CL-Class (W215) 2000-2006: CL 500, CL 600
CL500 TRUNK!!!!
Old 09-04-2011, 12:23 PM
John CL500's Avatar
2004 CL500
Unhappy CL500 TRUNK!!!!
Although I have seen this posted on numerous occasions, I have not found the solution to my problem:
The automatic trunk does not open the trunk.
Neither the Key FOB or the interior lift switch will do it.
The lock/Latch DOES release the the trunk...but no lift.
The lift switch on the drivers door used to light RED when I pulled or pushed it....now...no lights.
The trunk WILL close automatically when I hit the RED trunk button on the bottom edge of the trunk.
I have tried pulling all fuses associated with the remote trunk release....no go.
I have taken off the trunk lid cover and saw no obvious problems there.
I DO hear air moving when I hit the trunk release on the key....but I do not feel any air leaking out..
Recently tried something different.
I hit the trunk release button on the key to unlatch the trunk
I then lifted the trunk manually (about six inches)
Then I hit the release button again and it went up automatically...as it should.
PLEASE....IF YOU HAVE FOUND A SOLUTION TO THIS COMMON PROBLEM.....Email me at johnbosmans@yahoo.com
Thanks ALL!
P.S. I have posted this on Benzworld.org also...NO SOLUTION THERE
Old 09-05-2011, 05:47 PM
John CL500's Avatar
2004 CL500
And here I thought was a very common problem...???????
Old 09-05-2011, 10:58 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
If you hear air leaking when actuating the trunk with the key or one of the switches, then your latch is most likely leaking air (which the PSE pump will eventually shut off and disable). You shouldn't be able to hear any air leaking with it working properly. As for the problem with the trunk not opening/lifting when operating, I would check the wiring around the trunk lid hinges to make sure one or more of them aren't broken.
Old 09-30-2011, 02:22 PM
wigging's Avatar
04 CL55
similar problem
I just posted a similar problem on my 04 cl55.... except, I cant get the darn trunk open at all. Even with the key. I can turn it to valet/locket but that does help me. In the open/neutral position, I push up on the lock but the trunk wont budge....
see my post about 10 slots newer than this if you think you can help.
didnt mean to hijack- whats with these trunks seems like lots of folks have this problem.....
Old 09-30-2011, 03:34 PM
saintz's Avatar
GL450
There are several problems that can occur.
The hydraulic pump that opens and closes the trunk can lose fluid. In this case, the trunk will pop an inch open, no more. It won't auto close, either. You will hear the pump running dry trying to open it. Fix is to remove the pump (under the battery) and refill the fluid reservoir, and patch the leak if there is one.
If the trunk won't open at all, the pneumatic system probably has a leak. Open with the key, remove the trunk panel, and JB Weld whatever is leaking back together. I've had the bladder break twice.
You can also have the electronics get a cut wire or other issue. This will generally manifest in things like no light coming on for the trunk buttons, the buttons not working, etc.
Old 09-30-2011, 04:55 PM
John CL500's Avatar
2004 CL500
wigging - no prob on the hijack....I still havent found a solution.
saintz - Since the trunk does auto close with the red button, I will assume its not the pump fluid.
Since the trunk does unlatch and open after lifting it 6 inches or so and then hitting the open trunk button on the key fob, I will assume its not the Hydraulic pump.
So that leaves me with a likely electrical problem. I would probably start at the mesh encased wires that go from the trunk into the vehicle itself????
Does that make sense?
Old 10-01-2011, 10:49 AM
saintz's Avatar
GL450
You might have trunk safety mode turned on. This causes the trunk to only crack open and then you have to press again to open it all the way. It's to prevent the trunk from hitting something in a parking garage.
Try holding the trunk open button inside the car for over 5 seconds. This should reset it to open all the way.
https://mbworld.org/forums/s-class-w...-half-way.html
Old 10-01-2011, 02:15 PM
John CL500's Avatar
2004 CL500
Saintz....I thought so also.....tried that.....no luck. I guess I am back to checking the wiring.
Old 10-07-2011, 06:19 PM
John CL500's Avatar
2004 CL500
What the PUCK!!
