MOBIL 1 0W40 VS 5W40
Old 02-05-2011, 10:51 PM
BLUEBENZ230's Avatar
Would it make a difference to go to 5w40 vs 0w40 on my car that has 150,000 miles that started to consume 1 qrt per 2 months.
Old 02-06-2011, 05:01 AM
Lancelot's Avatar
'01 W210 E320 CDI
5W-40 is the recommended oil for CDI diesels. My shop refreshed my CDI with 10W-40 once, and it developed a ticking valve-tappet. Be careful with changing viscosity on high-mileage engines...
Old 02-06-2011, 05:17 AM
ohlord's Avatar
1 qt per
two months is nothing. Keep it on the 0w40 wt spec oil.
229.51 spec 5w40 mobil is as above mentioned diesel only spec.
For reference Mercedes considers 1 qt per 600 miles as excessive, so you have no worries at all. keep it clean and keep on driving her
Old 02-06-2011, 10:12 AM
mi benz's Avatar
98 E300
Mobil1 ESP 5W40 also meets MB229.31 (gasser specs). Would that not make it acceptable?
Old 02-06-2011, 11:19 AM
ohlord's Avatar
229.3
and 229.5 are gasser spec
229.51 is mb listed as diesel only
229.31 spec is also low ash diesel only spec
Old 02-06-2011, 01:04 PM
saintz's Avatar
GL450
Originally Posted by http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_ESP_Formula_M_5W-40.aspx
Mobil 1 ESP Formula M 5W-40 is an advanced performance synthetic motor oil designed to help prolong the life and maintain the efficiency of Car Emission Reduction Systems in diesel powered automobiles
5W40 is for diesel only, it says on the bottle.
If you live in the US and do not drive a diesel, Mobil 1 0W40 is the only oil you should use. There is no other oil that meets specs that is cheaper or better.
If you live outside the US, it is possible that it is either very hard or very expensive to find Mobil 1 0W40. In that case, it may be preferable to use another approved oil, like Fuchs, that may be available cheaper and easier.
Old 02-06-2011, 03:37 PM
mi benz's Avatar
98 E300
Mobil1 site says the following about 5W40 ESP:
Mobil 1 ESP Formula M 5W-40 is an advanced performance synthetic motor oil designed to help prolong the life and maintain the efficiency of Car Emission Reduction Systems in diesel powered automobiles that require oil that is approved against Mercedes-Benz MB 229.51 or MB 229.31specifications. Benefits of Mobil 1 ESP Formula M 5W-40:
  • Approved against MB 229.51
  • Approved against MB 229.31
It's not like the two specifications are mutually exclusive. 0W40 is approved for both MB229.5 & 229.3
My only question is if MB229.51/.31 are backward compatible to MB229.5/.3
Old 02-06-2011, 04:54 PM
ohlord's Avatar
No
the 1 following the 5 or the 3 means it has different properties.
Mb's list of approved oils even lists the .51 as diesel only.
The extra number does not mean it exceeds the specs of the approved oil.It means it is for a different application entirely.
0w40 m1 was just on sale a few weeks ago for 4.99qt
Old 02-06-2011, 06:26 PM
saintz's Avatar
GL450
Mi benz, if you read the quote you posted from the Mobil website, you'll notice it says it's for "diesel powered automobiles." This is the same sentence I posted, with the word "diesel" in bold.
Old 02-06-2011, 06:27 PM
saintz's Avatar
GL450
For more on oil: https://mbworld.org/forums/mercedes-...-read-faq.html
Old 02-06-2011, 07:56 PM
mi benz's Avatar
98 E300
Yes- I did read it
I was pointing out that the oil also meets the current MB gasoline engines (229.31), so its not really "only for diesel", right?
Old 02-06-2011, 08:00 PM
mi benz's Avatar
98 E300
I just saw this. Am I mistaken or is 229.31 the gasser spec?
Thanks for educating me.
Old 02-15-2011, 06:04 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
There used to be a Mobil1 Formula M (no ESP) 5W40 and I run that in mine. I am using less oil than I did on 0W40. From what I've read it is no longer available.
Old 09-23-2011, 08:03 AM
kyosuke's Avatar
1999 e320 ,2006 AMG S55
lul whut
says GASOLINE AND DIESEL,this is what they gave me at the dealsership its 5w-40 Formula M
Old 09-23-2011, 10:22 AM
juve010's Avatar
e320 4matic wagon
I have to say, after I switched from 5w to 0w40, I have aLOT more ticking upon startup which makes sense with lower cold weight. I think I might switch back to 5w.
