E-Class (W211) 2003-2009
anyone smell gas fumes inside the car?
Old 01-06-2011, 12:26 PM
health services's Avatar
Does anyone smell gas fumes inside the car after a fill up? This problems seems to be getting worst and my wife will not fill the tank over 3/4 car anymore because of this.
Thanks.
Old 01-06-2011, 12:33 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
https://mbworld.org/forums/e-class-w...-04-320-a.html
Old 01-06-2011, 12:36 PM
Wow, my search did not find that! Thanks
Old 01-08-2011, 11:03 AM
Tom T's Avatar
2017 E300
Thanks.
I just replaced my fuel filter yesterday. I noticed that there is some fuel leak on top of the fuel filter side through the gasket. I did get the gas smell sometime after fill up. If you have the back seat fold down option, just lift them up. There are 2 covers under the carpet each side of the rear seats.
Old 01-08-2011, 02:41 PM
I have a fixed back seat, how do I remove the seat bottom?
Old 01-08-2011, 02:57 PM
'71 Pinto
I have a fixed back seat, how do I remove the seat bottom? Thanks
Press locking mechanisms located on both sides and pull seat upwards. Check your email.
Old 01-08-2011, 03:20 PM
Thanks, I'll try it later when my wife gets back.
Old 01-09-2011, 04:18 PM
ok so I pulled it off thanks for the help konigstiger.
It looks like the seal is leaking that holds the pump in place. Either that or when the last person who removed it did not replace the seal correctly.
Attached Thumbnails anyone smell gas fumes inside the car?-dsc06195-copy.jpg
Old 01-09-2011, 05:21 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
You don't say what year or model you have (I wish people would list their car with their avatar ), but the 'leaking fuel sender issue' is not uncommon on early to mid W211s.
Do a search on the W211 AMG forums and you'll get detailed information that should prove very helpful. There's a lot of good info (with photos) and you'll know what to do once you read it. It's not a "seal" issue, but a defective design.
Old 01-09-2011, 07:01 PM
I have a e500 2005, looking at the complain page of NTSA I see only one complaint. Called a "friend" at the dealer, and instantly he told me where to look for my issue on my car.
I'll see if I can replace the seal to see if that will help. I don't have the money to replace a tank assembly right now.
Old 01-10-2011, 03:30 AM
220S's Avatar
Are you the original owner? Did you get a recall notice?
If not, then go to your dealer and get a VMI printout and see if the recall repair was ever done. You may still qualify if it wasn't (or at least get some goodwill.) If it was a CPO'd car you may still be covered.
I've attached the recall notice. Did you check the big thread on the AMG forum? The leak comes primarily from a hairline crack in the plastic cap of the sending unit and not so much the seal. It's a badly designed part.
File Type: pdf
Old 01-13-2011, 01:08 AM
I emailed my SA to see if falls under the recall
Quick Reply: anyone smell gas fumes inside the car?
