2001 CLK 320 antenna (rubber boot)
Old 01-10-2011, 04:24 PM
rcrane's Avatar
2001 clk 320
Hey All,
I am looking for information regarding the rubberr boot that protects the rooftop antenna. I am sure the dealer will tell me that the whole dome like assembly will need to be replaced but any ideas where I could buy one? The rubber piece tore and I was using black electrical tape until a recent trip to the car wash. Now it is gone. Any help would be great!
Old 01-11-2011, 12:24 AM
CLK430Benz's Avatar
2010 C300 4MATIC
Originally Posted by rcrane
Hey All,
I purchased one from eBay and installed it myself. When installing it make sure you run hot water and soap on the rubber stub antenna because it will not fit through the boot. The rubber boot seal is sold with the rubber antenna.
This is the listing I recently purchased mine from: http://cgi.ebay.com/ebaymotors/ws/eB...ht_2486wt_1163
Old 01-11-2011, 01:49 AM
MarcusF's Avatar
2002 CLK430
www.europartsdirect.com do a search on antenna. They're about $25.
Old 01-11-2011, 08:59 AM
rcrane's Avatar
2001 clk 320
Thank guys. I appreciate it and will search tonight.
Old 10-25-2012, 09:19 PM
bgillj220's Avatar
ML320
Had a similar problem on 2001 CLK320 Coupe. Rubber cap of antenna disappeared over the summer when my son was driving it. Local consult with MB Dealer resulted in advice to buy the entire assembly for $220 installed. I went on EBay and bought an after market URO replacement cap/gasket for $25. The antenna hood can be removed with a hex tool in about 2 minutes. The hex nut in on top, easy access. The replacement cap was a tight fit and required some WD-40 and took about 20 minutes to work through existing antenna hood opening. Gasket fit perfectly. Make sure old rubber cap is entirely off. I had the residuall base and once I figured out that was impeding the fitting of the new cap it was a breeze. Total cost $25 and 1/2 hour of elbow grease. Looks and works perfect .
Quick Reply: 2001 CLK 320 antenna (rubber boot)
