W210 AMG Discuss the W210 AMG's such as the E50, E55, and E60
Squeaky steering wheel
Old 03-05-2011, 12:24 AM
mtnhouse's Avatar
02 E55
I need help how make this squeaky sound go away. Every time I turn my steering wheel it makes this squeaky sound. Do I need to add a steering fluid?
Old 03-05-2011, 01:01 AM
ruBENZ's Avatar
2000 E55 AMG
Originally Posted by mtnhouse
...Do I need to add a steering fluid?
It wouldn't be a bad place to start.
Old 03-05-2011, 10:06 AM
mtnhouse's Avatar
02 E55
thanks i will try that
Old 03-05-2011, 11:03 PM
saintz's Avatar
GL450
If you're on smooth concrete, like a parking garage, it will squeal because that's the sound of the rubber on the smooth surface.
If it does it on asphalt, it's a low or tainted power steering fluid. First, check your levels. If you're topping up, a synthetic power steering fluid from an auto store is probably fine. If you need to add a lot, buy Mercedes/Fuchs fluid. If topping up doesn't work, you'll need to flush it and refill.
Old 03-06-2011, 04:18 PM
fintail's Avatar
S213 E450 4Matic, W111 220SE - prior cars: 3x W212, W210 E55 AMG, W202 C43 AMG, W126 300SE
Is this a noise coming from the engine area or from the steering wheel itself?
Now and then, especially in the cold, I get a faint squeak out of the steering wheel, seems to be coming from where the wheel meets the column. I can't imagine how much of a pain it would be to fix, so I just ignore it.
Old 03-06-2011, 09:17 PM
mtnhouse's Avatar
02 E55
Its coming from the inside. It gets louder when you turn the steering wheel slow. Hopefully wd40 will fix it.
Old 03-07-2011, 07:55 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
I had the same problem on my E55, it is coming from the sealing boot between the firewall and the steering shaft, do not replace the boot. Simply lubricate the existing boot with the improved grease on both sealing surfaces inside and outside thefront bulkhead. Improved grease Part Number A001 989 84 51 10.
On E320 and E430 the boot should be replaced with Part Number A210 462 10 96 and be lubricated with the improved grease. That should take care of your annoying squeaky sound from your steering column.
Old 03-07-2011, 11:21 AM
mtnhouse's Avatar
02 E55
Thanks I will try that this weekend.
Old 03-08-2011, 02:14 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
so is this done from under the car , inside under the dash or under the hood .. lol would like to try this out
Old 03-08-2011, 02:40 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Some members reported that adding Lubrisol to the PS fluid helped. In my case, the rack/pinion came out, a seal was replaced, buttoned back up and a front wheel alignment was done.
Old 03-09-2011, 08:35 AM
Factory Service Bulletins
Found this on my old computer last night. FSB for E320 and E430 on squeeky steering wheel, it might applied to E55.
Old 03-10-2011, 10:51 PM
armaniE55's Avatar
2012 CLS63 AMG
Talking
Attachment 204615
this is exactly what happen to my old 99 E430 drove me bananas. This is the only way to fix it, everything else is just a band aid.
Hope all is well Peter, I'm sure you dying to take out the Porsche
Quick Reply: Squeaky steering wheel
