ML320 window - motor seems ok but glass wont go up!
Old 04-07-2011, 10:47 PM
PrfNyr's Avatar
Hello all,
My 2001 ML 320 has chosen to misbehave again!! The window glass will not go up. When I press the switch, I hear the motor whirring but the glass does not move up or down. Can some kind person please shed some light on what the causes could be and how I might go about fixing it.
Thanks so much!!!
Bob
Old 04-07-2011, 11:10 PM
Sathinas's Avatar
His mama. Traded y0 mama in because she was squeaking.
Sounds like a stripped gear in the window crane mechanism.
Old 04-07-2011, 11:23 PM
PrfNyr's Avatar
thanks and question...
Thanks for your input. Is this a repair that I can attempt on my own? Or do I need to take it to dealer or autobody shop or whom dya suggest?
Thanks again
Old 04-07-2011, 11:30 PM
Sathinas's Avatar
Unfortunately, you're asking questions that I have no reasonable ability to answer honestly.
I don't know what your mechanical aptitude and skills are.
I don't know where you are, so, short of recommending someone locally where I am, I can't recommend someone locally where you are.
I'd take it to a reputable body shop or even a reputable Indy shop. But I'd get a couple more suggestions of what's going from more knowledgeable members here than I, before you start replacing stuff that may not be replaced.
What you described is a general symptom of a bad window crane gear mechanism, but that doesn't mean that's what it is. I only offered that suggestion based on my experience with power windows on other manufacturers' vehicles.
Old 07-21-2011, 01:28 PM
mercedesml320's Avatar
ml320
window not going up
Need to replace whole console, easy, just order,, about $160.00.
Old 07-22-2011, 08:35 AM
MBtech1's Avatar
2011 C 300 4-Matic
If you can hear the motor running but the glass wont move, the window regulator needs to be replaced. If you cant hear the motor running, on 163 MLs its almost always the switch. But yours definitely sounds like the regulator is broken.
Quick Reply: ML320 window - motor seems ok but glass wont go up!
