductible any help would be great. thanks
Attached Thumbnails How to remove Antenna & roof trim-img_3248.jpg   How to remove Antenna & roof trim-img_1494.jpg
Old 10-20-2013, 07:00 PM
dolvio's Avatar
2010 C250 4Matic
Mine is being done at the dealer tomorrow morning. The part is $55 if you do not have GPS. They can also access it from the rear dome.
Hope this helps,
A
Old 10-20-2013, 07:53 PM
Eickecc's Avatar
C350/'08 w204
Hope this helps,
A
This seems like a deal for $55 as long as labor is cheap. I paid $100 for the antenna from salvage and made the change within a few minutes. Adding labor might bring the total to around $100, maybe....
But, assuming the antenna works, it's easy to swap out the plastic cover. I just wouldn't change out the entire antenna, that's the pain.
Old 10-20-2013, 07:56 PM
steckology's Avatar
c 250
If I could get it done for that Id be really happy.. you cants really tell from the picture but the little green part sticking up is bent over really bad it looks to me like it should be replaced. thats the part im worrying will cost a lot.
Old 10-20-2013, 11:27 PM
Eickecc's Avatar
C350/'08 w204
That's no good man. I think the dealer quoted me at least $600 for the part and labor, before I had the idea to just change the cover....
Old 10-21-2013, 04:39 PM
dolvio's Avatar
2010 C250 4Matic
I had my antenna replaced at the dealer today. Took 35 minutes and cost was $150 all in. Great service.
Old 11-11-2013, 04:28 PM
Mikephinney's Avatar
2012 C250
I burnt mine with the buffer yesterday and the dealer told me that he can't order just the cover. Says it's a sealed unit and it's $271! Does this sound right? '12 c250 sport
Quick Reply: How to remove Antenna & roof trim
