USB CONNECTIONS
MB will sell you an adapter that plugs into the same socket in the glovebox that the standard Ipod connector plugs in to. Simply unplug the one that came with the car and plug in the one you bought from MB. The run about 50 bucks. If they dealer does not have it in stock they can get it in a about a week.
I did this and it works like a charm. However, you do not down load the data from them memory stick. Rather, the command system reads the memory stick and treats it as aux media. Plays MP3s from the stick just fine and displays the directory structure that you created when you copied the data to the USB stick.
Anybody know how to do either of these things?
Wow, I would like to download to the HD if possible. I spent months loading CD's to the hard drive and I would like to be able to easily rewrite it from a download. I hate the thought of a hard disc crash as well. How do you back up the the system?
From the computer, you MAY also be burn the music to a portable 1 TB Seagate HD that uses both MAC and NTFS on the fly and connects/and is possibly powered by the MB with USB 2, 3 and Firewire. Transfer the music from the Seagate HD through the ipod USB adapter - this gives you another backup and source, perhaps.
PM me if you want more info. Include the system(s) you are using since I did not know the MBs now had hard-drives.
Is there an MB manual online for this audio system? Can someone send me the link?
Why bother to download low fi MP3s when you might be able to have DVD-A quality music?
Last edited by grane; 04-05-2011 at 03:58 PM. Reason: the mind reels with the possibilities!
2011 E550, 2013 GLK
Idea: Copy CDs to computer in highest possible quality mode, create the play list on the computer, burn/upsample to DVD-R(s) and then download. Then you have two backups and a portable source. The DVD-R that holds a heck of a lot more than a CD as you know.
http://www.mbusa.com/mercedes/servic...owners_manuals
Let me clarify a few things if I may
You can't copy CDs to a computer, you can extract the audio as WAV and encode it in to some compression format. Not sure 100% but I think COMMAND might only understand MP3, might be wrong here as I have not looked at it yet. There are many levels of MP3 quality you can use when you encode. I like 320kbps CBR (constant bit rate) using EAC to extract and lame to encode.
You can't upsample the sound quality when you burn to a DVD, all you are doing is burning the encoded files in what ever quality they are on to the media, DVD-R in your case.
I'm a bit confused here with MAC and NTFS? What do you mean by MAC? You mean HFS file system used my Mac computers? I would think COMMAND needs FAT to be able to read the drive. Not sure if the USB connection provided by MB will have power to run external hard drive. There is no FireWire option on the MB. Hardly anything now days uses it. Also there is an indication that COMMAND does not allow to copy files threw the USB connection, only play them back.
Simply burning audio tracks in to a DVD will not magically give you a DVD-Audio quality. DVD-Audio like SACD is a higher-fidelity audio recording by using a higher bit depths and sample rates. A DVD-Audio disc may contain a 96 kHz/24-bit 5.1-channel audio track or/and 192 kHz/24-bit stereo etc. That is what gives higher sound fidelity over the red book (CD) 44.1kHz/16bit. You have to start with high-fidelity audio. There are also very few tools available to allow one to extract and copy the sound at that quality to another format white maintaining the same quality/resolution and limited playback options.
Would anyone happen to have part number for the USB cable? My parts guys at MB Escondido haven't heard of it (go figure...).
mb500, if you can wait, i could possibly save you over $50. i bought a 3.5mm to usb female converter but haven't received it yet. if it works, the cable is only $3 from ebay. however, if you can't wait, you can also find the oem cable set from ebay for around $50. i mean cable set because it comes with three individual cables: usb, ipod and 3.5mm.
Go to your dealer and look at the accessories booklet. The USB cable is there and amazingly it is not listed in MB parts computer system for E class. I bought it and the bag it comes in has all cars listed what it is made for and the E class is the first one on this list. Works well.
Received 4,415 Likes
'71 Pinto
Media Interface USB cable part # 2048270304 (see page 12 & 22) – MSRP $65
http://www.mbusa.com/vcm/MB/DigitalA...s_brochure.pdf
i think this will work but it's $30 for one. some guys on ebay have 3 different oem ones for around $50 or a bit more. you can put the other two back up on ebay if you don't want them.
btw, burnt some mp3 to a dvd+rw but showed unreadable. do you guys have any ideas ?
also, if i do get the usb female adapter for ipod which i can plug in the cable that came with the car in the glove box. do you think it's workable if i plug either a usb flash drive or portable hard drive w/tons of mp3's ?
