How to reset B Service message
Old 07-20-2011, 04:47 PM
Red66GT's Avatar
2002 E430 SE
I've found on here how to do it for most other cars except the 210. Anyone?
Old 07-20-2011, 05:06 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
This used to be in the owners manual but was removed at some point (2000?).
This is for early W210's -
The counter can also be set by any individual. To do so:
1. Turn electronic key in steering lock to position 2.
2. Within 4 seconds press button 0 twice.
3. The present status for days or distance is displayed.Within 10 seconds turn electronic key in steering lock to position 0.
4. Press and hold button 0, while turning electronic key in steering lock to position 2 again. The present status for days or distance is displayed once more. Continue to hold button 0. After approx. 10 seconds a signal sounds, and the display shows 10000 miles (Canada: 15 000 km).
5. Release button 0.
Also I think some minor changes using the steering wheel buttons. On early models button 0 is the one you press and hold to reset the trip odometer to zero.
For some strange reason it seems if you leave the door ajar it doesn't work ?? Sometimes takes two or three tries.
Old 07-20-2011, 05:26 PM
raymond g-'s Avatar
99 E320
Old 07-20-2011, 06:30 PM
Red66GT's Avatar
2002 E430 SE
0 button? The only 0 button in my '02 is on the radio. 0 button?
Old 07-20-2011, 06:52 PM
RichardM98's Avatar
As I said the procedure is for early W210's without steering wheel controls.
Old 07-20-2011, 06:55 PM
Red66GT's Avatar
2002 E430 SE
Ok, anyone have the prodecure for my 2002 E430 please!
Old 07-20-2011, 10:32 PM
raymond g-'s Avatar
99 E320
it's listed in your owner's manual....and also replicated above. did you attempt
the sequence and it failed to reset?
Old 07-21-2011, 01:10 PM
Red66GT's Avatar
2002 E430 SE
Ah, got it. Page 116. Took about 4 tries. Thanks guys.
Quick Reply: How to reset B Service message
