ML320 - Key fob issue - start error after battery change
Old 02-07-2011, 09:08 PM
boomie's Avatar
W166 ML350 Blutech
Long and short.
Battery was on the fritz. Bought a new battery from Mercedes. Change the battery.
Started the car, put the key in the ignition- then got start error.
Car would turn but then stop right after.
Tried my other fob, same error.
Detached the battery, let it sit for 5 mins.
Put the key in and no more start error. Car turned, no problem.
Tried the other fob, and i still get the start error. Car would not turn.
Any thoughts?
I took it to Mercedes and they said I need a new fob. Not sure why. The broken fob can still lock/ unlock the doors.
Please help. A new fob in Canada costs $250. RIP OFF.
Timothy Burgoyn (11-16-2022)
Old 02-08-2011, 08:32 AM
Geno777's Avatar
2000/ML320 2005/Subaru Baja
Originally Posted by boomie
Long and short.
Any thoughts?
I don't know what a fob is, however when i change a battery on a car that has a radio that has to be reprogrammed with a battery change. I hook up my jumper battery to the cabels BEFORE I disconnect it and then change the battery, put the cables back on the battery then disconnect the jumper battery. Works like a charm, Jumper battery @ harb. fret. around $50.00 USD.
Old 02-10-2011, 10:06 AM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
Check out this post ---
https://mbworld.org/forums/m-class-w...mediatley.html
Old 02-11-2011, 08:24 PM
c3212571's Avatar
2002 Mercedes c32 1998 Toyota tacoma 2002 Honda Cbr600f4i
Sounds like craks sensor going bad. or is bad!
!!!!!!!!!!!!always change tranny fluid!!!!!!!!!!!! on ML's!!!!!!!!!!!!
Old 02-12-2011, 11:28 AM
Mike's ML's Avatar
The CPS has different fault characteristics than indicated by the OP.
It is more likely the AAM/DAS key failure.
I have unfortunately experienced both failures in my 98ML.
There is a problem with jump starting the early ML's. If you leave the key in the ignition when trying multiple restarts it will render the key useless.
The Key's RFID chip has lost synchronization with the DAS (Drive Authorizing System). The only fix is to buy a new key and have it programmed into the AAM computer which contains the DAS. For some reason the old key can no longer be programmed into the DAS. Some refer this as Frying the key's RFID chip.
The 98ML's came with 3 keys. Did you try one of the other keys? They should still work.
The AAM can only be programmed with 8 keys maximum so I hope you still have one of the 5 remaining programming spaces left if you need a new key. If not a new AAM is very expensive. This can only be done at a Mercedes dealer.
In the future if the ML does not start, immediately REMOVE the key from the vehicle, charge the vehicles battery, than return the key to the vehicle and attempt another restart.
The Remote's battery has no function in an RFID DAS system. It's only for the remote entry & alrm system.
Good luck.
Mike
Old 02-14-2011, 05:43 PM
cmitch's Avatar
2002 ML320, 2010 Ford F150
A Start Error is most likely the DAS is fried. I've not known of a case where a bad key gave the start error but I could be wrong. The fact you got a start error on BOTH keys at first, then a start error just on one, tells me it's the DAS which is apart from the AAM in 2000 and up models. The fact you get a Start Error on the dash tells me you have a 2000 or up, right?
Please complete your profile and tell us what year model you have. It makes a HUGE difference.
Old 08-19-2013, 12:06 PM
mbenzml350's Avatar
ml350
Hello, I have an '05 ML350 and when I went to start it up, it ran for five second and it cut off, I don't know what the problem is, and now, not even the remote to lock and unlock doesn't work. I need help. Thanks
Old 09-08-2014, 04:10 AM
ssemmedo's Avatar
ML270
This is done buy virgin the MCU inside the ECU. and than make initial startup with DAS
Old 10-18-2014, 04:05 AM
ssemmedo's Avatar
ML270
anothre way to do it is to take all data from DAS and make new transponder with tango or similar tools.
Rate This Thread
Rate This Thread:
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
Quick Reply: ML320 - Key fob issue - start error after battery change
