W211 E55 FUEL TANK CAPACITY
Old 12-31-2010, 02:55 PM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Anyone have an idea the actual capacity of the fuel tank on the 06 w211 e55 AMG? Understand the capacity is greater than that on the smaller engined w211 sedans.
Brgds
Old 12-31-2010, 03:00 PM
shooter's Avatar
2011 Ford Raptor, 2003 FX35, 2008 E63 AMG (Gone but not forgotten)
You should be able to get that from the manual. You can download it here.
http://www.mbusa.com/vcm/MB/DigitalA...tic_e55amg.pdf
Old 12-31-2010, 04:40 PM
Super Moderator
BenzoBoi's Avatar
W221
Brgds
I believe 21.1 gallons is your answer.
Old 01-01-2011, 03:24 AM
OK55's Avatar
80 litres. Fuel gauge reading isn't proportional then. Indicated half tank fills up with some 55 litres. Never had the courage to run it empty and can't seem to locate a drain for the tank either. Has anyone actually confirmed by emptying the tank and brimming it afterwards - bearing in mind the fact that gas station pumps may vary significantly in dispensing accuracy?
Or is my fuel gauge simply bonkers?
Thanks & brgds.J
Quick Reply: W211 E55 FUEL TANK CAPACITY