Old 09-30-2011, 02:56 PM
Lancelot's Avatar
'01 W210 E320 CDI
Once again;
229.51 is low-ash-oil for Diesels with a DPF (Diesel Particle Filter or Sooth-filter), BlueTec etc.
The low-ash might even be BAD for the regular bearings in our engines!
229.5 Is better than anything that was available when our, now at least 10y/o, engines came out!
My current fill is Valvoline SynPower 5W-40 229.5 spec
Old 10-02-2011, 11:53 PM
E320User's Avatar
Black 2000 E320 4Matic
So 0W40 is the correct oil to use, what would happen if a gasoline engine was to use the 5w40?
is 5w40 better for colder regions?
Old 10-03-2011, 10:27 AM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I Have been using AMSOIL 5W-40 for years , I know it is not the Mobile 1 , but should I consider changing ?
Old 10-08-2011, 01:00 PM
mi benz's Avatar
98 E300
why would a 5W be better than a 0W for colder regions?
Based on the fact that the above label shows the oil is approved for 229.3, nothing bad would happen to a gasoline engine running this oil.
Old 10-08-2011, 01:02 PM
mi benz's Avatar
98 E300
Originally Posted by Lancelot
Once again;
Over here that oil is shown good for both 229.5 AND 229.51
Old 11-15-2011, 11:53 AM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
There was some confusion in this thread (I myself was VERY confused on this for a long time and was scared my dealer on its first two changes had put in ESP OIL)! However, they didn't...
True, the ESP Formula M 5w40 should always be used only in diesel cars.
HOWEVER, there is another Formula M 5w40, that is not ESP. Many Mercedes-Benz dealers have this oil, both in barrels and on their shelves in bottles to sell to you. You won't find it at the local parts store though, there you will only find the ESP (diesel) one.
The 0w40 meets more manufactures, and it is richer in additives when you run an analysis on it. If you are going for the 10k-13k oil changes, it might be better. If you don't do so many miles in the year, my oil analysis I send in, shows that the 5w40 Formula M (NOT ESP) gives essentially the same results, even if it is a slightly less robust oil in its additive package.
Nevertheless, I still use the 0w40 for the extra additives in case I do ever go to the full 10k+ miles in a year.
Now, the ESP (diesel) version I also had an analysis ran on for the fun of it. It is MUCH weaker in additives than its gasoline approved counterparts. It would likely work fine for a short time, but after a few thousand miles, the additives would be used up and that wouldn't be so good for the engine to keep using it then.
Old 11-15-2011, 04:50 PM
saintz's Avatar
GL450
Mac, thank you, that is proof that just because the numbers are similar, does not mean the oil is similar. Everyone needs to pay attention to what's on the bottle. The difference between the ESP and non-ESP 5w40 is likely to throw a lot of people off. Mobil should do a better job differentiating, really. In the meantime, 0w40 is one of the best (and most recommended) oils on the market.
Old 11-16-2011, 08:06 PM
dsmith's Avatar
88 535is, 89 318iT
For clarification, at 150k miles, it doesn't matter what oil you use. The trans will die and the car will be worthless long before the engine dies.
But still, 0w40 Mobil 1 is the safe bet, and cheap when on sale.
Old 11-16-2011, 09:36 PM
Ungarisch's Avatar
Tectitgrau S210
My manual calls for 5w-50, my local Napa carries Mobil 1 5w-50 usually on sale for 5 bux a qt, Also Castrol has a full synth 5W-50 as well.
I prefer the Castrol, but it seems that Mobil 1 has more deals/specials.
Old 11-16-2011, 11:06 PM
blacked210's Avatar
99 Mercedes E320 Sedan
so i went to pep boys today and they had a good deal on the 5W-40 Castrol Edge which meets the MB229.3. it cost 22.99 for 5 quarts plus a filter (i just picked up a random filter to us on my other cars) after the 7 dollar rebate, so it comes out to be like little over 4 dollars plus a free filter so i picked up to specials. just thought id share, since we where on this topic.
http://forms.young-america.com/124508_PBA-111105.pdf
also there is a form for a free football
http://www.castrol.com/liveassets/bp...l_rebate_A.pdf
Quick Reply: MOBIL 1 0W40 VS 5W40
