Cabin Air Filter 2010 MB GLK350 (help)
Old 12-17-2011, 12:53 AM
wutzurname's Avatar
2010 Mercedes Benz GLK350 SUV
I need help locating where there cabin air filter is located on this model. Any help would be greatly appreciated.
Old 12-17-2011, 05:37 AM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
A quick search on the forum would have given you the location - and a replacement procedure (DIY): https://mbworld.org/forums/glk-class...in-filter.html
Good luck.
Old 12-17-2011, 09:44 AM
420tee's Avatar
Red GLK350, blue '87 Toyota Land Cruiser
Since I've driven cars with A/C for nearly 50 years without Cabin Air Filters what's the harm in taking this one out when dirty and not replacing it?
Interesting, there is an ad for Infiniti just below this thread.
Old 12-17-2011, 10:44 AM
iridiumGLK350's Avatar
11 GLK350
ive pulled some cabin filters at 15k on various cars and the filter is black with all kinds of stuff trapped onto it. im pretty sure you dont want that stuff to go staight into the cabin and into your lungs, also helps keep the interior more tidy as it traps dust while in use.
Old 12-17-2011, 11:50 AM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
GLK is the same...
https://www.mann-hummel.com/mf_prodk...u/HB5JXdhG.pdf
Old 12-17-2011, 03:40 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
You should also remove the filter from your home HVAC system.
Wayne
Driving with cabin air filters since 1999 in East Texas.
Old 12-17-2011, 04:55 PM
venchka's Avatar
But seriously...Are you sure? We have had cabin filters since 1999. I am pretty sure that they appeared before 1999. They are not expensive and do some good.
Wayne
Old 12-17-2011, 07:22 PM
slk55er's Avatar
'19 CLS53, '19 SL550, '22 GLE53
If you do decide to remove it (as I have done temporarily to try to eliminate the musty smell) you should cover the opening into which the filter is inserted. Otherwise the air will not circulate properly.
To do this I removed the charcoal/paper portion of the filter from the plastic end/cover and used this. The musty smell did disappear, so I suspect that the filter itself was the source of the musty smell. Now that the smell is gone, I'll see if it re-appears next summer with heavy A/C use here in the high desert (above 110 regularly in July and August.)
Quick Reply: Cabin Air Filter 2010 MB GLK350 (help)
