Sponsored by: DashLynx
Oil Filter cap
Old 10-08-2011, 10:57 AM
S550Designo's Avatar
2007 S550 Designo Launch Edition
Oil Filter cap
Ok, tackling my first oil change and I have stumbled upon a problem. It seems the oil filter housing cap is on incredibly tight.
It is threaded normally right? No reverse threads?
Old 10-08-2011, 11:14 AM
745Japan's Avatar
745i BMW '05, S550 '08
Righty tighty, lefty loosey man. No its not reversed. If you can't get it, double some cloth and use a pair of pliers and slowly turn. First oil change and the cap is a challenge, your in for a treat.
Old 10-08-2011, 01:44 PM
Finally had to go get a strap style filter remover to break it loose. That thing was on crazy tight.
Also, I noticed my replacement filter came with 5 o-rings. I could only find three to replace: the big one on the threads and the two at the end. Where are the other two?
Finally, it took every bit of 8 quarts and looks like it could still take another 1/2 quart. Suggestions on whether I put the oil level in the middle of the oil stick indicator or should I get it as close to max as I can?
Old 10-08-2011, 02:51 PM
listerone's Avatar
2018 BMW 540d
In doing an oil change I always,initially,bring it up to about 1/2 quart of capacity,then run the engine for awhile,shut it down,check the dipstick and carefully bring it up to capacity according to the dipstick.
But that's just me I guess.
Old 10-08-2011, 07:05 PM
745Japan's Avatar
Not just you but it's what I do as well. Running the engine will send oil throughout the motor and should decrease from the filler mark. Add more to actually "top" off the engine with oil.
Old 10-09-2011, 01:44 AM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
just curious, are you draining it or extracting it?
Quick Reply: Oil Filter cap
