Old 06-04-2015, 08:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior
Print Wikipost
Cabin Filter Replacement DIY
Old 09-14-2011, 05:45 PM
jreash's Avatar
mercedes benz 2011 e350
Hi Folks - Hoping to replace the cabin filter on my 2011 E350. I found a post that stated: Remove instrument panel cover below glove box, remove clamps at both ends of filter housing, unlock slide in direction of arrow – remove combination filter.
Well, when folded back the cover, there was an aluminum plate with a bolt in the upper right corner. I removed it, but there was still a lot of resistance when I tried to fold back the plate. I didn't see any clamps. It does look like the filter might be under there, but I didn't want to break anything. Is this the right spot? An help will be appreciated.
Jim
Old 09-16-2011, 11:48 AM
El Cid's Avatar
Earlier post
Jim
I think Konigstar provided some information on a post several months ago for the 2010 model. Do you really need to replace it already? This is part of "B" service.
Old 09-16-2011, 06:56 PM
jreash's Avatar
Yes, just reached 20K and need to replace it. Actually, Konigstar was a big help. Hope to change oil and the cabin filter this weekend.
Jim
Old 10-29-2011, 12:08 PM
viksc230's Avatar
2005 c230 sport
cabin filter mounting instructions
easy as pie and Autohausz has activated charcoal filters on sale like 20 bucks....no excuse not to change this thing yourself and save money
https://www.mann-hummel.com/mf_prodk...u/HB5JXdhG.pdf
Old 10-29-2011, 12:57 PM
ghstudio's Avatar
Mercedes e350 BlueTec
Originally Posted by viksc230
https://www.mann-hummel.com/mf_prodk.../HB5JXdhG.pdf:) easy as pie and Autohausz has activated charcoal filters on sale like 20 bucks....no excuse not to change this thing yourself and save money
Please correct the bad link...
Old 10-29-2011, 01:10 PM
viksc230's Avatar
2005 c230 sport
linky fixt
Old 11-02-2011, 02:19 PM
speedwaywhite's Avatar
Just did it myself. I found it easiest by:
* Pulling back the carpet and padding to get it out of my way
* Once removing the screws and loweing the panel, disconnecting both the puddle light and the sensor connect on the panel allows easier access
Old 11-02-2011, 08:53 PM
jreash's Avatar
Agreed. I also removed the right side panel under the glove box panel. Took me a bit of time to figure out how to disconnect the wires.
Old 02-18-2012, 10:09 AM
MagicJack's Avatar
E550 2010
dust cabin filter replace w/ pics
Instructions:
1) remove 3 screws from the top panel in the passenger footwell.
2) pull back floor mat as you see in picture
3) disconnect 2 wires attached to the top panel. The connection closer to the driver see comes straight out with pressure. The one closer to the passenger door as little tab you press down before pulling out.
3) Remove top panel - takes some manipulation but the plastic is pretty flexible.
4) Slide plastic tab to the left on the air filter and pull it out.
Attached Thumbnails Cabin Filter Replacement DIY-2012-02-11_5093.jpg   Cabin Filter Replacement DIY-2012-02-11_5094.jpg   Cabin Filter Replacement DIY-2012-02-11_5095.jpg   Cabin Filter Replacement DIY-2012-02-11_5096.jpg   Cabin Filter Replacement DIY-2012-02-11_5097.jpg
Old 02-18-2012, 10:23 AM
Raymond Lee's Avatar
Lexus LS 400, 2008 BMW 528i, 2014 e250 BlueTec
MagicJack
Thank you much for sharing the information.
Old 02-18-2012, 12:18 PM
BenzV12's Avatar
W212 FL
Great post, I think this forum needs a FAQ for such useful topics thus you can easily see some tips thanks to these threads
Quick Reply: Cabin Filter Replacement DIY