Success!
Thanks to Wig and Saintz.....
Finally got in to the Trunk Latch and discovered that it was indeed the Pump Actuator (THE DREADED PUCK) that was causing the problem.....It was cracked in several places.
So i took the following steps to fix the problem.
First, Cabled tied the puck tightly....
Next, Epoxy all around the seams....
Last, Good Old electrical tape to give it the extra sealing power....
Re-Installed the puck......and.............power assist trunk works!!!
P.s. This fix also corrected my drivers side door soft close problem!
Old 10-07-2011, 06:34 PM
240M3SRT's Avatar
CL 600
Congrats on the not too expensive fix. Where is the pump actuator located and what does it look like?
Originally Posted by John CL500
Success!
Old 10-07-2011, 06:53 PM
John CL500's Avatar
2004 CL500
Behind the Trunk Lid Cover....in the Trunk latch assembly...
Trying to get a picture of it....will post it soon...if you need further instructions/info just let me know....I am glad to help.
Old 10-07-2011, 07:07 PM
John CL500's Avatar
2004 CL500
Pic of PUCK
Old 10-07-2011, 10:35 PM
240M3SRT's Avatar
CL 600
Pic of PUCK
Nice job! Thanks for the pic.
Gotta love epoxy.
Old 11-18-2011, 11:08 PM
thesheikh's Avatar
94 S600 | 95 SL600 | 97 SL600
Hey John! Thanks for this thread. I have the same problem with my e500. Im going to try and check this out. Where exactly is the pump actuator located?
Old 03-28-2012, 10:26 PM
DjSpin's Avatar
2005 cl500 benz
Thank you so much for the very helpful info..I had the same problem and flowed the steps and its working again.
Old 03-29-2012, 10:03 AM
mf219's Avatar
2004 CL500
Pic of PUCK
any chance you could post a pic of where the "puck" is located?
Old 07-31-2012, 01:11 PM
Anthony PNC's Avatar
2004 CL 500
John - great stuff, I have the same issue right now. My technical issue is, how do you remove the puck? Do you have to pull out the entire lock assembly or can you disconnect the puck while the assembly is still attached? I got in there today and couldnt figure it out.
Old 07-31-2012, 08:05 PM
biker349's Avatar
cl600
can you buy the puck seperately?
Old 07-31-2012, 08:24 PM
2004 CL 500
No you can't buy it separately.
Old 07-31-2012, 09:53 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
Actually I have found a supplier for the piece (Boot Closer Assist Upper Cap) separately as well as the door close assist pieces if needed. If you want info feel free to PM me.
Old 12-28-2012, 01:36 PM
tonydt1g3r's Avatar
CL500
thanks for this thread. The puck was broken like stated above. I used some permetex plastic weld and put it back together. saved me some $ thanks again
Old 02-08-2013, 11:15 AM
CL500's Avatar
11' E220 CDI
Can anyone explain to me how to remove this puck thing?
As of now - my doors won't autoclose anymore and I'm unable to remotely lock the car with the key.
I checked the 20A fuse (under the rear seat) and it was blown. Put a new one in, and I can hear that the pump starts up - runs for a while and then blows the fuse again..
Old 02-08-2013, 12:22 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
The trunk puck or the door puck ? This thread is in regards to the trunk. There is another thread about the doors that has more info.
Old 02-08-2013, 12:48 PM
CL500's Avatar
11' E220 CDI
As far as I could understand the problem I'm experiencing has to do with the pump/puck - in the trunk.
The doors AND the trunk won't softclose anymore. I'm also unable to lock/unlock the car with the key remotely (central locking).
I can open the trunk mechanically, and also the drivers side door.. (at least when it's not frozen).
Old 02-08-2013, 09:58 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
For the trunk, you need to remove the rear plastic trim that holds the electronic close and/or lock buttons (on electronic optioned trunks).
Then remove the felt covered trim panel from the lid.
You will then see the pneumatic locking unit. To remove it, remove the locking rod and associated screws.
Quick Reply: CL500 TRUNK!!!!
